No zero home on Z axix
24 Jun 2014 04:31 #48210 by kayej
No zero home on Z axix was created by kayej
Messing around with stepconfig to try and get my spindle motor working with little success, however, when I put everything back to the original values etc, my home location for Z axis is now -50.862 even though in the stepconfig file home location for Z axis is 0.0 When I home Z it reflects value -50.862. When the files starts the Z axis will go to -2 for engraving but home is still -50.862. Where did I go wrong?? Thanks. This forum has been outstanding in helping a newbie get onboard with linuxCnc.
24 Jun 2014 06:51 #48211 by BigJohnT
Replied by BigJohnT on topic No zero home on Z axix
You might have an offset from running a program.
linuxcnc.org/docs/html/common/User_Conce...hen_you_8217_re_lost
JT
24 Jun 2014 07:19 #48212 by kayej
Replied by kayej on topic No zero home on Z axix
Got it!! You got me going in the right direction. Touch Off was messed up and now everything is zero.
