Embed Live Video to a Tab in Axis[Solved]
  • TurBoss
  • TurBoss's Avatar Topic Author
  • Premium Member
  • Premium Member
16 Nov 2014 09:50 - 24 Nov 2014 01:51 #53132 by TurBoss
hello,
LINUXCNC - 2.8.0~pre1
simulator mode
ive tried to add a video tab to linux cnc following this wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding_Camview
only tryed the mplayer mode
but i get this error
pastebin.com/LJCyA06i
my .axisrc
pastebin.com/f3NMCNWW
thx
Last edit: 24 Nov 2014 01:51 by TurBoss.
16 Nov 2014 15:52 - 16 Nov 2014 20:09 #53133 by ArcEye
Replied by ArcEye on topic Embed Live Video to a Tab in Axis
I am not at a linux box right now, but I am pretty sure that the problem is quite simple.
The wiki may have been edited recently, but some of the info is old.
The code in the .axisrc file was by Dewey AFAIR and allowed dynamic tabs to be created.
I think code to do this is now in Axis, so you are trying to do the same thing twice, which is causing the errors.
Comment out the code, or just delete .axisrc, if that is all it contains and try again
EDIT: Yes I can confirm the code is already in Axis now, so that is your problem. mplayer, xterm and other apps that take a WinID for a parent window, embed quite nicely
I have updated the wiki
Last edit: 16 Nov 2014 20:09 by ArcEye.
Time to create page: 0.050 seconds
