Problem with Video Card
- roosp
21 Nov 2014 00:28 - 21 Nov 2014 08:00 #53244
by roosp
Problem with Video Card was created by roosp
I am a newbie to LinuxCNC. I have build my own CNC and wanted to use LinuxCNC for the control of the steppers. The PC I am using is a Dell Optiplex GX270. The installation of Debian Wheezy LinuxCNC went well and I could run LinuxCNC Axis but the latency was very poor with the onboard video. Then I installed a APG video card with the expectation to get a better latency but LinuxCNC Axis just start and then terminate with the following message:
I expect it is the video card but do not know how to get it to work. The rest of Linux Debian Wheezy seems to work fine with the APG video card.
Step by step assistance will be appreciated because I am also learning Linux as well.
Thank you.
Paul
South Africa
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.1
Machine configuration directory is '/home/paulr/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
INIFILE=/home/paulr/linuxcnc/configs/sim.axis/axis.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=3585
Killing task milltask, PID=3654
Debug file information:
python: nv04_state_raster.c:126: get_blend_func: Assertion `0' failed.
/usr/bin/linuxcnc: line 766: 3655 Aborted $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
3585
PID TTY STAT TIME COMMAND
3654
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-3linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-3linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001ff70000 (usable)
[ 0.000000] BIOS-e820: 000000001ff70000 - 000000001ff72000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000001ff72000 - 000000001ff93000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001ff93000 - 0000000020000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fecf0000 - 00000000fecf1000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Dell Computer Corporation OptiPlex GX270 /0U1324, BIOS A02 07/16/2003
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x1ff70 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C3FFF write-protect
[ 0.000000] C4000-C7FFF uncachable
[ 0.000000] C8000-CBFFF write-protect
[ 0.000000] CC000-CFFFF uncachable
[ 0.000000] D0000-D3FFF write-protect
[ 0.000000] D4000-D7FFF uncachable
[ 0.000000] D8000-DBFFF write-protect
[ 0.000000] DC000-DFFFF uncachable
[ 0.000000] E0000-E3FFF write-protect
[ 0.000000] E4000-E7FFF uncachable
[ 0.000000] E8000-EBFFF write-protect
[ 0.000000] EC000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-000000001ff70000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001fc00000 page 2M
[ 0.000000] 001fc00000 - 001ff70000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x1ff6ffff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 1e7ab000 - 1f58a000
[ 0.000000] ACPI: RSDP 000feba0 00014 (v00 DELL )
[ 0.000000] ACPI: RSDT 000fd193 00038 (v01 DELL GX270 00000007 ASL 00000061)
[ 0.000000] ACPI: FACP 000fd1cb 00074 (v01 DELL GX270 00000007 ASL 00000061)
[ 0.000000] ACPI: DSDT fffcdbdd 02787 (v01 DELL dt_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 1ff70000 00040
[ 0.000000] ACPI: SSDT fffd040b 00096 (v01 DELL st_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: APIC 000fd23f 0006C (v01 DELL GX270 00000007 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fd2ab 00028 (v01 DELL GX270 00000007 ASL 00000061)
[ 0.000000] ACPI: ASF! 000fd2d3 00067 (v16 DELL GX270 00000007 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 511MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1ff70000
[ 0.000000] low ram: 0 - 1ff70000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001ff70
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x000000a0
[ 0.000000] 0: 0x00000100 -> 0x0001ff70
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map dfb6f200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3952 pages, LIFO batch:0
[ 0.000000] Normal zone: 991 pages used for memmap
[ 0.000000] Normal zone: 125841 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:dec00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @dfb27000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129793
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=17482122-4231-4c50-88bd-3f29a0fd772e ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 1047296 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 497380k/523712k available (3495k kernel code, 25884k reserved, 1237k data, 416k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xe0770000 - 0xff7fe000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdff70000 ( 511 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d0a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d0a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=de008000 soft=de00a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2260.934 MHz processor.
