need a linuxcnc with 4 linear axis for 3d printing
- James
18 Sep 2014 00:36 #51278
by James
need a linuxcnc with 4 linear axis for 3d printing was created by James
I have been running linuxcnc for about a year as a 3d printer driver. I have used the rotary A axis for the extruder and configured it to work but not without issues. My "work arounds" are not cutting it anymore as my printed parts are getting larger. I now have a problem with not being able to zero out the A axis when I start a new print. I have seen where others have been able to get linuxcnc to have the 4th axis be linear but I am still stuck with a rotary 4th axis. Could some one please help me? I am using a xylotex stepper driver system, (open loop steppers). Hopefully somebody already has what I need and can send or point me to an easy load or install type solution. Thank you for any help with this.
- JoeHildreth
- Thank you received: 14
18 Sep 2014 01:14 #51280
by JoeHildreth
Replied by JoeHildreth on topic need a linuxcnc with 4 linear axis for 3d printing
What do you mean you cannot zero out the A-Axis? Do you mean you cannot home it, or you cannot get the display to read 0 degrees?
Couldn't you use a match mark and home to that, or am I not understanding your problem?
Joe
Joe
- Thank you received: 5230
18 Sep 2014 01:20 #51281
Replied by PCW on topic need a linuxcnc with 4 linear axis for 3d printing
I notice some people have dispensed with the idea of a motion axis
for the extruder and instead use the print head velocity:
basdebruijn.com/2014/05/machinekit-and-additive-manufacturing/
To me this seems like a better way to go
The following user(s) said Thank You: Doogie
- James
18 Sep 2014 02:54 #51285
by James
Replied by James on topic need a linuxcnc with 4 linear axis for 3d printing
I can home the machine and it will show on the preview display that the A axis is at zero. When I try to start a new print it starts my A axis runnng backwards. I guess the rotary axis is trying to move back to what it thinks is zero. I have tried using G92 A0 to fix this but I have found that this does not work with very large prints with gcodes of about 8meg or bigger. 3D printer gcodes can be very large.
- James
18 Sep 2014 03:04 #51286
by James
I saw this page before but I really want to not have to change the slic3r data. Really what I need is the XYZ and A axis to all be linear. If I can get that I believe linuxcnc would be much better for driving my 3D printer.
Time to create page: 0.065 seconds
