HELP
- nissjay
19 Aug 2014 17:25 #50049
by nissjay
HELP was created by nissjay
Hi Everyone,
I have written a small 3 axis g code program by using gedit (please refer the attachment file). program is running with linux cnc without any problem but I can not change the speed of the tool path
as I tried feed rate from F 100 to F 1100 but the tool running same speed every time.What am I doing wrong? Please someone let me know how to do it properly.
I step config 3 axis and opened up the program and gcode file with gedit delet the file content and write my g code is that ok or not ?
- Rick G
- Thank you received: 155
19 Aug 2014 17:37 #50052
by Rick G
Replied by Rick G on topic HELP
You might want to look here...
gnipsel.com/linuxcnc/g-code/
No file is attached.
What is the maximum speed your machine can move at? Is your machine set for metric or Imperial?
The maximum speed is set in your configuration files for each axis and also a maximum speed for combined axis moves.
If you set a very slow speed does the machine move slower.
www.linuxcnc.org/docs/devel/html/config/ini_config.html
Rick G
Rick G
Time to create page: 0.078 seconds
