Video Issues
14 Nov 2014 20:57 - 14 Nov 2014 21:01 #53078 by jorsborn
Video Issues was created by jorsborn
I recently tried switching to the vesa driver to help with my latency issues (and it seems to have). That also seems to have affected my ability to run Linux CNC too. Axis and/or gmoccapy fail to load however I can use an interface like mini that doesn't depend on OpenGL. The funny thing is that glxgears runs just fine. Any ideas what is causing this? I tried to revert to my old X11 configuration file but that doesn't solve the problem. Besides, I want to stick with the vesa driver to keep my improved latency anyway.
I've included my X11 configuration file as well.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.4
Machine configuration directory is '/home/jorsborn/linuxcnc/configs/Router'
Machine configuration file is 'router.ini'
INIFILE=/home/jorsborn/linuxcnc/configs/Router/router.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
INFO CLASSICLADDER-   No ladder GUI requested-Realtime runs till HAL closes.
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=6685
Killing task milltask, PID=6736
xhc-hb04: waiting for XHC-HB04 device
xhc-hb04: found XHC-HB04 device
xhc-hb04: connection lost, cleaning up
[timestamp] [threadID] facility level [function call] <message>
Debug file information:
  File "/usr/bin/axis", line 3421, in <module>
    _dynamic_tabs(inifile)
  File "/usr/bin/axis", line 3267, in _dynamic_tabs
    child = Popen(cmd)
  File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1259, in _execute_child
    raise child_exception
OSError: [Errno 13] Permission denied
6685
  PID TTY      STAT   TIME COMMAND
6736
Stopping realtime threads
Unloading hal components
[ 0.000000] [00001a46] libusbx: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
[ 0.000077] [00001a46] libusbx: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
Kernel message information:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[    0.000000]  BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 00000000a7c39000 (usable)
[    0.000000]  BIOS-e820: 00000000a7c39000 - 00000000a7c8d000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000a7c8d000 - 00000000a7cae000 (reserved)
[    0.000000]  BIOS-e820: 00000000a7cae000 - 00000000a7cbf000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000a7cbf000 - 00000000a7cd5000 (reserved)
[    0.000000]  BIOS-e820: 00000000a7cd5000 - 00000000a7cd6000 (usable)
[    0.000000]  BIOS-e820: 00000000a7cd6000 - 00000000a7cd7000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000a7cd7000 - 00000000a7cd8000 (reserved)
[    0.000000]  BIOS-e820: 00000000a7cd8000 - 00000000a7cdf000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000a7cdf000 - 00000000a7d41000 (reserved)
[    0.000000]  BIOS-e820: 00000000a7d41000 - 00000000a7d84000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000a7d84000 - 00000000a7f00000 (usable)
[    0.000000]  BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec10000 - 00000000fec11000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed00000 - 00000000fed01000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed61000 - 00000000fed71000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed80000 - 00000000fed90000 (reserved)
[    0.000000]  BIOS-e820: 00000000fef00000 - 0000000100000000 (reserved)
[    0.000000]  BIOS-e820: 0000000100001000 - 0000000140000000 (usable)
[    0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[    0.000000] SMBIOS 2.6 present.
[    0.000000] DMI: System manufacturer System Product Name/E45M1-I DELUXE, BIOS 0504 05/23/2014
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[    0.000000] last_pfn = 0xa7f00 max_arch_pfn = 0x100000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF write-through
[    0.000000]   C0000-CEFFF write-protect
[    0.000000]   CF000-E7FFF uncachable
[    0.000000]   E8000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask F00000000 write-back
[    0.000000]   1 base 0A7F00000 mask FFFF00000 uncachable
[    0.000000]   2 base 0A8000000 mask FF8000000 uncachable
[    0.000000]   3 base 0B0000000 mask FF0000000 uncachable
[    0.000000]   4 base 0C0000000 mask FC0000000 uncachable
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] TOM2: 0000000140000000 aka 5120M
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] e820 update range: 00000000a7f00000 - 0000000100000000 (usable) ==> (reserved)
[    0.000000] found SMP MP-table at [c00fcd20] fcd20
[    0.000000] initial memory mapped : 0 - 01800000
[    0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[    0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[    0.000000]  0000000000 - 0000400000 page 4k
[    0.000000]  0000400000 - 0037400000 page 2M
[    0.000000]  0037400000 - 00377fe000 page 4k
[    0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[    0.000000] RAMDISK: 36532000 - 37291000
[    0.000000] ACPI: RSDP 000f0430 00024 (v02 ALASKA)
[    0.000000] ACPI: XSDT a7c82068 0004C (v01 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: FACP a7c884c8 000F4 (v04 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20120320/tbfadt-579)
[    0.000000] ACPI: DSDT a7c82140 06385 (v02 ALASKA    A M I 00000000 INTL 20051117)
[    0.000000] ACPI: FACS a7cdef80 00040
[    0.000000] ACPI: APIC a7c885c0 00062 (v03 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: MCFG a7c88628 0003C (v01 ALASKA    A M I 01072009 MSFT 00010013)
[    0.000000] ACPI: HPET a7c88668 00038 (v01 ALASKA    A M I 01072009 AMI  00000004)
[    0.000000] ACPI: SSDT a7c886a0 0168E (v02    AMD     ALIB 00000001 MSFT 04000000)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 1799MB HIGHMEM available.
[    0.000000] 887MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 377fe000
[    0.000000]   low ram: 0 - 377fe000
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x000377fe
[    0.000000]   HighMem  0x000377fe -> 0x000a7f00
[    0.000000] Movable zone start PFN for each node
[    0.000000] Early memory PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009d
[    0.000000]     0: 0x00000100 -> 0x000a7c39
[    0.000000]     0: 0x000a7cd5 -> 0x000a7cd6
[    0.000000]     0: 0x000a7d84 -> 0x000a7f00
[    0.000000] On node 0 totalpages: 687427
[    0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5032200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3949 pages, LIFO batch:0
[    0.000000]   Normal zone: 1744 pages used for memmap
[    0.000000]   Normal zone: 221486 pages, LIFO batch:31
[    0.000000]   HighMem zone: 3599 pages used for memmap
[    0.000000]   HighMem zone: 456617 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x00] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 0, version 33, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0xffffffff base: 0xfed00000
[    0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[    0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[    0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[    0.000000] Allocating PCI resources starting at a7f00000 (gap: a7f00000:38100000)
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[    0.000000] PERCPU: Embedded 17 pages/cpu @f77cf000 s48384 r0 d21248 u69632
[    0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 682052
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=42c31fa5-d404-436f-9ee4-203b139f2c32 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 radeon.modeset=0 nohalt isolcpus=1 noht radeon.modeset=0 isolcpus=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] allocated 5502848 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (000377fe:000a7f00)
[    0.000000] Memory: 2702288k/2751488k available (3495k kernel code, 47420k reserved, 1237k data, 416k init, 1840864k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff17000 - 0xfffff000   ( 928 kB)
[    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    0.000000]     vmalloc : 0xf7ffe000 - 0xff7fe000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf77fe000   ( 887 MB)
[    0.000000]       .init : 0xc14a0000 - 0xc1508000   ( 416 kB)
[    0.000000]       .data : 0xc1369d4a - 0xc149f480   (1237 kB)
[    0.000000]       .text : 0xc1000000 - 0xc1369d4a   (3495 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:2304 nr_irqs:512 16
[    0.000000] CPU 0 irqstacks, hard=f4406000 soft=f4408000
[    0.000000] Extended CMOS year: 2000
[    0.000000] Interrupt pipeline (release #3)
[    0.000000] spurious 8259A interrupt: IRQ7.