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4521.86 BogoMIPS (lpj=9043736)
[ 0.004012] pid_max: default: 32768 minimum: 301
[ 0.004104] Security Framework initialized
[ 0.004113] AppArmor: AppArmor disabled by boot time parameter
[ 0.004150] Mount-cache hash table entries: 512
[ 0.004508] Initializing cgroup subsys cpuacct
[ 0.004513] Initializing cgroup subsys memory
[ 0.004530] Initializing cgroup subsys devices
[ 0.004535] Initializing cgroup subsys freezer
[ 0.004539] Initializing cgroup subsys net_cls
[ 0.004543] Initializing cgroup subsys blkio
[ 0.004558] Initializing cgroup subsys perf_event
[ 0.004612] CPU0: Hyper-Threading is disabled
[ 0.004618] mce: CPU supports 4 MCE banks
[ 0.004631] CPU0: Thermal monitoring enabled (TM1)
[ 0.004721] SMP alternatives: switching to UP code
[ 0.012857] ACPI: Core revision 20120320
[ 0.039587] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.039953] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.079648] CPU0: Intel(R) Pentium(R) 4 CPU 2.26GHz stepping 09
[ 0.080004] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.080004] ... version: 0
[ 0.080004] ... bit width: 40
[ 0.080004] ... generic registers: 18
[ 0.080004] ... value mask: 000000ffffffffff
[ 0.080004] ... max period: 0000007fffffffff
[ 0.080004] ... fixed-purpose events: 0
[ 0.080004] ... event mask: 000000000003ffff
[ 0.088040] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.088105] Brought up 1 CPUs
[ 0.088111] Total of 1 processors activated (4521.86 BogoMIPS).
[ 0.088691] devtmpfs: initialized
[ 0.089148] PM: Registering ACPI NVS region [mem 0x1ff70000-0x1ff71fff] (8192 bytes)
[ 0.089340] dummy:
[ 0.089443] NET: Registered protocol family 16
[ 0.089673] ACPI: bus type pci registered
[ 0.090805] PCI: PCI BIOS revision 2.10 entry at 0xfbab1, last bus=2
[ 0.090810] PCI: Using configuration type 1 for base access
[ 0.092021] bio: create slab <bio-0> at 0
[ 0.092195] ACPI: Added _OSI(Module Device)
[ 0.092201] ACPI: Added _OSI(Processor Device)
[ 0.092206] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.092211] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.093387] ACPI: EC: Look up EC in DSDT
[ 0.116718] ACPI: Interpreter enabled
[ 0.116743] ACPI: (supports S0 S1 S4 S5)
[ 0.116797] ACPI: Using IOAPIC for interrupt routing
[ 0.149505] ACPI: No dock devices found.
[ 0.149519] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.152499] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.158782] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.158789] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.158796] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.158801] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000ca7ff] (ignored)
[ 0.158806] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xfebfffff] (ignored)
[ 0.158811] PCI: root bus 00: using default resources
[ 0.158884] PCI host bridge to bus 0000:00
[ 0.158891] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.158898] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.158922] pci 0000:00:00.0: [8086:2570] type 00 class 0x060000
[ 0.158930] pci 0000:00:00.0: Enabling MCH 'Overflow' Device
[ 0.158945] pci 0000:00:00.0: reg 10: [mem 0xf0000000-0xf7ffffff pref]
[ 0.159033] pci 0000:00:01.0: [8086:2571] type 01 class 0x060400
[ 0.159094] pci 0000:00:06.0: [8086:2576] type 00 class 0x088000
[ 0.159111] pci 0000:00:06.0: reg 10: [mem 0xfecf0000-0xfecf0fff]
[ 0.159225] pci 0000:00:1d.0: [8086:24d2] type 00 class 0x0c0300
[ 0.159287] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.159335] pci 0000:00:1d.1: [8086:24d4] type 00 class 0x0c0300
[ 0.159396] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.159445] pci 0000:00:1d.2: [8086:24d7] type 00 class 0x0c0300
[ 0.159506] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.159553] pci 0000:00:1d.3: [8086:24de] type 00 class 0x0c0300
