Warped/ variable thickness workpeice compensation
- geo01005
25 Jul 2014 00:56 #49100
by geo01005
Warped/ variable thickness workpeice compensation was created by geo01005
So I'm planing on doing a fair amount of V-carving with my linuxcnc powered CNC router table. As you may know the width of a V-Carved segment is a function of the depth the tool penetrates the surface of the workpeice. Many pieces of wood have variable thickness or might be warped. This isn't so be a problem when using less detailed "wide and deep" carving strokes. But when doing fine engraving work you can end up with a stroke that is .015" wide on one side of a workpiece and .045" wide on the other side of the workpiece if that side is only .015" thicker, or higher.
One answer to the problem is simply only use "high quality" raw materials. I would like to look at a different answer to the problem. I'm thinking that I ought to be able to use a touch probe to do a grip probe routine before cutting that can then be used to modify the Z coordinates in the G-code to compensate for workpiece warping and variable thickness.
Is there any existing feature in Linuxcnc that does something like this? The closest thing I know if is torch height compensation for plasma cutters. Or has anybody done something similar outside of linuxcnc?
- alan_3301
- Thank you received: 33
25 Jul 2014 02:27 #49104
by alan_3301
Replied by alan_3301 on topic Warped/ variable thickness workpeice compensation
Search for probekins
It is a kinematics module for linuxcnc that uses a touch probe to create a surface offset for the gcode to do exactly what you want.
It works very well too!
I have posted my experience with it in this thread
www.linuxcnc.org/index.php/english/forum...-and-using-probe2stl
don't get discouraged, it will take some effort to get it working, but it is totally worth it.
- geo01005
25 Jul 2014 13:51 #49117
by geo01005
Replied by geo01005 on topic Warped/ variable thickness workpeice compensation
Cool, just what I was looking for!
Anybody used this with a gantry machine? I currently use gantrykins for my router.
- Thank you received: 4968
25 Jul 2014 19:05 #49120
In that case you probably have to combine the two into a gantryprobekins.
As the modifications are to different axes it probably isn't too hard (and your special kins could hard-code the gantry linking to suit your specific machine, rather than being generic like gantrykins)
Replied by andypugh on topic Warped/ variable thickness workpeice compensation
- geo01005
26 Jul 2014 11:17 #49160
by geo01005
Ok, that doesn't look to hard. Where is the most "official" place to get the probekins code? I didn't find it on the Linux cnc gig repository.
26 Jul 2014 17:39 #49166
I think here: git.mah.priv.at/gitweb?p=emc2-dev.git;a=...507e9820146e36eb7a0f
Time to create page: 0.079 seconds