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] hpet clockevent registered
[    0.000000] Fast TSC calibration using PIT
[    0.004000] Detected 1650.042 MHz processor.
[    0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 3300.08 BogoMIPS (lpj=6600168)
[    0.000011] pid_max: default: 32768 minimum: 301
[    0.000086] Security Framework initialized
[    0.000094] AppArmor: AppArmor disabled by boot time parameter
[    0.000126] Mount-cache hash table entries: 512
[    0.000435] Initializing cgroup subsys cpuacct
[    0.000440] Initializing cgroup subsys memory
[    0.000454] Initializing cgroup subsys devices
[    0.000458] Initializing cgroup subsys freezer
[    0.000462] Initializing cgroup subsys net_cls
[    0.000465] Initializing cgroup subsys blkio
[    0.000476] Initializing cgroup subsys perf_event
[    0.000523] CPU: Physical Processor ID: 0
[    0.000526] CPU: Processor Core ID: 0
[    0.000530] mce: CPU supports 6 MCE banks
[    0.000704] ACPI: Core revision 20120320
[    0.007361] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.007731] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.047390] CPU0: AMD E-450 APU with Radeon(tm) HD Graphics stepping 00
[    0.152528] Performance Events: AMD PMU driver.
[    0.152537] ... version:                0
[    0.152541] ... bit width:              48
[    0.152544] ... generic registers:      4
[    0.152548] ... value mask:             0000ffffffffffff
[    0.152551] ... max period:             00007fffffffffff
[    0.152555] ... fixed-purpose events:   0
[    0.152558] ... event mask:             000000000000000f
[    0.164554] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.176539] CPU 1 irqstacks, hard=f4494000 soft=f4496000
[    0.176544] Booting Node   0, Processors  #1 Ok.
[    0.186503] Initializing CPU#1
[    0.189602] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.189657] Brought up 2 CPUs
[    0.189662] Total of 2 processors activated (6600.16 BogoMIPS).
[    0.190284] devtmpfs: initialized
[    0.190718] PM: Registering ACPI NVS region [mem 0xa7c39000-0xa7c8cfff] (344064 bytes)
[    0.190743] PM: Registering ACPI NVS region [mem 0xa7cae000-0xa7cbefff] (69632 bytes)
[    0.190751] PM: Registering ACPI NVS region [mem 0xa7cd6000-0xa7cd6fff] (4096 bytes)
[    0.190756] PM: Registering ACPI NVS region [mem 0xa7cd8000-0xa7cdefff] (28672 bytes)
[    0.190762] PM: Registering ACPI NVS region [mem 0xa7d41000-0xa7d83fff] (274432 bytes)
[    0.190942] dummy:
[    0.191047] NET: Registered protocol family 16
[    0.191405] ACPI: bus type pci registered
[    0.191505] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.191512] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.191516] PCI: Using MMCONFIG for extended config space
[    0.191520] PCI: Using configuration type 1 for base access
[    0.192626] bio: create slab <bio-0> at 0
[    0.192800] ACPI: Added _OSI(Module Device)
[    0.192805] ACPI: Added _OSI(Processor Device)
[    0.192809] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.192813] ACPI: Added _OSI(Processor Aggregator Device)
[    0.195258] ACPI: EC: Look up EC in DSDT
[    0.198448] ACPI: Executed 3 blocks of module-level executable AML code
[    0.204301] ACPI: Interpreter enabled
[    0.204317] ACPI: (supports S0 S3 S4 S5)
[    0.204361] ACPI: Using IOAPIC for interrupt routing
[    0.216730] ACPI: No dock devices found.
[    0.216743] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.217031] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.217516] pci_root PNP0A08:00: host bridge window [io  0x0000-0x0cf7]
[    0.217521] pci_root PNP0A08:00: host bridge window [io  0x0d00-0xffff]
[    0.217527] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[    0.217532] pci_root PNP0A08:00: host bridge window [mem 0x000c8000-0x000dffff]
[    0.217537] pci_root PNP0A08:00: host bridge window [mem 0xc0000000-0xffffffff]
[    0.217548] pci_root PNP0A08:00: ignoring host bridge window [mem 0x000c8000-0x000dffff] (conflicts with Video ROM [mem 0x000c0000-0x000ce1ff])
[    0.217606] PCI host bridge to bus 0000:00
[    0.217612] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7]
[    0.217617] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff]
[    0.217621] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[    0.217626] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xffffffff]
[    0.217645] pci 0000:00:00.0: [1022:1510] type 00 class 0x060000
[    0.217711] pci 0000:00:01.0: [1002:9806] type 00 class 0x030000
[    0.217728] pci 0000:00:01.0: reg 10: [mem 0xc0000000-0xcfffffff pref]
[    0.217740] pci 0000:00:01.0: reg 14: [io  0xf000-0xf0ff]
[    0.217753] pci 0000:00:01.0: reg 18: [mem 0xfeb00000-0xfeb3ffff]
[    0.217807] pci 0000:00:01.0: supports D1 D2
[    0.217835] pci 0000:00:01.1: [1002:1314] type 00 class 0x040300
[    0.217850] pci 0000:00:01.1: reg 10: [mem 0xfeb40000-0xfeb43fff]
[    0.217917] pci 0000:00:01.1: supports D1 D2
[    0.217971] pci 0000:00:04.0: [1022:1512] type 01 class 0x060400
[    0.218041] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[    0.218099] pci 0000:00:11.0: [1002:4391] type 00 class 0x010601
[    0.218128] pci 0000:00:11.0: reg 10: [io  0xf140-0xf147]
[    0.218144] pci 0000:00:11.0: reg 14: [io  0xf130-0xf133]
[    0.218159] pci 0000:00:11.0: reg 18: [io  0xf120-0xf127]
[    0.218174] pci 0000:00:11.0: reg 1c: [io  0xf110-0xf113]
[    0.218190] pci 0000:00:11.0: reg 20: [io  0xf100-0xf10f]
