Global Parameters XYZ are "non existent" ?
- GaryLa
17 Aug 2014 06:20 #49954
by GaryLa
Global Parameters XYZ are "non existent" ? was created by GaryLa
Section 7.3 states: "Printing the value of a non-existent named parameter with a DEBUG statement - like (DEBUG, #<no_such_parameter>) will display the string ######."
I'm using the statement: (debug,X=#<_x> Y=#<_y> Z=#<_z>)
and getting the display:
X=###### Y=###### Z=######
Shouldn't this at least show zeroes?
- GaryLa
17 Aug 2014 06:44 #49957
by GaryLa
Replied by GaryLa on topic Global Parameters XYZ are "non existent" ?
I think I can answer my own question with "They haven't been homed".
However, what's not clear is how I home them without moving them. I have no limit switches and I'm moving from manual to CNC...
Therefore, I simply set XYZ into a known position and wish to program gcode from there. I used:
#<_x> = 0
#<_y> = 0
#<_z> = 0
which works, but I feel this is probably not the right way to do this.
#<_x> = 0
#<_y> = 0
#<_z> = 0
- ArcEye
- Thank you received: 758
17 Aug 2014 13:28 - 17 Aug 2014 15:59 #49961
by ArcEye
Replied by ArcEye on topic Global Parameters XYZ are "non existent" ?
Hi
If you don't have homing switches, you can still 'home', you just have to alter your ini file.
If you set each axis SEARCH_VEL and LATCH_VEL to 0, the axes will not move when the Home button is pressed and the current position is set to machine zero.
Set HOME_SEQUENCE to 0 for each axis and all 3axes will home together.
www.linuxcnc.org/docs/html/config/ini_co...tml#sub:AXIS-section
I have a small mill I mostly use for engraving that I home like this against datum marks.
It works perfectly well.
Last edit: 17 Aug 2014 15:59 by ArcEye.
The following user(s) said Thank You: GaryLa
- joekline9
- Thank you received: 14
18 Aug 2014 04:26 #49978
by joekline9
Replied by joekline9 on topic Global Parameters XYZ are "non existent" ?
I do as ArcEye says above.
I have index marks on the machine and the dials.
Before I shut down I do "G53 G0 X0 Y0 Z0.
When I start the next time I check to see I'm on the marks, click <Home> (nothing moves) and we are ready to go.
Time to create page: 0.048 seconds
