SET PROBE in linuxcncrsh
- zek99
28 Jun 2014 01:55 #48278
by zek99
SET PROBE in linuxcncrsh was created by zek99
Trying to use SET PROBE over telnet in linuxcncrsh but only get set probe nak or no response at all. Anyone know how the syntax is for using SET PROBE? If I use SET MDI G38.2X10.0 it works but then the next problem is how to obtain the #5061-#5063 over telnet. Anyone familiar with that?
- ArcEye
- Thank you received: 758
28 Jun 2014 17:44 #48297
by ArcEye
I think that if you send a MDI command such as '(DEBUG, Value of X is #5061)'
you should be able to get the string using one of the
get error / get operator_display / get operator_text commands (most likely one of the last 2)
I have not used it for quite a while, so you will have to experiment.
Replied by ArcEye on topic SET PROBE in linuxcncrsh
Time to create page: 0.257 seconds