[    0.218205] pci 0000:00:11.0: reg 24: [mem 0xfeb4b000-0xfeb4b3ff]
[    0.218275] pci 0000:00:12.0: [1002:4397] type 00 class 0x0c0310
[    0.218297] pci 0000:00:12.0: reg 10: [mem 0xfeb4a000-0xfeb4afff]
[    0.218398] pci 0000:00:12.2: [1002:4396] type 00 class 0x0c0320
[    0.218427] pci 0000:00:12.2: reg 10: [mem 0xfeb49000-0xfeb490ff]
[    0.218528] pci 0000:00:12.2: supports D1 D2
[    0.218533] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[    0.218569] pci 0000:00:13.0: [1002:4397] type 00 class 0x0c0310
[    0.218591] pci 0000:00:13.0: reg 10: [mem 0xfeb48000-0xfeb48fff]
[    0.218692] pci 0000:00:13.2: [1002:4396] type 00 class 0x0c0320
[    0.218720] pci 0000:00:13.2: reg 10: [mem 0xfeb47000-0xfeb470ff]
[    0.218820] pci 0000:00:13.2: supports D1 D2
[    0.218824] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[    0.218860] pci 0000:00:14.0: [1002:4385] type 00 class 0x0c0500
[    0.218971] pci 0000:00:14.3: [1002:439d] type 00 class 0x060100
[    0.219081] pci 0000:00:14.4: [1002:4384] type 01 class 0x060401
[    0.219142] pci 0000:00:14.5: [1002:4399] type 00 class 0x0c0310
[    0.219163] pci 0000:00:14.5: reg 10: [mem 0xfeb46000-0xfeb46fff]
[    0.219268] pci 0000:00:15.0: [1002:43a0] type 01 class 0x060400
[    0.219356] pci 0000:00:15.0: supports D1 D2
[    0.219396] pci 0000:00:15.1: [1002:43a1] type 01 class 0x060400
[    0.219483] pci 0000:00:15.1: supports D1 D2
[    0.219531] pci 0000:00:16.0: [1002:4397] type 00 class 0x0c0310
[    0.219553] pci 0000:00:16.0: reg 10: [mem 0xfeb45000-0xfeb45fff]
[    0.219655] pci 0000:00:16.2: [1002:4396] type 00 class 0x0c0320
[    0.219684] pci 0000:00:16.2: reg 10: [mem 0xfeb44000-0xfeb440ff]
[    0.219784] pci 0000:00:16.2: supports D1 D2
[    0.219788] pci 0000:00:16.2: PME# supported from D0 D1 D2 D3hot
[    0.219826] pci 0000:00:18.0: [1022:1700] type 00 class 0x060000
[    0.219878] pci 0000:00:18.1: [1022:1701] type 00 class 0x060000
[    0.219928] pci 0000:00:18.2: [1022:1702] type 00 class 0x060000
[    0.219980] pci 0000:00:18.3: [1022:1703] type 00 class 0x060000
[    0.220040] pci 0000:00:18.4: [1022:1704] type 00 class 0x060000
[    0.220089] pci 0000:00:18.5: [1022:1718] type 00 class 0x060000
[    0.220138] pci 0000:00:18.6: [1022:1716] type 00 class 0x060000
[    0.220187] pci 0000:00:18.7: [1022:1719] type 00 class 0x060000
[    0.220342] pci 0000:01:00.0: [9710:9900] type 00 class 0x070103
[    0.220367] pci 0000:01:00.0: reg 10: [io  0xe010-0xe017]
[    0.220385] pci 0000:01:00.0: reg 14: [io  0xe000-0xe007]
[    0.220403] pci 0000:01:00.0: reg 18: [mem 0xfea01000-0xfea01fff]
[    0.220447] pci 0000:01:00.0: reg 24: [mem 0xfea00000-0xfea00fff]
[    0.220521] pci 0000:01:00.0: PME# supported from D3hot D3cold
[    0.228480] pci 0000:00:04.0: PCI bridge to [bus 01-01]
[    0.228490] pci 0000:00:04.0:   bridge window [io  0xe000-0xefff]
[    0.228496] pci 0000:00:04.0:   bridge window [mem 0xfea00000-0xfeafffff]
[    0.228584] pci 0000:00:14.4: PCI bridge to [bus 02-02] (subtractive decode)
[    0.228600] pci 0000:00:14.4:   bridge window [io  0x0000-0x0cf7] (subtractive decode)
[    0.228605] pci 0000:00:14.4:   bridge window [io  0x0d00-0xffff] (subtractive decode)
[    0.228610] pci 0000:00:14.4:   bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[    0.228615] pci 0000:00:14.4:   bridge window [mem 0xc0000000-0xffffffff] (subtractive decode)
[    0.228719] pci 0000:03:00.0: [168c:002b] type 00 class 0x028000
[    0.228754] pci 0000:03:00.0: reg 10: [mem 0xfe900000-0xfe90ffff 64bit]
[    0.228877] pci 0000:03:00.0: supports D1
[    0.228881] pci 0000:03:00.0: PME# supported from D0 D1 D3hot D3cold
[    0.236470] pci 0000:00:15.0: PCI bridge to [bus 03-03]
[    0.236483] pci 0000:00:15.0:   bridge window [mem 0xfe900000-0xfe9fffff]
[    0.236593] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[    0.236620] pci 0000:04:00.0: reg 10: [io  0xd000-0xd0ff]
[    0.236662] pci 0000:04:00.0: reg 18: [mem 0xd0004000-0xd0004fff 64bit pref]
[    0.236691] pci 0000:04:00.0: reg 20: [mem 0xd0000000-0xd0003fff 64bit pref]
[    0.236764] pci 0000:04:00.0: supports D1 D2
[    0.236768] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.244464] pci 0000:00:15.1: PCI bridge to [bus 04-04]
[    0.244474] pci 0000:00:15.1:   bridge window [io  0xd000-0xdfff]
[    0.244487] pci 0000:00:15.1:   bridge window [mem 0xd0000000-0xd00fffff 64bit pref]
[    0.244517] pci_bus 0000:00: on NUMA node 0
[    0.244524] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.244908] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PE20._PRT]
[    0.244991] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PE21._PRT]
[    0.245118] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR14._PRT]
[    0.245191]  pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[    0.257756] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 7 10 11 14 15) *0
[    0.257917] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 7 10 11 14 15) *0
[    0.258078] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 7 10 11 14 15) *0
[    0.258237] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 7 10 11 14 15) *0
[    0.258370] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 7 10 11 14 15) *0
[    0.258480] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 7 10 11 14 15) *0
[    0.258572] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 7 10 11 14 15) *0
[    0.258679] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 7 10 11 14 15) *0