[ 0.159614] pci 0000:00:1d.3: reg 20: [io 0xff20-0xff3f]
[ 0.159678] pci 0000:00:1d.7: [8086:24dd] type 00 class 0x0c0320
[ 0.159709] pci 0000:00:1d.7: reg 10: [mem 0xffa80800-0xffa80bff]
[ 0.159814] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.159844] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[ 0.159906] pci 0000:00:1f.0: [8086:24d0] type 00 class 0x060100
[ 0.159991] pci 0000:00:1f.0: HPET at 0xfed00000
[ 0.160038] pci 0000:00:1f.1: [8086:24db] type 00 class 0x01018a
[ 0.160059] pci 0000:00:1f.1: reg 10: [io 0x01f0-0x01f7]
[ 0.160074] pci 0000:00:1f.1: reg 14: [io 0x03f4-0x03f7]
[ 0.160089] pci 0000:00:1f.1: reg 18: [io 0x0170-0x0177]
[ 0.160103] pci 0000:00:1f.1: reg 1c: [io 0x0374-0x0377]
[ 0.160118] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf]
[ 0.160133] pci 0000:00:1f.1: reg 24: [mem 0xfebffc00-0xfebfffff]
[ 0.160173] pci 0000:00:1f.2: [8086:24d1] type 00 class 0x01018f
[ 0.160193] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.160207] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.160221] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.160234] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.160248] pci 0000:00:1f.2: reg 20: [io 0xfea0-0xfeaf]
[ 0.160292] pci 0000:00:1f.3: [8086:24d3] type 00 class 0x0c0500
[ 0.160353] pci 0000:00:1f.3: reg 20: [io 0xeda0-0xedbf]
[ 0.160408] pci 0000:00:1f.5: [8086:24d5] type 00 class 0x040100
[ 0.160432] pci 0000:00:1f.5: reg 10: [io 0xee00-0xeeff]
[ 0.160446] pci 0000:00:1f.5: reg 14: [io 0xedc0-0xedff]
[ 0.160460] pci 0000:00:1f.5: reg 18: [mem 0xfebffa00-0xfebffbff]
[ 0.160475] pci 0000:00:1f.5: reg 1c: [mem 0xfebff900-0xfebff9ff]
[ 0.160529] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[ 0.160575] pci 0000:01:00.0: [10de:002c] type 00 class 0x030000
[ 0.160600] pci 0000:01:00.0: reg 10: [mem 0xfd000000-0xfdffffff]
[ 0.160613] pci 0000:01:00.0: reg 14: [mem 0xf8000000-0xf9ffffff pref]
[ 0.160658] pci 0000:01:00.0: reg 30: [mem 0xfea00000-0xfea0ffff pref]
[ 0.160733] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.160744] pci 0000:00:01.0: bridge window [mem 0xfd000000-0xfeafffff]
[ 0.160751] pci 0000:00:01.0: bridge window [mem 0xf8000000-0xf9ffffff pref]
[ 0.160811] pci 0000:02:0c.0: [8086:100e] type 00 class 0x020000
[ 0.160839] pci 0000:02:0c.0: reg 10: [mem 0xfcfe0000-0xfcffffff]
[ 0.160864] pci 0000:02:0c.0: reg 18: [io 0xdf40-0xdf7f]
[ 0.160939] pci 0000:02:0c.0: PME# supported from D0 D3hot D3cold
[ 0.160987] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.160995] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.161003] pci 0000:00:1e.0: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.161012] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.161018] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.161037] pci_bus 0000:00: on NUMA node 0
[ 0.161045] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.161756] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.162538] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.296930] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 0.297330] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 0.297724] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.298117] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.298506] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.298897] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.299289] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.299686] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.300039] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.300046] vgaarb: loaded
[ 0.300049] vgaarb: bridge control possible 0000:01:00.0
[ 0.300111] PCI: Using ACPI for IRQ routing
[ 0.300118] PCI: pci_cache_line_size set to 64 bytes
[ 0.300218] reserve RAM buffer: 000000001ff70000 - 000000001fffffff
