color coded text editor
17 Sep 2014 01:48 #51244 by JRied
color coded text editor was created by JRied
Hey guys... new user... but I really like the program.
We switched from Ubuntu to Debian and now the text editor no longer has those fancy colors to tell me if I have entered a coordinate (pink) a parameter (blue) or whatever.
Is there a way in the new software (mousepad) to change this?
Thanks in advance
17 Sep 2014 05:56 #51248 by andypugh
Replied by andypugh on topic color coded text editor
It doesn't seem that mousepad supports syntax-highlighting. I think you may need to install a different text editor if you want that feature.
gedit seems to be available, and is known to work. (if you find the highlighting to be strange for G-code then there is a better scheme available at cnclub.ru)
The following user(s) said Thank You: JRied
17 Sep 2014 13:38 #51259 by ArcEye
Replied by ArcEye on topic color coded text editor
Hi
sudo apt-get install gedit gedit-plugins
will get you back to the way you were with Ubuntu
A couple of the plugins are only in the jessie repo, depends what you use as to whether you need to backport it.
There are a few highlighting schemes for gcode, including the one Andy linked to
17 Sep 2014 22:05 - 17 Sep 2014 22:07 #51272 by ArcEye
Last edit: 17 Sep 2014 22:07 by ArcEye.
Time to create page: 0.054 seconds