[    0.258849] vgaarb: device added: PCI:0000:00:01.0,decodes=io+mem,owns=io+mem,locks=none
[    0.258875] vgaarb: loaded
[    0.258879] vgaarb: bridge control possible 0000:00:01.0
[    0.258938] PCI: Using ACPI for IRQ routing
[    0.270293] PCI: pci_cache_line_size set to 64 bytes
[    0.270440] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[    0.270445] reserve RAM buffer: 00000000a7c39000 - 00000000a7ffffff
[    0.270450] reserve RAM buffer: 00000000a7cd6000 - 00000000a7ffffff
[    0.270456] reserve RAM buffer: 00000000a7f00000 - 00000000a7ffffff
[    0.270728] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.270739] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.272783] Switching to clocksource hpet
[    0.272936] pnp: PnP ACPI init
[    0.272957] ACPI: bus type pnp registered
[    0.273268] pnp 00:00: [bus 00-ff]
[    0.273274] pnp 00:00: [io  0x0cf8-0x0cff]
[    0.273279] pnp 00:00: [io  0x0000-0x0cf7 window]
[    0.273283] pnp 00:00: [io  0x0d00-0xffff window]
[    0.273288] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[    0.273293] pnp 00:00: [mem 0x000c8000-0x000dffff window]
[    0.273297] pnp 00:00: [mem 0xc0000000-0xffffffff window]
[    0.273302] pnp 00:00: [mem 0x00000000 window]
[    0.273403] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[    0.273481] pnp 00:01: [mem 0xe0000000-0xefffffff]
[    0.273563] system 00:01: [mem 0xe0000000-0xefffffff] has been reserved
[    0.273570] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.274690] pnp 00:02: [io  0x040b]
[    0.274695] pnp 00:02: [io  0x04d6]
[    0.274699] pnp 00:02: [io  0x0c00-0x0c01]
[    0.274703] pnp 00:02: [io  0x0c14]
[    0.274706] pnp 00:02: [io  0x0c50-0x0c51]
[    0.274710] pnp 00:02: [io  0x0c52]
[    0.274714] pnp 00:02: [io  0x0c6c]
[    0.274717] pnp 00:02: [io  0x0c6f]
[    0.274721] pnp 00:02: [io  0x0cd0-0x0cd1]
[    0.274725] pnp 00:02: [io  0x0cd2-0x0cd3]
[    0.274729] pnp 00:02: [io  0x0cd4-0x0cd5]
[    0.274733] pnp 00:02: [io  0x0cd6-0x0cd7]
[    0.274737] pnp 00:02: [io  0x0cd8-0x0cdf]
[    0.274741] pnp 00:02: [io  0x0800-0x089f]
[    0.274745] pnp 00:02: [io  0x0000-0xffffffff disabled]
[    0.274749] pnp 00:02: [io  0x0000-0x000f]
[    0.274753] pnp 00:02: [io  0x0b20-0x0b3f]
[    0.274757] pnp 00:02: [io  0x0900-0x090f]
[    0.274761] pnp 00:02: [io  0x0910-0x091f]
[    0.274768] pnp 00:02: [io  0xfe00-0xfefe]
[    0.274772] pnp 00:02: [io  0x0060-0x005f disabled]
[    0.274777] pnp 00:02: [io  0x0064-0x0063 disabled]
[    0.274781] pnp 00:02: [mem 0xfec00000-0xfec00fff]
[    0.274785] pnp 00:02: [mem 0xfee00000-0xfee00fff]
[    0.274790] pnp 00:02: [mem 0xfed80000-0xfed8ffff]
[    0.274794] pnp 00:02: [mem 0xfed61000-0xfed70fff]
[    0.274798] pnp 00:02: [mem 0xfec10000-0xfec10fff]
[    0.274802] pnp 00:02: [mem 0xfed00000-0xfed00fff]
[    0.274807] pnp 00:02: [mem 0xffc00000-0xffffffff]
[    0.274927] system 00:02: [io  0x040b] has been reserved
[    0.274933] system 00:02: [io  0x04d6] has been reserved
[    0.274939] system 00:02: [io  0x0c00-0x0c01] has been reserved
[    0.274944] system 00:02: [io  0x0c14] has been reserved
[    0.274949] system 00:02: [io  0x0c50-0x0c51] has been reserved
[    0.274954] system 00:02: [io  0x0c52] has been reserved
[    0.274959] system 00:02: [io  0x0c6c] has been reserved
[    0.274964] system 00:02: [io  0x0c6f] has been reserved
[    0.274969] system 00:02: [io  0x0cd0-0x0cd1] has been reserved
[    0.274975] system 00:02: [io  0x0cd2-0x0cd3] has been reserved
[    0.274980] system 00:02: [io  0x0cd4-0x0cd5] has been reserved
[    0.274985] system 00:02: [io  0x0cd6-0x0cd7] has been reserved
[    0.274990] system 00:02: [io  0x0cd8-0x0cdf] has been reserved
[    0.274996] system 00:02: [io  0x0800-0x089f] has been reserved
[    0.275001] system 00:02: [io  0x0b20-0x0b3f] has been reserved
[    0.275006] system 00:02: [io  0x0900-0x090f] has been reserved
[    0.275012] system 00:02: [io  0x0910-0x091f] has been reserved
[    0.275017] system 00:02: [io  0xfe00-0xfefe] has been reserved
[    0.275024] system 00:02: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.275030] system 00:02: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.275036] system 00:02: [mem 0xfed80000-0xfed8ffff] has been reserved
[    0.275041] system 00:02: [mem 0xfed61000-0xfed70fff] has been reserved
[    0.275047] system 00:02: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.275052] system 00:02: [mem 0xfed00000-0xfed00fff] has been reserved
[    0.275058] system 00:02: [mem 0xffc00000-0xffffffff] has been reserved
[    0.275064] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.275330] pnp 00:03: [io  0x0000-0xffffffff disabled]
[    0.275335] pnp 00:03: [io  0x0300-0x031f]
[    0.275339] pnp 00:03: [io  0x0290-0x029f]
[    0.275343] pnp 00:03: [io  0x0230-0x023f]
[    0.275423] system 00:03: [io  0x0300-0x031f] has been reserved
[    0.275429] system 00:03: [io  0x0290-0x029f] has been reserved
[    0.275434] system 00:03: [io  0x0230-0x023f] has been reserved
[    0.275440] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.275468] pnp 00:04: [dma 4]
[    0.275472] pnp 00:04: [io  0x0000-0x000f]
[    0.275476] pnp 00:04: [io  0x0081-0x0083]
[    0.275480] pnp 00:04: [io  0x0087]
[    0.275484] pnp 00:04: [io  0x0089-0x008b]
[    0.275488] pnp 00:04: [io  0x008f]
[    0.275492] pnp 00:04: [io  0x00c0-0x00df]
[    0.275540] pnp 00:04: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.275564] pnp 00:05: [io  0x0070-0x0071]