[ 0.300588] hpet clockevent registered
[ 0.300598] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.300610] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.302636] Switching to clocksource hpet
[ 0.302743] pnp: PnP ACPI init
[ 0.302767] ACPI: bus type pnp registered
[ 0.305516] pnp 00:00: [mem 0x00000000-0x0009ffff]
[ 0.305522] pnp 00:00: [mem 0x00100000-0x00ffffff]
[ 0.305528] pnp 00:00: [mem 0x01000000-0x1ff6ffff]
[ 0.305533] pnp 00:00: [mem 0x000ca800-0x000fffff]
[ 0.305539] pnp 00:00: [mem 0xfec00000-0xfec0ffff]
[ 0.305544] pnp 00:00: [mem 0xfee00000-0xfee0ffff]
[ 0.305549] pnp 00:00: [mem 0xfed20000-0xfed8ffff]
[ 0.305555] pnp 00:00: [mem 0xfecf0000-0xfecf0fff]
[ 0.305560] pnp 00:00: [mem 0xffb00000-0xffbfffff]
[ 0.305566] pnp 00:00: [mem 0xffc00000-0xffffffff]
[ 0.305651] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.305659] system 00:00: [mem 0x00100000-0x00ffffff] could not be reserved
[ 0.305666] system 00:00: [mem 0x01000000-0x1ff6ffff] could not be reserved
[ 0.305673] system 00:00: [mem 0x000ca800-0x000fffff] could not be reserved
[ 0.305680] system 00:00: [mem 0xfec00000-0xfec0ffff] could not be reserved
[ 0.305687] system 00:00: [mem 0xfee00000-0xfee0ffff] has been reserved
[ 0.305694] system 00:00: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.305700] system 00:00: [mem 0xfecf0000-0xfecf0fff] has been reserved
[ 0.305707] system 00:00: [mem 0xffb00000-0xffbfffff] has been reserved
[ 0.305713] system 00:00: [mem 0xffc00000-0xffffffff] has been reserved
[ 0.305720] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.308820] pnp 00:01: [bus 00-ff]
[ 0.308826] pnp 00:01: [io 0x0cf8-0x0cff]
[ 0.308833] pnp 00:01: [io 0x0000-0x0cf7 window]
[ 0.308838] pnp 00:01: [io 0x0d00-0xffff window]
[ 0.308843] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[ 0.308848] pnp 00:01: [mem 0x000c0000-0x000ca7ff window]
[ 0.308852] pnp 00:01: [mem 0x80000000-0xfebfffff window]
[ 0.308917] pnp 00:01: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.312217] pnp 00:02: [io 0x0080-0x009f]
[ 0.312223] pnp 00:02: [io 0x0000-0x001f]
[ 0.312228] pnp 00:02: [io 0x00c0-0x00df]
[ 0.312234] pnp 00:02: [dma 4]
[ 0.312282] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.312397] pnp 00:03: [io 0x00f0-0x00ff]
[ 0.312415] pnp 00:03: [irq 13]
[ 0.312466] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.312581] pnp 00:04: [io 0x0061]
[ 0.312632] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.312748] pnp 00:05: [io 0x0070-0x007f]
[ 0.312758] pnp 00:05: [irq 8]
[ 0.312808] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.315935] pnp 00:06: [io 0x03f0-0x03f5]
[ 0.315942] pnp 00:06: [io 0x03f7]
[ 0.315953] pnp 00:06: [irq 6]
[ 0.315959] pnp 00:06: [dma 2]
[ 0.316257] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.317282] pnp 00:07: [io 0x0060]
[ 0.317288] pnp 00:07: [io 0x0064]
[ 0.317297] pnp 00:07: [irq 1]
[ 0.317360] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.320669] pnp 00:08: [io 0x03f8-0x03ff]
[ 0.320680] pnp 00:08: [irq 4]
[ 0.320911] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.325651] pnp 00:09: [io 0x0378-0x037f]
[ 0.325657] pnp 00:09: [io 0x0778-0x077f]
[ 0.325668] pnp 00:09: [irq 7]
[ 0.325673] pnp 00:09: [dma 0 disabled]
[ 0.326248] pnp 00:09: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.328063] pnp 00:0a: [io 0x0062-0x0063]
[ 0.328069] pnp 00:0a: [io 0x0065-0x006f]
[ 0.328075] pnp 00:0a: [io 0x00e0-0x00ef]
[ 0.328079] pnp 00:0a: [io 0x0800-0x085f]
[ 0.328083] pnp 00:0a: [io 0x0c00-0x0c7f]
[ 0.328088] pnp 00:0a: [io 0x0860-0x08ff]
[ 0.328178] system 00:0a: [io 0x0800-0x085f] has been reserved
[ 0.328185] system 00:0a: [io 0x0c00-0x0c7f] has been reserved
[ 0.328195] system 00:0a: [io 0x0860-0x08ff] has been reserved
[ 0.328201] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.329119] pnp: PnP ACPI: found 11 devices
