System variable for current Z machine position
  • emcPT
  • emcPT's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Sep 2014 16:53 #50622 by emcPT
Hello
I am writing a subprogram to suit my machine and I need to get the current Z machine position.
Looking at:
linuxcnc.org/docs/html/gcode/overview.html, I would use:
#<_z> - Return current machine Z coordinate. Same as #5422.
I tested using 5022 or 5422, but both return the actual relative position, not the machine position that I am looking for.
Would this be a bug or am I looking at the wrong variable?
I am using a custom 2.6 pre
Thank you
02 Sep 2014 17:42 #50623 by ArcEye
Hi
I think it is a case of imprecise phraseology
5420-5428
Current Position including all offsets and in the current program units for X, Y, Z, A, B, C, U, V & W, volatile.
5422 returns the current relative position in the active co-ordinate system I believe, so it definately does not return machine position despite
what this says
I have never needed to access actual machine position from gcode and was rather surprised to find there was no set of parameters for it,
unless I too cannot see them.
You can get machine position programmatically from halui.axis.n.pos-commanded (float, out) - Commanded axis position in machine coordinates
but that does not assist you much.
One way would be to touch off one of the co-ordinate systems to 0,0,0 at home and then it will mirror machine position and you can use that
The following user(s) said Thank You: emcPT
  • emcPT
  • Platinum Member
  • Platinum Member
02 Sep 2014 17:47 - 02 Sep 2014 17:56 #50624 by emcPT
Thank you,
I will wait a bit more to see if there is anyone using it (maybe it already exists). If not I will think about possible turnarounds but yours is quite good: "One way would be to touch off one of the co-ordinate systems to 0,0,0 at home and then it will mirror machine position and you can use that"
Last edit: 02 Sep 2014 17:56 by emcPT.
02 Sep 2014 17:49 #50625 by Rick G
  • emcPT
  • Platinum Member
  • Platinum Member
02 Sep 2014 17:55 #50626 by emcPT
Yes, my original post was related with that list, so no more relevant information there. Thank you anyway.
02 Sep 2014 18:59 #50627 by BigJohnT
Replied by BigJohnT on topic System variable for current Z machine position
Hi
5420-5428
what this says
The description is more precise now :)
JT
The following user(s) said Thank You: ArcEye
02 Sep 2014 19:10 #50629 by alan_3301
Replied by alan_3301 on topic System variable for current Z machine position
It would take a whole lot of if/thens but how about a subroutine to check #5210 and #5220 to check what offsets are active.
Then subtracting the correct parameter #5211 through #5219 or #5221 through #5390 from #5420 - #5428.
what do you think?
02 Sep 2014 19:12 #50630 by andypugh
Replied by andypugh on topic System variable for current Z machine position
A roundabout way to get machine absolute position is to perform a G30.1 then read #5183
www.linuxcnc.org/docs/html/gcode/gcode.html#sec:G30-G30_1
02 Sep 2014 19:39 #50631 by Rick G
I believe Chris used something like this to find X Y when looking for the center of a circle..
G91 G38.3 Z.00001
#1001=#5061
#1002=#5062
Or as Alan suggested if you know what coordinate system you are going to work in work with the parameter and the offset.
Rick G
  • emcPT
  • Platinum Member
  • Platinum Member
02 Sep 2014 19:46 #50632 by emcPT
This was the most straight forward method, so I believe I will use it.
Thank you
Time to create page: 0.107 seconds
