Search for Support in Berlin. Pay for it.
07 Sep 2014 18:09 #50880 by GeorgeL
Hello everybody,
i am new in the part of LinuxCNC. I have a CNC-Machine and LinuxCNC installed. But the configuration with the axes i do not know how to fixe, everytime if i will drive the maschine the program say i am out of the z-zone.
I am living in Berlin. I search for someone who live here too. I need help to fixe the configuration dirctly by my maschine. I will pay for it.
Please contact me.
Best
Joerg
07 Sep 2014 19:42 #50882 by cncbasher
Replied by cncbasher on topic Search for Support in Berlin. Pay for it.
i can help with remote assistance and help if you have no other option
my details on on my profile , perhaps if you post an archive of your config directory
and give details of your machine. will help.
also give exact error or message on screen or post a screen capture , if your are unsure
07 Sep 2014 23:06 - 07 Sep 2014 23:07 #50890 by ArcEye
Replied by ArcEye on topic Search for Support in Berlin. Pay for it.
Hi
...............everytime if i will drive the maschine the program say i am out of the z-zone
This is quite common.
Either you have not got your soft limits set properly in your inii file
[AXIS_2]
MAX_LIMIT = 0.5
MIN_LIMIT= -100 (where 100mm is the extent of travel of the quill from home position)
or
Simply you have not touched off.
Because it is a new config, your var file will not have any figures in it for G54 etc, so they will be 0 the same as the machine position at homing
When you try to run a file that shows any elevation of the Z axis above 0 , it will error because it sees that you are at the max extent of your limits at 0 and cannot go any higher
Simply touching off at the workpiece and setting G54 to Z0 will cure that
Last edit: 07 Sep 2014 23:07 by ArcEye.
09 Sep 2014 00:40 #50960 by GeorgeL
Replied by GeorgeL on topic Search for Support in Berlin. Pay for it.
Hello,
thank you very much for this information.
I have to be check this intensiv and slowly, because all is new for me.
Regards
George
Time to create page: 0.053 seconds