[ 0.329124] ACPI: ACPI bus type pnp unregistered
[ 0.329132] PnPBIOS: Disabled by ACPI PNP
[ 0.367055] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.367067] pci 0000:00:01.0: bridge window [mem 0xfd000000-0xfeafffff]
[ 0.367075] pci 0000:00:01.0: bridge window [mem 0xf8000000-0xf9ffffff pref]
[ 0.367086] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
[ 0.367093] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.367102] pci 0000:00:1e.0: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.367131] pci 0000:00:1e.0: setting latency timer to 64
[ 0.367139] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.367145] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.367150] pci_bus 0000:01: resource 1 [mem 0xfd000000-0xfeafffff]
[ 0.367155] pci_bus 0000:01: resource 2 [mem 0xf8000000-0xf9ffffff pref]
[ 0.367161] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.367166] pci_bus 0000:02: resource 1 [mem 0xfcf00000-0xfcffffff]
[ 0.367171] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[ 0.367176] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[ 0.367292] NET: Registered protocol family 2
[ 0.367405] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.367655] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.367735] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.367816] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.367820] TCP: reno registered
[ 0.367826] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.367835] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.367965] NET: Registered protocol family 1
[ 0.368243] pci 0000:01:00.0: Boot video device
[ 0.368255] PCI: CLS 64 bytes, default 64
[ 0.368349] Unpacking initramfs...
[ 0.851412] Freeing initrd memory: 14204k freed
[ 0.865892] Simple Boot Flag value 0x87 read from CMOS RAM was invalid
[ 0.865899] Simple Boot Flag at 0x7a set to 0x1
[ 0.866502] audit: initializing netlink socket (disabled)
[ 0.866533] type=2000 audit(1416499468.860:1): initialized
[ 0.881445] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.881694] VFS: Disk quotas dquot_6.5.2
[ 0.881735] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.881862] msgmni has been set to 999
[ 0.882150] alg: No test for stdrng (krng)
[ 0.882202] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.882208] io scheduler noop registered
[ 0.882212] io scheduler deadline registered
[ 0.882240] io scheduler cfq registered (default)
[ 0.882404] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.882443] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.882447] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.882898] GHES: HEST is not enabled!
[ 0.882923] isapnp: Scanning for PnP cards...
[ 1.237109] isapnp: No Plug & Play device found
[ 1.237190] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.257546] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.278315] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.278547] Linux agpgart interface v0.103
[ 1.278758] agpgart-intel 0000:00:00.0: Intel 865 Chipset
[ 1.285549] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xf0000000
[ 1.285767] i8042: PNP: PS/2 Controller [PNP0303:KBD] at 0x60,0x64 irq 1
[ 1.285772] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.286668] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.286841] mousedev: PS/2 mouse device common for all mice
[ 1.286924] rtc_cmos 00:05: RTC can wake from S4
[ 1.287096] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 1.287128] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 1.287322] TCP: cubic registered
[ 1.287397] NET: Registered protocol family 10
[ 1.287761] Mobile IPv6
[ 1.287767] NET: Registered protocol family 17
[ 1.287776] Registering the dns_resolver key type
[ 1.287866] Using IPI No-Shortcut mode
[ 1.288089] PM: Hibernation image not present or could not be loaded.
