Help with connector name(s)
- Zahnrad Kopf
- Thank you received: 3
07 Sep 2014 00:10 #50854
by Zahnrad Kopf
Help with connector name(s) was created by Zahnrad Kopf
Can someone please tell me what the header ( and specifically - the required connector for it ) in this picture is called?
I'm looking for the 8 pin one in yellow.
I'm not very saavy with this stuff and need to order a connector for this but have no idea where to start or what it is called.
Alternatively, if someone can tell me where they might be used, I could even snip one off of something else and have it come with a ready to be wired pigtail.
Thanks.
Thanks.
- BigJohnT
- Thank you received: 1176
07 Sep 2014 01:54 #50862
by BigJohnT
Replied by BigJohnT on topic Help with connector name(s)
If you have any old motherboards around I'd bet you can find a connector to fit that. It looks like a front audio connector.
JT
JT
- Zahnrad Kopf
07 Sep 2014 02:43 - 07 Sep 2014 02:46 #50865
by Zahnrad Kopf
John, you are a rock star!
Compaq part number 245151-001 will suffice. It's a 10 pin connector used for front panel USB ports, but fits this 8 pin header just fine and by moving one wire I can use it as a pre wired pigtail.
Thank you again, John!
EDIT - and with John's tip, I went searching and found this -
www.ebay.com/itm/8-pin-female-to-8-pin-f...&hash=item5d273f718c
Replied by Zahnrad Kopf on topic Help with connector name(s)
JT
Last edit: 07 Sep 2014 02:46 by Zahnrad Kopf.
Time to create page: 0.046 seconds
