Swapping Axis Direction
- GaryLa
16 Aug 2014 01:12 #49897
by GaryLa
Swapping Axis Direction was created by GaryLa
I wish to swap the direction of an axis. I am using a stepper configuration.
So far, my searches have yielded the suggestion to change the standard_pinout.hal file. My concern is with the pin "descriptions".
Does inverting it change the how the hardware is driven (open-collector, tri-state, whatever) or simply change the software's writing of it for directional purposes?
I tried using both positive and negative values for INPUT_SCALE as loosely suggested elsewhere but that made no difference.
- Thank you received: 5230
16 Aug 2014 01:38 #49899
Replied by PCW on topic Swapping Axis Direction
changing the sign of OUTPUT_SCALE should do what you want
If its a parallel port system you can also change the polarity of the direction output
(with the appropiate out-invert parameter)
- GaryLa
16 Aug 2014 02:20 #49901
by GaryLa
Replied by GaryLa on topic Swapping Axis Direction
Thanks for the response. It is a parallel port system: Sherline.
I have not found the appropriate syntax to invert this signal. I don't want to change the way the hardware is driven. I haven't yet found the way to simply invert the software's view of the signal.
I don't have an OUTPUT_SCALE parameter in this INI file. Its basis is the Sherline INI. It's horribly wrong, I know, but I'm trying to go slowly and not change too many things at once.
Originally, it had "SCALE = 16000". But EMC2 didn't like that and reported an error. I changed that to INPUT_SCALE = 16000.
16 Aug 2014 02:58 #49903
setp parport.0.pin-<yourpin#here>-out-invert true
www.linuxcnc.org/docs/2.4/html/hal_parallel_port.html
The following user(s) said Thank You: GaryLa
- GaryLa
16 Aug 2014 03:05 #49905
by GaryLa
Thanks again. I knew that it was going to be something like that, I have just been trying to figure out where it goes.
I'm just now getting my head around these files. I wanted to be sure it got placed in an area where it wouldn't get overidden by a subsequent statement.
Maybe that's not even possible?
- BigJohnT
- Thank you received: 1176
19 Aug 2014 04:37 #50023
by BigJohnT
If you try and set the same pin twice LinuxCNC complains loudly and refuses to run.
JT
Replied by BigJohnT on topic Swapping Axis Direction
JT
Time to create page: 0.056 seconds
