Probe settings
- WhoKnow
02 Aug 2014 14:18 #49433
by WhoKnow
Probe settings was created by WhoKnow
I'm very new to LinuxCNC.
I have managed to get my probe working with the smartprobe.ngc routine.
What I don't know, is how to set the dimensions for the probe e,g if I have an object that I want to probe that is roughly about 100mm x 250mm, where do I let the probe routine know that?
Thanks.
Thanks.
- BigJohnT
- Thank you received: 1176
02 Aug 2014 20:01 #49436
by BigJohnT
Replied by BigJohnT on topic Probe settings
The first few lines of smartprobe.ngc are the start location, the distance between each probe and the number of probes. So you will need to do a bit of simple math to determine the counts.
JT
JT
- WhoKnow
03 Aug 2014 11:33 #49459
by WhoKnow
Replied by WhoKnow on topic Probe settings
Thanks John. I were able to change the X and Y diameters to what I need.
But now I keep on getting the error message "Probe is already tripped when starting G38.2 or G38.3 move" . This happens when the probe goes down until it touches the subject.
Any suggestions on how to fix it?
Thanks.
Thanks.
- cncbasher
- Thank you received: 288
03 Aug 2014 17:01 #49462
by cncbasher
Replied by cncbasher on topic Probe settings
this can be a number of things , but i have found most to be causes of either interference or the probe is inverted
have you used screened cable to the probe ? , one other probable solution is to add a debounce to the pin in your hal file
- WhoKnow
03 Aug 2014 17:35 #49463
by WhoKnow
thanks for the help. I really appreciate your suggestions.
I changed to the mm version of smartprobe, and played around with the config settings in the file. Everything is working now.
It's working really awesome.
Time to create page: 0.207 seconds