[    0.275583] pnp 00:05: [irq 8]
[    0.275629] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.275648] pnp 00:06: [io  0x0061]
[    0.275693] pnp 00:06: Plug and Play ACPI device, IDs PNP0800 (active)
[    0.275749] pnp 00:07: [io  0x0010-0x001f]
[    0.275754] pnp 00:07: [io  0x0022-0x003f]
[    0.275758] pnp 00:07: [io  0x0044-0x005f]
[    0.275762] pnp 00:07: [io  0x0072-0x007f]
[    0.275766] pnp 00:07: [io  0x0080]
[    0.275769] pnp 00:07: [io  0x0084-0x0086]
[    0.275773] pnp 00:07: [io  0x0088]
[    0.275777] pnp 00:07: [io  0x008c-0x008e]
[    0.275781] pnp 00:07: [io  0x0090-0x009f]
[    0.275785] pnp 00:07: [io  0x00a2-0x00bf]
[    0.275789] pnp 00:07: [io  0x00e0-0x00ef]
[    0.275793] pnp 00:07: [io  0x04d0-0x04d1]
[    0.275884] system 00:07: [io  0x04d0-0x04d1] has been reserved
[    0.275891] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.275910] pnp 00:08: [io  0x00f0-0x00ff]
[    0.275936] pnp 00:08: [irq 13]
[    0.275983] pnp 00:08: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.276091] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.276791] pnp 00:0a: [io  0x03f8-0x03ff]
[    0.276802] pnp 00:0a: [irq 4]
[    0.276821] pnp 00:0a: [dma 0 disabled]
[    0.276945] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.277215] pnp 00:0b: [mem 0xa8000000-0xbfffffff]
[    0.277325] system 00:0b: [mem 0xa8000000-0xbfffffff] has been reserved
[    0.277332] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.277637] pnp 00:0c: [mem 0xfed00000-0xfed003ff]
[    0.277724] pnp 00:0c: Plug and Play ACPI device, IDs PNP0103 (active)
[    0.277738] pnp: PnP ACPI: found 13 devices
[    0.277742] ACPI: ACPI bus type pnp unregistered
[    0.277747] PnPBIOS: Disabled by ACPI PNP
[    0.315362] pci 0000:00:04.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01-01] add_size 200000
[    0.315419] pci 0000:00:04.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[    0.315430] pci 0000:00:04.0: BAR 15: assigned [mem 0xd0100000-0xd02fffff 64bit pref]
[    0.315437] pci 0000:00:04.0: PCI bridge to [bus 01-01]
[    0.315444] pci 0000:00:04.0:   bridge window [io  0xe000-0xefff]
[    0.315453] pci 0000:00:04.0:   bridge window [mem 0xfea00000-0xfeafffff]
[    0.315460] pci 0000:00:04.0:   bridge window [mem 0xd0100000-0xd02fffff 64bit pref]
[    0.315470] pci 0000:00:14.4: PCI bridge to [bus 02-02]
[    0.315489] pci 0000:00:15.0: PCI bridge to [bus 03-03]
[    0.315498] pci 0000:00:15.0:   bridge window [mem 0xfe900000-0xfe9fffff]
[    0.315512] pci 0000:00:15.1: PCI bridge to [bus 04-04]
[    0.315517] pci 0000:00:15.1:   bridge window [io  0xd000-0xdfff]
[    0.315529] pci 0000:00:15.1:   bridge window [mem 0xd0000000-0xd00fffff 64bit pref]
[    0.315599] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7]
[    0.315604] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff]
[    0.315608] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[    0.315613] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xffffffff]
[    0.315619] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.315623] pci_bus 0000:01: resource 1 [mem 0xfea00000-0xfeafffff]
[    0.315628] pci_bus 0000:01: resource 2 [mem 0xd0100000-0xd02fffff 64bit pref]
[    0.315633] pci_bus 0000:02: resource 4 [io  0x0000-0x0cf7]
[    0.315638] pci_bus 0000:02: resource 5 [io  0x0d00-0xffff]
[    0.315642] pci_bus 0000:02: resource 6 [mem 0x000a0000-0x000bffff]
[    0.315648] pci_bus 0000:02: resource 7 [mem 0xc0000000-0xffffffff]
[    0.315653] pci_bus 0000:03: resource 1 [mem 0xfe900000-0xfe9fffff]
[    0.315657] pci_bus 0000:04: resource 0 [io  0xd000-0xdfff]
[    0.315662] pci_bus 0000:04: resource 2 [mem 0xd0000000-0xd00fffff 64bit pref]
[    0.315802] NET: Registered protocol family 2
[    0.315925] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.316254] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.316922] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.317228] TCP: Hash tables configured (established 131072 bind 65536)
[    0.317234] TCP: reno registered
[    0.317242] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.317256] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.317464] NET: Registered protocol family 1
[    0.317495] pci 0000:00:01.0: Boot video device
[    1.375849] PCI: CLS 64 bytes, default 64
[    1.375942] Unpacking initramfs...
[    1.880295] Freeing initrd memory: 13692k freed
[    1.888667] LVT offset 0 assigned for vector 0x400
[    1.888714] perf: AMD IBS detected (0x000000ff)
[    1.889073] audit: initializing netlink socket (disabled)
[    1.889096] type=2000 audit(1415961611.788:1): initialized
[    1.910433] highmem bounce pool size: 64 pages
[    1.910445] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    1.910787] VFS: Disk quotas dquot_6.5.2
[    1.910836] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.910982] msgmni has been set to 1709
[    1.911319] alg: No test for stdrng (krng)
[    1.911384] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    1.911390] io scheduler noop registered
[    1.911394] io scheduler deadline registered
[    1.911446] io scheduler cfq registered (default)
[    1.911814] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.911847] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.911851] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    1.912608] GHES: HEST is not enabled!
[    1.912629] isapnp: Scanning for PnP cards...