[ 1.288110] registered taskstats version 1
[ 1.288527] rtc_cmos 00:05: setting system clock to 2014-11-20 16:04:29 UTC (1416499469)
[ 1.288681] Freeing unused kernel memory: 416k freed
[ 1.289131] Write protecting the kernel text: 3496k
[ 1.289162] Write protecting the kernel read-only data: 984k
[ 1.315248] udevd[45]: starting version 175
[ 1.320426] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.416267] usbcore: registered new interface driver usbfs
[ 1.416316] usbcore: registered new interface driver hub
[ 1.425976] usbcore: registered new device driver usb
[ 1.426861] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.426958] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.426965] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.427012] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.427053] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.442990] Floppy drive(s): fd0 is 1.44M
[ 1.444919] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.468615] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.468660] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xffa80800
[ 1.469946] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 1.469953] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 1.475139] SCSI subsystem initialized
[ 1.480062] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.480152] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.480158] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.480163] usb usb1: Product: EHCI Host Controller
[ 1.480167] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.480172] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.480401] hub 1-0:1.0: USB hub found
[ 1.480413] hub 1-0:1.0: 8 ports detected
[ 1.483468] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.483477] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.483498] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.483556] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000ff80
[ 1.483629] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.483635] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.483639] usb usb2: Product: UHCI Host Controller
[ 1.483644] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.483648] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.483862] hub 2-0:1.0: USB hub found
[ 1.483876] hub 2-0:1.0: 2 ports detected
[ 1.484123] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.484131] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.484147] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.484195] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000ff60
[ 1.484256] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.484262] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.484266] usb usb3: Product: UHCI Host Controller
[ 1.484270] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.484274] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.484468] hub 3-0:1.0: USB hub found
[ 1.484479] hub 3-0:1.0: 2 ports detected
[ 1.485692] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.485701] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.485718] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.485778] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 1.485846] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.485852] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.485856] usb usb4: Product: UHCI Host Controller
[ 1.485861] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.485865] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.486084] hub 4-0:1.0: USB hub found
[ 1.486095] hub 4-0:1.0: 2 ports detected
[ 1.486250] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.486257] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.486274] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.486305] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000ff20
[ 1.486368] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.486374] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.486378] usb usb5: Product: UHCI Host Controller
[ 1.486382] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.486387] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.486596] hub 5-0:1.0: USB hub found
[ 1.486607] hub 5-0:1.0: 2 ports detected
[ 1.493098] FDC 0 is a post-1991 82077
[ 1.520261] libata version 3.00 loaded.
[ 1.520887] ata_piix 0000:00:1f.1: version 2.13
[ 1.520976] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.526127] scsi0 : ata_piix
[ 1.529292] microcode: CPU0 sig=0xf29, pf=0x4, revision=0x11
[ 1.529385] scsi1 : ata_piix
[ 1.529483] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.529489] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.529785] ata_piix 0000:00:1f.2: MAP [ P0 -- P1 -- ]
[ 1.529860] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.538868] scsi2 : ata_piix
[ 1.542630] scsi3 : ata_piix
[ 1.542741] ata3: SATA max UDMA/133 cmd 0xfe00 ctl 0xfe10 bmdma 0xfea0 irq 18
[ 1.542747] ata4: SATA max UDMA/133 cmd 0xfe20 ctl 0xfe30 bmdma 0xfea8 irq 18
[ 1.628813] microcode: CPU0 updated to revision 0x2e, date = 2004-08-11
[ 1.628891] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.692894] ata2.00: ATAPI: SAMSUNG CD-ROM SC-148C, B105, max UDMA/33
[ 1.693069] ata1.00: ATA-6: ST340810A, 3.60, max UDMA/100
[ 1.693075] ata1.00: 78165360 sectors, multi 8: LBA
[ 1.693449] ata2.00: configured for UDMA/33
[ 1.712296] ata1.00: configured for UDMA/100
[ 1.730685] scsi 0:0:0:0: Direct-Access ATA ST340810A 3.60 PQ: 0 ANSI: 5
[ 1.731207] scsi 1:0:0:0: CD-ROM SAMSUNG CD-ROM SC-148C B105 PQ: 0 ANSI: 5
[ 1.876030] Refined TSC clocksource calibration: 2260.999 MHz.
