Moving config to new pc
07 Oct 2014 19:15 #51846 by Clive S
Moving config to new pc was created by Clive S
What config files do I need for moving my configuration to a new pc. I am just using axis with xyz and steppers and a PP.
I would like to port total config if possible. Thanks Clive
07 Oct 2014 19:47 #51849 by emcPT
Replied by emcPT on topic Moving config to new pc
I hope that I do not miss anything, but you need:
HAL file
INI file
Tooltable file
This is assuming that you did not add any panels, or if you only have a single HAL file.
07 Oct 2014 19:54 #51850 by Clive S
Replied by Clive S on topic Moving config to new pc
HAL file
INI file
Tooltable file
Thanks I did set up a new mill config with stepconfig and then copied the .ini and .hal files over into the (new mil)l directory and then renamed them to suite.
But when I viewed them with stepconfig it did not show how the pins were setup.
Am I missing something? Clive
07 Oct 2014 22:00 #51854 by BigJohnT
Replied by BigJohnT on topic Moving config to new pc
My guess is you opened up the old .stepconf file or an empty .stepconf file.
JT
07 Oct 2014 23:27 - 07 Oct 2014 23:29 #51858 by ArcEye
Replied by ArcEye on topic Moving config to new pc
All you need to do is copy your entire /home/yourname/linuxcnc folder onto a USB stick and copy it into your new home folder
The only problem you should get is if some hardware is different, eg the parport addresses are not the same
The base computer parport is universally 0x378, (sometimes 0x278), but a PCI card will have different port addresses in different machines,
even different linux distro versions, so needs checking carefully from the lspci -vv output
You don't need to use stepconf again, just put the hal file in an editor and change the port numbers in the
loadrt hal_parport line, if required
Last edit: 07 Oct 2014 23:29 by ArcEye.
Time to create page: 0.056 seconds