[    2.280645] isapnp: No Plug & Play device found
[    2.280724] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.301211] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    2.322156] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    2.322532] Linux agpgart interface v0.103
[    2.322892] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    2.323406] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.323465] serio: i8042 AUX port at 0x60,0x64 irq 12
[    2.323616] mousedev: PS/2 mouse device common for all mice
[    2.323703] rtc_cmos 00:05: RTC can wake from S4
[    2.323857] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[    2.323906] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    2.324125] TCP: cubic registered
[    2.324243] NET: Registered protocol family 10
[    2.324625] Mobile IPv6
[    2.324631] NET: Registered protocol family 17
[    2.324640] Registering the dns_resolver key type
[    2.324743] Using IPI No-Shortcut mode
[    2.324890] PM: Hibernation image not present or could not be loaded.
[    2.324917] registered taskstats version 1
[    2.325624] rtc_cmos 00:05: setting system clock to 2014-11-14 10:40:12 UTC (1415961612)
[    2.325863] Freeing unused kernel memory: 416k freed
[    2.326253] Write protecting the kernel text: 3496k
[    2.326294] Write protecting the kernel read-only data: 984k
[    2.352219] udevd[49]: starting version 175
[    2.443519] SCSI subsystem initialized
[    2.494855] usbcore: registered new interface driver usbfs
[    2.494928] usbcore: registered new interface driver hub
[    2.495006] libata version 3.00 loaded.
[    2.496272] ahci 0000:00:11.0: version 3.0
[    2.496515] ahci 0000:00:11.0: AHCI 0001.0200 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[    2.496523] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[    2.501378] usbcore: registered new device driver usb
[    2.502224] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.526756] scsi0 : ahci
[    2.533326] scsi1 : ahci
[    2.535315] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.540126] scsi2 : ahci
[    2.546598] scsi3 : ahci
[    2.548823] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    2.549233] r8169 0000:04:00.0: eth0: RTL8168e/8111e at 0xf8010000, c8:60:00:bd:eb:d2, XID 0c200000 IRQ 17
[    2.549240] r8169 0000:04:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    2.553771] scsi4 : ahci
[    2.558258] scsi5 : ahci
[    2.558410] ata1: SATA max UDMA/133 abar m1024@0xfeb4b000 port 0xfeb4b100 irq 19
[    2.558417] ata2: SATA max UDMA/133 abar m1024@0xfeb4b000 port 0xfeb4b180 irq 19
[    2.558423] ata3: SATA max UDMA/133 abar m1024@0xfeb4b000 port 0xfeb4b200 irq 19
[    2.558429] ata4: SATA max UDMA/133 abar m1024@0xfeb4b000 port 0xfeb4b280 irq 19
[    2.558435] ata5: SATA max UDMA/133 abar m1024@0xfeb4b000 port 0xfeb4b300 irq 19
[    2.558441] ata6: SATA max UDMA/133 abar m1024@0xfeb4b000 port 0xfeb4b380 irq 19
[    2.558676] ehci_hcd 0000:00:12.2: EHCI Host Controller
[    2.558726] ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 1
[    2.558756] ehci_hcd 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    2.558792] QUIRK: Enable AMD PLL fix
[    2.558813] ehci_hcd 0000:00:12.2: debug port 1
[    2.558859] ehci_hcd 0000:00:12.2: irq 17, io mem 0xfeb49000
[    2.570669] ehci_hcd 0000:00:12.2: USB 2.0 started, EHCI 1.00
[    2.570724] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.570730] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.570735] usb usb1: Product: EHCI Host Controller
[    2.570739] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    2.570743] usb usb1: SerialNumber: 0000:00:12.2
[    2.570963] hub 1-0:1.0: USB hub found
[    2.570973] hub 1-0:1.0: 5 ports detected
[    2.571205] ohci_hcd 0000:00:12.0: OHCI Host Controller
[    2.571222] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 2
[    2.571278] ohci_hcd 0000:00:12.0: irq 18, io mem 0xfeb4a000
[    2.630603] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    2.630612] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.630617] usb usb2: Product: OHCI Host Controller
[    2.630622] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[    2.630626] usb usb2: SerialNumber: 0000:00:12.0
[    2.630843] hub 2-0:1.0: USB hub found
[    2.630870] hub 2-0:1.0: 5 ports detected
[    2.631100] ehci_hcd 0000:00:13.2: EHCI Host Controller
[    2.631121] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 3
[    2.631134] ehci_hcd 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    2.631174] ehci_hcd 0000:00:13.2: debug port 1
[    2.631200] ehci_hcd 0000:00:13.2: irq 17, io mem 0xfeb47000
[    2.642832] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[    2.642885] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.642891] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.642896] usb usb3: Product: EHCI Host Controller
[    2.642900] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    2.642904] usb usb3: SerialNumber: 0000:00:13.2
[    2.643108] hub 3-0:1.0: USB hub found
[    2.643118] hub 3-0:1.0: 5 ports detected
[    2.643370] ehci_hcd 0000:00:16.2: EHCI Host Controller
[    2.643387] ehci_hcd 0000:00:16.2: new USB bus registered, assigned bus number 4
[    2.643400] ehci_hcd 0000:00:16.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    2.643440] ehci_hcd 0000:00:16.2: debug port 1
[    2.643467] ehci_hcd 0000:00:16.2: irq 17, io mem 0xfeb44000
[    2.654567] ehci_hcd 0000:00:16.2: USB 2.0 started, EHCI 1.00
[    2.654621] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    2.654626] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.654631] usb usb4: Product: EHCI Host Controller
[    2.654636] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    2.654640] usb usb4: SerialNumber: 0000:00:16.2
[    2.654857] hub 4-0:1.0: USB hub found
[    2.654867] hub 4-0:1.0: 4 ports detected
[    2.655144] ohci_hcd 0000:00:13.0: OHCI Host Controller
[    2.655169] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 5
[    2.655222] ohci_hcd 0000:00:13.0: irq 18, io mem 0xfeb48000
[    2.662076] microcode: CPU0: patch_level=0x05000101
[    2.714631] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    2.714640] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.714645] usb usb5: Product: OHCI Host Controller
[    2.714650] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[    2.714654] usb usb5: SerialNumber: 0000:00:13.0
[    2.714893] hub 5-0:1.0: USB hub found
[    2.714920] hub 5-0:1.0: 5 ports detected
[    2.715349] ohci_hcd 0000:00:14.5: OHCI Host Controller
[    2.715367] ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus number 6
[    2.715402] ohci_hcd 0000:00:14.5: irq 18, io mem 0xfeb46000
[    2.727092] microcode: CPU0: new patch_level=0x0500010d
[    2.727643] microcode: CPU1: patch_level=0x05000101
[    2.738136] microcode: CPU1: new patch_level=0x0500010d
[    2.739195] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    2.774463] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    2.774469] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.774474] usb usb6: Product: OHCI Host Controller
[    2.774478] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[    2.774482] usb usb6: SerialNumber: 0000:00:14.5
[    2.776036] hub 6-0:1.0: USB hub found
[    2.776071] hub 6-0:1.0: 2 ports detected
[    2.776297] ohci_hcd 0000:00:16.0: OHCI Host Controller
[    2.776315] ohci_hcd 0000:00:16.0: new USB bus registered, assigned bus number 7
[    2.776353] ohci_hcd 0000:00:16.0: irq 18, io mem 0xfeb45000
[    2.834398] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    2.834407] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.834412] usb usb7: Product: OHCI Host Controller
[    2.834417] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[    2.834421] usb usb7: SerialNumber: 0000:00:16.0
[    2.836038] hub 7-0:1.0: USB hub found
[    2.836073] hub 7-0:1.0: 4 ports detected
[    2.874341] ata1: SATA link down (SStatus 0 SControl 300)
[    2.882383] ata2: SATA link down (SStatus 0 SControl 300)
[    2.886323] ata4: SATA link down (SStatus 0 SControl 300)
[    2.886358] ata3: SATA link down (SStatus 0 SControl 300)
[    2.886394] Refined TSC clocksource calibration: 1650.012 MHz.
