Soft EStop randumly trips
- bnktaylor86
08 Nov 2014 04:47 #52923
by bnktaylor86
Soft EStop randumly trips was created by bnktaylor86
I have just installed the 2.6 Debian with LinuxCNC 2.6.4, the issue I am having is that randomly my soft estop trips. What could cause this?
- ArcEye
- Thank you received: 758
08 Nov 2014 15:36 #52936
by ArcEye
Replied by ArcEye on topic Soft EStop randumly trips
Hi
You need to attach your configs and tell us what your machine is.
Listing possible causes with no information will not be productive for anyone
- cncbasher
- Thank you received: 288
08 Nov 2014 17:59 #52938
by cncbasher
Replied by cncbasher on topic Soft EStop randumly trips
you dont mention what breakout or what the machine is , so i can only give a general responce .
this is mostly down to either poor wiring , or noise pickup on low voltage wiring .
look at using the debounce component , or suppression and screening of cables , or moving low voltage cables , away from areas such as mains or spindle motors
or vfd
this should give you enough , to be able to locate your problem
if not give us some more detailed information as to equipment , as suggested
or vfd
Time to create page: 0.167 seconds
