How to stop spindle 3 mm before end of the line ?
- Nick
- Thank you received: 15
18 Sep 2014 14:19 #51303
by Nick
Replied by Nick on topic How to stop spindle 3 mm before end of the line ?
What does this line do?
M68 E0 Q323.36218
and here
M64 P0
M68 E0 Q323.36218
G4 P0.1
M65 P0
you turn on the spindle, wait 0.1sec and turn it off?
M68 E0 Q323.36218
and here
M64 P0
M68 E0 Q323.36218
G4 P0.1
M65 P0
- Woj123
18 Sep 2014 17:42 - 18 Sep 2014 17:53 #51304
by Woj123
Replied by Woj123 on topic How to stop spindle 3 mm before end of the line ?
M68 E0 Q323.36218 - that line do nothing
Pump starts after M65 P0 ( but only when starts move ) , so if we do G04 P0.5 after M65 P0 pump will wait 0.5s ( the pump starts with the movement)
what I need is:
1.pump starts ( no move )
2. G04 P0.5 ( wait a bit)
3 move ( drawing a line)
thanks for help
what I need is:
thanks for help
Last edit: 18 Sep 2014 17:53 by Woj123.
- BigJohnT
- Thank you received: 1176
18 Sep 2014 22:53 #51309
by BigJohnT
Replied by BigJohnT on topic How to stop spindle 3 mm before end of the line ?
Just move a tiny amount to start the pump like 0.000001.
JT
JT
- Nick
19 Sep 2014 16:07 #51334
by Nick
That looks very strange!
Immediate digital out should turn on immediate not only when the movement starts...
- Woj123
19 Sep 2014 16:43 #51337
by Woj123
Nick,
Can you check my "hal" files - mayby there is something wrong
- Nick
19 Sep 2014 17:40 #51339
by Nick
I think the problem is somewhere here:
net len => sum2.0.in0
net max <= sum2.0.out
net max => wcomp.0.max
because when we reset integ, it will be = 0 and it can be not inside wcomp's window.
You can try to define wcomp's min to some value...
change this
net min => wcomp.0.min
net min => sum2.0.in1
setp sum2.0.gain1 -1
to
setp wcomp.0.min -1
setp sum2.0.in1 -1
change this
to
setp wcomp.0.min -1
setp sum2.0.in1 -1
- Woj123
26 Sep 2014 17:51 #51591
by Woj123
Nick,
today I have checked all one more time agine ( with very slow speed)
I set min to 3 mm
After
G01 Z1.500000 F100.0(Penetrate)
I put for instance:
M64 P0
M68 E0 Q323.36218
G4 P2
M65 P0
so maschine is going to Z1.5mm , than waiting 2 seconds than starts moving ,THAN AFTER 3 MM PUMP IS TURNNIG ON than 3 mm before end of the line is turnning off.
Is there any way to turn pump on when maschine goes to Z1.5 mm?
Thanks for help
I set min to 3 mm
After
I put for instance:
M64 P0
M68 E0 Q323.36218
G4 P2
M65 P0
Thanks for help
- Nick
01 Oct 2014 18:43 #51708
by Nick
Have you tried what I've posted just before?
just try to replace
to
setp wcomp.0.min 0
just try to replace
to
setp wcomp.0.min 0
The following user(s) said Thank You: Woj123
- Woj123
01 Oct 2014 18:49 #51709
by Woj123
As you told me I did :
setp wcomp.0.min -1
but there was some "debug" problem
setp wcomp.0.min -1
- Nick
01 Oct 2014 19:10 #51711
by Nick
what problem exactly?
post the whole error (inside tag code )
Time to create page: 0.069 seconds