[    2.886405] Switching to clocksource tsc
[    2.894300] ata6: SATA link down (SStatus 0 SControl 300)
[    3.062132] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.062588] ata5.00: ATA-9: SanDisk SDSSDRC032G, 3.1.0, max UDMA/133
[    3.062594] ata5.00: 62533296 sectors, multi 1: LBA48 NCQ (depth 31/32)
[    3.062817] ata5.00: configured for UDMA/133
[    3.063005] scsi 4:0:0:0: Direct-Access     ATA      SanDisk SDSSDRC0 3.1. PQ: 0 ANSI: 5
[    3.090352] sd 4:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
[    3.090501] sd 4:0:0:0: [sda] Write Protect is off
[    3.090507] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.090554] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.091523]  sda: sda1 sda2 < sda5 >
[    3.092383] sd 4:0:0:0: [sda] Attached SCSI disk
[    3.096794] sd 4:0:0:0: Attached scsi generic sg0 type 0
[    3.229968] usb 2-3: new full-speed USB device number 2 using ohci_hcd
[    3.394869] usb 2-3: New USB device found, idVendor=10ce, idProduct=eb70
[    3.394875] usb 2-3: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[    3.394881] usb 2-3: Manufacturer: KTURT.LTD
[    3.657543] usb 2-5: new low-speed USB device number 3 using ohci_hcd
[    3.823453] usb 2-5: New USB device found, idVendor=89e5, idProduct=101b
[    3.823459] usb 2-5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.823464] usb 2-5: Product:  USB OPTICAL MOUSE
[    3.845033] generic-usb 0003:10CE:EB70.0001: hiddev0,hidraw0: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:12.0-3/input0
[    3.849811] input:  USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:12.0/usb2/2-5/2-5:1.0/input/input0
[    3.850935] generic-usb 0003:89E5:101B.0002: input,hidraw1: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:12.0-5/input0
[    3.851522] usbcore: registered new interface driver usbhid
[    3.851527] usbhid: USB HID core driver
[    4.264956] usb 7-3: new full-speed USB device number 2 using ohci_hcd
[    4.425885] usb 7-3: New USB device found, idVendor=0b05, idProduct=179c
[    4.425891] usb 7-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.696538] usb 5-1: new low-speed USB device number 2 using ohci_hcd
[    4.865459] usb 5-1: New USB device found, idVendor=413c, idProduct=2107
[    4.865465] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.865470] usb 5-1: Product: Dell USB Entry Keyboard
[    4.865474] usb 5-1: Manufacturer: DELL
[    4.877859] input: DELL Dell USB Entry Keyboard as /devices/pci0000:00/0000:00:13.0/usb5/5-1/5-1:1.0/input/input1
[    4.880918] generic-usb 0003:413C:2107.0003: input,hidraw2: USB HID v1.10 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:00:13.0-1/input0
[    8.919337] PM: Starting manual resume from disk
[    8.919348] PM: Hibernation image partition 8:5 present
[    8.919351] PM: Looking for hibernation image.
[    8.919744] PM: Image not found (code -22)
[    8.919748] PM: Hibernation image not present or could not be loaded.
[    8.937843] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    9.402415] udevd[365]: starting version 175
[    9.641955] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[    9.641969] ACPI: Power Button [PWRB]
[    9.642168] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    9.642175] ACPI: Power Button [PWRF]
[    9.648538] wmi: Mapper loaded
[    9.654456] [drm] Initialized drm 1.1.0 20060810
[    9.826659] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    9.826667] [drm] No driver support for vblank timestamp query.
[    9.826674] [drm] Initialized radeon 1.33.0 20080528 for 0000:00:01.0 on minor 0
[    9.852839] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input4
[    9.853734] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[    9.860186] sp5100_tco: SP5100 TCO WatchDog Timer Driver v0.01
[    9.860321] sp5100_tco: mmio address 0xbafe00 already in use
[    9.991157] cfg80211: Calling CRDA to update world regulatory domain
[    9.999310] Bluetooth: Core ver 2.16
[    9.999349] NET: Registered protocol family 31
[    9.999353] Bluetooth: HCI device and connection manager initialized
[    9.999358] Bluetooth: HCI socket layer initialized
[    9.999362] Bluetooth: L2CAP socket layer initialized
[    9.999371] Bluetooth: SCO socket layer initialized
[   10.016837] usbcore: registered new interface driver btusb
[   10.173575] asus_wmi: ASUS WMI generic driver loaded
[   10.190165] asus_wmi: Initialization: 0x0
[   10.190230] asus_wmi: BIOS WMI version: 0.9
[   10.190354] asus_wmi: SFUN value: 0x0
[   10.191041] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input5
[   10.282982] cfg80211: World regulatory domain updated:
[   10.282992] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   10.282998] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   10.283003] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   10.283008] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   10.283013] cfg80211:   (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   10.283017] cfg80211:   (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   10.283022] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   10.283026] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   10.283031] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   10.312720] ath: EEPROM regdomain: 0x60
[   10.312727] ath: EEPROM indicates we should expect a direct regpair map
[   10.312734] ath: Country alpha2 being used: 00
[   10.312738] ath: Regpair used: 0x60
[   10.324887] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   10.325691] Registered led device: ath9k-phy0
[   10.325706] ieee80211 phy0: Atheros AR9285 Rev:2 mem=0xf8440000, irq=16
[   10.854193] Adding 1316860k swap on /dev/sda5.  Priority:-1 extents:1 across:1316860k SS
[   10.879471] EXT4-fs (sda1): re-mounted. Opts: (null)
[   10.952978] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   11.026241] loop: module loaded
[   12.494448] RPC: Registered named UNIX socket transport module.