[ 1.876041] Switching to clocksource tsc
[ 1.886064] e1000 0000:02:0c.0: eth0: (PCI:33MHz:32-bit) 00:0b:db:c5:c0:2f
[ 1.886086] e1000 0000:02:0c.0: eth0: Intel(R) PRO/1000 Network Connection
[ 1.976029] usb 2-1: new low-speed USB device number 2 using uhci_hcd
[ 2.151509] usb 2-1: New USB device found, idVendor=046d, idProduct=c016
[ 2.151516] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.151521] usb 2-1: Product: Optical USB Mouse
[ 2.151525] usb 2-1: Manufacturer: Logitech
[ 5.753080] sd 0:0:0:0: [sda] 78165360 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 5.753214] sd 0:0:0:0: [sda] Write Protect is off
[ 5.753221] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.753277] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.755392] sr0: scsi3-mmc drive: 1x/48x cd/rw xa/form2 cdda tray
[ 5.755401] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 5.756195] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 5.757888] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input1
[ 5.758162] generic-usb 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:1d.0-1/input0
[ 5.758221] usbcore: registered new interface driver usbhid
[ 5.758225] usbhid: USB HID core driver
[ 5.790527] sda: sda1 sda2 < sda5 >
[ 5.791178] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.808267] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.809178] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 11.514056] PM: Starting manual resume from disk
[ 11.514065] PM: Hibernation image partition 8:5 present
[ 11.514069] PM: Looking for hibernation image.
[ 11.550701] PM: Image not found (code -22)
[ 11.550706] PM: Hibernation image not present or could not be loaded.
[ 11.622525] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 14.223200] udevd[311]: starting version 175
[ 14.575677] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 14.575692] ACPI: Power Button [VBTN]
[ 14.575807] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 14.575815] ACPI: Power Button [PWRF]
[ 14.615895] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 14.885411] parport_pc 00:09: reported by Plug and Play ACPI
[ 14.885468] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 15.141964] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 15.188523] intel_rng: FWH not detected
[ 15.210320] iTCO_vendor_support: vendor-support=0
[ 15.555035] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 15.555159] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 15.715014] [drm] Initialized drm 1.1.0 20060810
[ 16.103275] wmi: Mapper loaded
[ 16.182536] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[ 16.255052] [drm] nouveau 0000:01:00.0: Detected an NV 4 generation card (0x20154000)
[ 16.257132] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 16.292552] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 16.292560] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 16.292656] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 16.292661] [drm] nouveau 0000:01:00.0: BMP version 5.6
[ 16.292667] [drm] nouveau 0000:01:00.0: Bios version 02.05.20.02
[ 16.292672] [drm] nouveau 0000:01:00.0: No DCB data found in VBIOS
[ 16.292945] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 16.302022] [TTM] Zone kernel: Available graphics memory: 256000 kiB
[ 16.302028] [TTM] Initializing pool allocator
[ 16.302050] [drm] nouveau 0000:01:00.0: Detected 16MiB VRAM (SDRAM)
[ 16.302260] agpgart-intel 0000:00:00.0: AGP 3.0 bridge
[ 16.302286] agpgart-intel 0000:00:00.0: bridge is in legacy mode, falling back to 2.x
[ 16.302299] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
[ 16.302357] nouveau 0000:01:00.0: putting AGP V2 device into 4x mode
[ 16.302376] [drm] nouveau 0000:01:00.0: 128 MiB GART (aperture)
[ 16.302515] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 16.357522] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 16.357528] [drm] No driver support for vblank timestamp query.
[ 16.357610] [drm] nouveau 0000:01:00.0: 0 available performance level(s)
[ 16.357617] [drm] nouveau 0000:01:00.0: c: core 100MHz memory 109MHz
[ 16.400264] [drm] nouveau 0000:01:00.0: allocated 1024x768 fb: 0x44000, bo df018200
[ 16.400494] fbcon: nouveaufb (fb0) is primary device
[ 16.535985] Console: switching to colour frame buffer device 128x48
[ 16.536939] fb0: nouveaufb frame buffer device
[ 16.536943] drm: registered panic notifier
[ 16.536953] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 16.608039] intel8x0_measure_ac97_clock: measured 52557 usecs (2533 samples)
[ 16.608046] intel8x0: clocking to 48000
[ 19.103709] Adding 1028092k swap on /dev/sda5. Priority:-1 extents:1 across:1028092k
[ 19.131410] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 19.567317] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 19.730470] loop: module loaded
[ 22.118138] RPC: Registered named UNIX socket transport module.
