10.04 installation with no internet access
- cmtunnel
- ArcEye
- Thank you received: 758
What is the USB adaptor?
They generally tend to be very problematic and are best avoided.
Apart from anything else, as soon as your CNC machine is running, the 'noise' from the motors and spindle will probably knock out the connection.
A very good alternative is two 'home-plugs' and a wired ethernet connection
Mine work 200 ft from the house and give me full speed broadband
- cmtunnel
beatofthegeek.com/2011/07/aptoncd-tutori...-to-backup-your.html
- ArcEye
The usb adapter is the hardware that plugs into the usb port and provides the pc with the wireless connection.
No s**t!
Does it have a maker and model number?
- cmtunnel
- ArcEye
You caught me at a bad moment
Will need to know the exact model.
Realtek can be horrors, the r8168 ethernet chip is a prime example.
They make stuff for wondoze and don't care if it works with anything else.
I still stand by my original recommendation, if possible just throw it in the bin and go for a wired solution
- cmtunnel
Now having trouble with ethernet drivers. Read something about vr driver that i think will work but cant find how to do it.
- ArcEye
. I am wondering if I should change the laptop over to 10.04? Will that make it easier to get files over to the other machine?
That is one way of updating, do the updates and get the new packages on an internet connected machine running the same version.
Then copy the packages to the other machine and install manually using dpkg.
Again, without the make and model, can't assist
- ArcEye
That man page was taken straight from the BSD one, not quite sure what the point of it is.
The drivers for Ubuntu 10.04 are on the Via website
download.viatech.com/en/support/driversSelect.jsp
They do however require building and installing by hand, there are about 5 different downloads, depending upon the model
- cmtunnel
Think I might change the online machine to 10.04 today.
Any info. or links for building & installing the drivers are greatly appreciated. If you know of any links that are step-by-step that would help alot............still trying to get in the groove with linux.
Thanks alot for your help