[   12.494457] RPC: Registered udp transport module.
[   12.494461] RPC: Registered tcp transport module.
[   12.494464] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   12.503857] FS-Cache: Loaded
[   12.515147] NFS: Registering the id_resolver key type
[   12.515188] FS-Cache: Netfs 'nfs' registered for caching
[   12.523735] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   14.242586] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.242595] Bluetooth: BNEP filters: protocol multicast
[   14.269350] Bluetooth: RFCOMM TTY layer initialized
[   14.269364] Bluetooth: RFCOMM socket layer initialized
[   14.269369] Bluetooth: RFCOMM ver 1.11
[   14.368609] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input6
[   14.574194] lp: driver loaded but no devices found
[   14.614549] ppdev: user-space parallel port driver
[   15.397085] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   15.817385] r8169 0000:04:00.0: eth0: link down
[   15.817699] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   17.981040] wlan0: authenticate with 64:66:b3:96:06:b0
[   17.992134] wlan0: send auth to 64:66:b3:96:06:b0 (try 1/3)
[   17.994688] wlan0: authenticated
[   18.011712] wlan0: associate with 64:66:b3:96:06:b0 (try 1/3)
[   18.016790] wlan0: RX AssocResp from 64:66:b3:96:06:b0 (capab=0x431 status=0 aid=1)
[   18.024591] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   18.025354] wlan0: associated
[  108.641144] I-pipe: head domain RTAI registered.
[  108.641159] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  108.641250] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  108.641256] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12499168, CLK_FREQ 1650042000, CPU_FREQ 1650042000
[  108.641262] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  108.641268] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12499168, 12499168, 12393750
[  108.661617] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  108.661691] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  108.661700] RTAI[sched]: hard timer type/freq = APIC/12499168(Hz); default timing: oneshot; linear timed lists.
[  108.661706] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1650042000 hz.
[  108.661710] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[  108.684934] RTAI[math]: loaded.
[  113.202344] RTAI[math]: unloaded.
[  113.206002] SCHED releases registered named ALIEN PEDV$D
[  113.218642] RTAI[malloc]: unloaded.
[  113.315150] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  113.318162] I-pipe: head domain RTAI unregistered.
[  113.318263] RTAI[hal]: unmounted.
[  187.267898] I-pipe: head domain RTAI registered.
[  187.267912] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  187.267998] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  187.268004] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12499168, CLK_FREQ 1650042000, CPU_FREQ 1650042000
[  187.268010] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  187.268016] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12499168, 12499168, 12409250
[  187.284358] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  187.284432] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  187.284441] RTAI[sched]: hard timer type/freq = APIC/12499168(Hz); default timing: oneshot; linear timed lists.
[  187.284447] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1650042000 hz.
[  187.284451] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[  187.301950] RTAI[math]: loaded.
[  192.245117] RTAI[math]: unloaded.
[  192.248758] SCHED releases registered named ALIEN PEDV$D
[  192.261570] RTAI[malloc]: unloaded.
[  192.358459] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  192.361469] I-pipe: head domain RTAI unregistered.
[  192.361569] RTAI[hal]: unmounted.
[  313.566215] I-pipe: head domain RTAI registered.
[  313.566231] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  313.566315] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  313.566322] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12499168, CLK_FREQ 1650042000, CPU_FREQ 1650042000
[  313.566328] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  313.566334] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12499168, 12499168, 12389750
[  313.582429] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  313.582505] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  313.582513] RTAI[sched]: hard timer type/freq = APIC/12499168(Hz); default timing: oneshot; linear timed lists.
[  313.582519] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1650042000 hz.
[  313.582524] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[  313.599706] RTAI[math]: loaded.
[  313.798644] config string '0xe010 out'
[  313.817581] classicladder_rt: module license 'LGPL' taints kernel.
[  313.817590] Disabling lock debugging due to kernel taint
[  313.818667] creating ladder-state
[  315.855180] RTAPI: ERROR: Unexpected realtime delay on task 1
[  315.855186] This Message will only display once per session.
[  315.855188] Run the Latency Test and resolve before continuing.
[  321.408629] RTAI[math]: unloaded.
[  321.412289] SCHED releases registered named ALIEN PEDV$D
[  321.425537] RTAI[malloc]: unloaded.
[  321.525150] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  321.528176] I-pipe: head domain RTAI unregistered.
[  321.528276] RTAI[hal]: unmounted.
[  339.348646] I-pipe: head domain RTAI registered.
[  339.348661] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[  339.348747] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  339.348754] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12499168, CLK_FREQ 1650042000, CPU_FREQ 1650042000
[  339.348760] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  339.348766] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12499168, 12499168, 12406000
[  339.361940] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  339.362017] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  339.362026] RTAI[sched]: hard timer type/freq = APIC/12499168(Hz); default timing: oneshot; linear timed lists.
[  339.362032] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1650042000 hz.
[  339.362037] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[  339.379174] RTAI[math]: loaded.
[  339.581623] config string '0xe010 out'
[  339.603273] creating ladder-state
[  343.905126] RTAI[math]: unloaded.
[  343.911886] SCHED releases registered named ALIEN PEDV$D
[  343.924784] RTAI[malloc]: unloaded.
[  344.023338] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  344.026366] I-pipe: head domain RTAI unregistered.
[  344.026465] RTAI[hal]: unmounted.
Section "ServerLayout"
        Identifier     "aticonfig Layout"
        Screen      0  "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Module"
EndSection
Section "Monitor"
        Identifier   "aticonfig-Monitor[0]-0"
        Option      "VendorName" "ATI Proprietary Driver"
        Option      "ModelName" "Generic Autodetecting Monitor"
        Option      "DPMS" "true"
EndSection
Section "Device"
        Identifier "Configured Video Device"
        Driver     "vesa"
EndSection
Section "Screen"
        Identifier "aticonfig-Screen[0]-0"
        Device     "aticonfig-Device[0]-0"
        Monitor    "aticonfig-Monitor[0]-0"
        DefaultDepth     24
        SubSection "Display"
                Viewport   0 0
                Depth     24
        EndSubSection
EndSection
Last edit: 14 Nov 2014 21:01 by jorsborn.
15 Nov 2014 00:26 #53087 by ArcEye
Replied by ArcEye on topic Video Issues
Hi
Try the software accelerated GL libraries.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL
Sounds like your card / chip / driver combination is not able to use the default hardware acceleration libs
Glxgears is actually not a good test for those issues. It can work but when you try to run Axis that fails.
Otherwise you need to look at using the opensource ATI driver, you seem to be on the proprietary one, and see how that fares.
The vesa driver is rather limited and probably best not used.
