Digital readout from magnetic or glass scales
- Jake
- Thank you received: 10
26 Nov 2014 19:49 - 26 Nov 2014 19:52 #53437
by Jake
Replied by Jake on topic Digital readout from magnetic or glass scales
I had originally thought I needed to buy interface cards,
But after you and some others mentioning that TTL signals can go right a to a parallel port with no additional hardware I thought that would be the simpler and less expensive route to go.
But I can go buy interface cards if need be for simplicity. I wanted to wait on buying the cards since I have not aquired a mill that I want to retrofit yet, I want to be able to buy the hardware that could possibly work with existing encoders, and servos. (I am hoping to work out a deal on a Servo SAM7 we have at work when they replace it next year with a HMC)
I started to go down that road to figure out what it would take to connect the 4 scales to the PC through the parallel port. Which is where I came up with my last post.
Sorry for making your head hurt on this! As you can see computer control logic is not my strong suit. I am an electrician and used to large industrial systems, as the instrument and control guys typically have to deal with this level. I can get a 7000 hp electric motor to run, but a controlling a little servo motor is handing me my .....
Thanks again Andy!
Where is the LinuxCNC for dummies book at???????
Thanks again Andy!
Last edit: 26 Nov 2014 19:52 by Jake. Reason: deedadee
- Thank you received: 4997
26 Nov 2014 19:55 #53438
Ah, in that case you don't need a clock signal. Just the two AB lines into the p-port and from there to a HAL encoder counter.
However you _might_ still need an interface card, depending on the speed at which you can wind the handles and how many pulses per mm the scales put out.
Software encoder counting on the parport tops out at about 20kHz. If you are seeing quadrature pulses faster than that then you would need an interface card of some sort.
Replied by andypugh on topic Digital readout from magnetic or glass scales
The following user(s) said Thank You: Jake
- Jake
26 Nov 2014 20:31 #53439
by Jake
Ok cool,
With 5 micron scales it looks like 12 inches per minute puts me at 20kHz which I think my feeds can only run 9"
So Pport connections should be
A, B (X) to Data 0, 1
A, B (Y) to Data 2, 3
A, B (Z) to Data 4, 5
A, B (W) to Data 6, 7
Then the HAL encoder counter is the software portion correct? I need some more caffeine this morning!
- DaBit
- Thank you received: 35
26 Nov 2014 20:45 #53441
by DaBit
Replied by DaBit on topic Digital readout from magnetic or glass scales
Although not quite a robust industrial solution one can interface TTL-level scales such as Sino and Ditron are selling directly to the parallel port. I setup my first experiments like this and it worked flawless at the maximumspeed of 3 meters/minute that the axis could do.
You are correct regarding the wiring (A,B to data 0/1, etc.). The 5V power supply for the scales can be obtained from an unused USB port.
Once you have hooked it up, do not forget to put the parallel port in input mode while loading the 'parport' component. But we'll discuss that when you are ready for that. Small steps at a time.
- Jake
26 Nov 2014 20:52 #53442
by Jake
Awesome,
More to continue when my parallel to PCI card gets here and my scales. I did buy Ditron scales, the price was right and I have not found really any bad info about them yeah there not Heidenhain or Mitutoyo's but I got 6 of them for what I would have paid for one of those ones.
Thanks again for putting up with me!
- DaBit
26 Nov 2014 21:12 #53444
by DaBit
I am using Ditron 1um scales on my machine. Except that one scale does not produce index pulses they work fine and seem quite accurate.
26 Nov 2014 21:23 - 26 Nov 2014 21:24 #53445
Yes, assuming that those parport pins have the right direction.
Indeed.
A very simple config for a DRO would be to save this HAL code as a dro.hal then open a terminal on a LinuxCNC computer and run the command
dro.hal
This is typed from memory, so don't expect it to work first time.
It sets up a very basic HAL session, loads the parport driver and some encoders. makes the connections then opens a set of 4 halmeter indicators.
This is very basic, there is no way to tell which axis is which, and no way to zero an axis or set a value.
For those functions a simple GladeVCP panel could be used, potentially with a touchscreen and pop-up keyboard.
(I quite like the idea of writing that, if you don't).
it's a slight pity that you already ordered a PCI parallel port card, for $80 you could have ordered a mesa 5i25 which looks exactly like a parallel port card but can count encoders at 10Mhz rather than 20kHz.
Indeed.
halrun -I -f dro.hal
dro.hal
loadrt encoder num_chan=3
loadrt hal_parport cfg="0"
loadrt threads name1=base-thread period1=50000 name2=servo-thread period2=1000000
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
net xa parport.0.pin-00-in => encoder.0.phase-A
net xb parport.0.pin-01-in => encoder.0.phase-B
net ya parport.0.pin-02-in => encoder.1.phase-A
net yb parport.0.pin-03-in => encoder.1.phase-B
net za parport.0.pin-04-in => encoder.2.phase-A
net zb parport.0.pin-05-in => encoder.2.phase-B
net wa parport.0.pin-06-in => encoder.3.phase-A
net wb parport.0.pin-07-in => encoder.3.phase-B
setp encoder.0.scale 5080
setp encoder.1.scale 5080
setp encoder.2.scale 5080
setp encoder.3.scale 5080
loadusr halmeter -s -pin encoder.0.position
loadusr halmeter -s -pin encoder.1.position
loadusr halmeter -s -pin encoder.2.position
loadusr halmeter -s -pin encoder.3.position
start
Last edit: 26 Nov 2014 21:24 by andypugh.
- Jake
26 Nov 2014 22:27 #53449
by Jake
I didn't get a chance to order that card this morning so I will just get one of the Mesa cards instead!
26 Nov 2014 22:31 #53450
OK, that will significantly change the HAL code I wrote above, though the principle stays the same.
For lots of encoders get the 7i77 firmware option. (though it is reasonably easy to swap firmwares)
- Jake
26 Nov 2014 22:50 #53452
by Jake
