Concave corners
- Fordgalaxy
25 Sep 2014 22:25 #51563
by Fordgalaxy
Concave corners was created by Fordgalaxy
Has the concave corner gouging issue in the earlier versions been resolved?
- ArcEye
- Thank you received: 758
25 Sep 2014 23:27 #51566
by ArcEye
Replied by ArcEye on topic Concave corners
Hi
You will have to specify what you mean.
All the recent reports of gouging errors I have seen, were from users who thought their code should not cause it, but had overlooked the exit path of the tool or similar.
If you have code that gives this error, you will need to post it so it can be tested
Time to create page: 0.047 seconds