[ 22.118146] RPC: Registered udp transport module.
[ 22.118149] RPC: Registered tcp transport module.
[ 22.118153] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 22.178830] FS-Cache: Loaded
[ 22.249663] NFS: Registering the id_resolver key type
[ 22.249699] FS-Cache: Netfs 'nfs' registered for caching
[ 22.268917] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 24.681931] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input4
[ 27.867483] Bluetooth: Core ver 2.16
[ 27.867915] NET: Registered protocol family 31
[ 27.867922] Bluetooth: HCI device and connection manager initialized
[ 27.867928] Bluetooth: HCI socket layer initialized
[ 27.867932] Bluetooth: L2CAP socket layer initialized
[ 27.867943] Bluetooth: SCO socket layer initialized
[ 27.924475] Bluetooth: RFCOMM TTY layer initialized
[ 27.924487] Bluetooth: RFCOMM socket layer initialized
[ 27.924492] Bluetooth: RFCOMM ver 1.11
[ 28.020652] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 28.020660] Bluetooth: BNEP filters: protocol multicast
[ 28.204755] lp0: using parport0 (interrupt-driven).
[ 28.418848] ppdev: user-space parallel port driver
[ 31.504698] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 31.512030] e1000: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 31.512206] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 42.352013] eth0: no IPv6 routers present
[ 85.802621] x-www-browser[3323]: segfault at 4 ip b2769af1 sp bfb7da80 error 4 in nouveau_vieux_dri.so[b274e000+360000]
[ 529.310828] I-pipe: head domain RTAI registered.
[ 529.310841] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 529.310852] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 529.310859] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8312480, CLK_FREQ 2260934000, CPU_FREQ 2260934000
[ 529.310864] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 529.310870] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312480, 8312480, 8138750
[ 529.408311] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 529.408385] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 529.408394] RTAI[sched]: hard timer type/freq = APIC/8312480(Hz); default timing: oneshot; linear timed lists.
[ 529.408401] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2260934000 hz.
[ 529.408405] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 529.445435] RTAI[math]: loaded.
[ 536.384608] RTAI[math]: unloaded.
[ 536.388580] SCHED releases registered named ALIEN PEDV$D
[ 536.398648] RTAI[malloc]: unloaded.
[ 536.496037] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 536.499764] I-pipe: head domain RTAI unregistered.
[ 536.499783] RTAI[hal]: unmounted.
Thank you.
Paul
South Africa
Last edit: 21 Nov 2014 08:00 by BigJohnT. Reason: add code tags
- ArcEye
- Thank you received: 758
21 Nov 2014 01:15 #53245
by ArcEye
Replied by ArcEye on topic Problem with Video Card
Hi
I managed to find one reference to this error, on a Russian CNC site
It appears to be specific to this particular type of nvidia AGP card
In that instance, changing to the software accelerated opengl libraries apparently worked
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL
If that fails, you may have to go for something like a Matrox AGP board, nvidia is best avoided altogether.
- roosp
21 Nov 2014 02:42 #53249
by roosp
Replied by roosp on topic Problem with Video Card
Hi ArcEye
Thank you very much for the quick response.
Will look at the link and try to understand it all. It seems if I must rather look for another APG video card or I must try some of the PCI video cards
that I have available.
I see in the LinuxCNC list of computers for Dell Optiplex GX270 it is mentioned that "Onboard video - must disable SMI".
I am not sure how to perform that. Is there a easy step by step procedure somewhere. Some of the articles and writeups are difficult for someone
without Linux background.
- ArcEye
21 Nov 2014 02:57 #53250
by ArcEye
Only once you are sure you have an affected chipset.
Read the FAQ and do the test to determine that. There is a link to the wiki re loading the smi module.
www.linuxcnc.org/index.php/english/forum...me-latency-solutions
Do one thing at a time, first try the software libs. Hopefully that will enable Axis to start, then you can look at further reducing latency
