linux cnc and closedloop dc motor control
25 Jun 2014 04:04 #48232 by guicnc
do i or do i not need a mesa board to do positioning control with dc motors and quadrature encoders on Linux cnc ? or it can handle them directly from parallel port?
dose it do pid same way?
25 Jun 2014 04:15 - 25 Jun 2014 04:17 #48233 by PCW
You can control a DC motor with just a hBridge, and a parallel port
This setup uses the same PID component as a fancier setup using external hardware
The limitations of using a parallel port are:
limited encoder resolution*speed
limited PWM resolution
But it does work:
emergent.unpythonic.net/projects/01142347802
for example
Last edit: 25 Jun 2014 04:17 by PCW.
The following user(s) said Thank You: guicnc
Time to create page: 0.132 seconds
