MPG to behave as a real handwheel
- jeeybee
18 Jul 2014 03:36 #48904
by jeeybee
MPG to behave as a real handwheel was created by jeeybee
I have tried several times to use the search function but it generates only a blank page for some reason so please point me in the right direction if there is a similar thread.
I wonder if LinuxCNC is able to make an MGP or encoder fed handwheel behave as it would on a manual lathe or mill?
For example in Mach3 it only takes 0.01mm or so for each pulse which gives a choppy motion, or it can operate in velocity mode but then it just moves faster the faste you turn the wheel but not relative to the actual movement of the wheel.
I think there would be a lot of people interrested in having there lathe cnc customized but also still be able to jog it as it was still manual.
What do you think?
What do you think?
- Thank you received: 2159
18 Jul 2014 11:56 #48913
Replied by cmorley on topic MPG to behave as a real handwheel
You can set the increments to whatever you like in linuxcnc. Also often a filter component is added to smooth the pulses.
- Thank you received: 4966
18 Jul 2014 21:19 #48925
Replied by andypugh on topic MPG to behave as a real handwheel
Try scrolling down a long way, you might find results. (No, it's not very obvious). so please point me in the right direction if there is a similar thread.I have tried several times to use the search function but it generates only a blank page for some reason
www.linuxcnc.org/docs/html/man/man9/ilowpass.9.htmlFor example in Mach3 it only takes 0.01mm or so for each pulse which gives a choppy motion
Time to create page: 0.065 seconds
