M66 alternative
22 Nov 2014 00:12 #53266 by eslavko
M66 alternative was created by eslavko
Hello...
I try to make scanning laser project.
I add rotating axis (A) with laser attached to arm.
For modulating laser I use streamer component with two bitstream. One is lased enable and other is position index. Now when laser rotates I wait in Gcode with M66 to get falling edge of index to advance Y axis for new arc scan. The trouble is that M66 seems to be userspace component and sometime miss the index. Is there maybe some other alternative to M66?
Time to create page: 0.039 seconds
