Rotary axis feedrate.
22 Nov 2014 19:50 #53286 by eslavko
Rotary axis feedrate. was created by eslavko
Hello...
I have trouble with A axis feedrate.
There is some limit that I'm unable to find it. If I jog A axis (rotary) I can turn it fast as I need to. But when I execute G1 Aangle Fspeed I can get max 720 deg/sec. But when jogging I can get it over 3600 deg/sec. Even G0 doesn't go faster. With G1 F les 720 the speed is limited to corect value.
Can someone heelp me?
Thanks...
there is ini file
# EMC controller parameters for generic controller. Make these what you need
# for your system.
# General note: Comments can either be preceded with a # or ; - either is
# acceptable, although # is in keeping with most linux config files.
# Settings with a + at the front of the comment are likely needed to get
# changed by the user.
# Settings with a - at the front are highly unneeded to be changed
# General section
[EMC]
MACHINE =               laserCNC
DEBUG = 0
NML_FILE =		emc.nml
[FILTER]
#PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
#PROGRAM_EXTENSION = .py Python Script
#png = image-to-gcode
#gif = image-to-gcode
#jpg = image-to-gcode
#py = python
# Sections for display options
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm
MAX_FEED_OVERRIDE = 2.5
#MIN_SPINDLE_OVERRIDE = 0.5
#MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_ANGULAR_VELOCITY = 3600
MAX_ANGULAR_VELOCITY = 3600
INTRO_TIME = 1
PROGRAM_PREFIX = /home/slavko/linuxcnc/laser_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
#OPEN_FILE = /home/slavko/linuxcnc/laser_files/00_rotscaner.ngc
OPEN_FILE = /home/slavko/linuxcnc/laser_files/test1.ngc
# Task controller section
[TASK]
# Name of task controller program, e.g., milltask
TASK =                  milltask
CYCLE_TIME =            0.010
# Part program interpreter section
[RS274NGC]
#- File containing interpreter variables
PARAMETER_FILE =        linuxcnc.var
# Motion control section
[EMCMOT]
EMCMOT =              motmod
COMM_TIMEOUT =          1.0
COMM_WAIT =             0.010
BASE_PERIOD =           35000
SERVO_PERIOD =          1000000
# Hardware Abstraction Layer section
[HALUI]
[HAL]
HALFILE =           laserCNC.hal
HALUI=halui
#POSTGUI_HALFILE = caacam.hal
# Trajectory planner section
[TRAJ]
#+ machine specific settings
AXES =                  4
COORDINATES =           X Y Z A
HOME =                  0 0 0 0
LINEAR_UNITS =          mm
ANGULAR_UNITS =         degree
CYCLE_TIME =            0.010
DEFAULT_VELOCITY =      18
MAX_VELOCITY =          25
DEFAULT_ACCELERATION =  2000
MAX_ACCELERATION =      4000
#NO_FORCE_HOMING = 1
# Axes sections
#+ First axis
[AXIS_0]
TYPE =                          LINEAR
HOME =                          0.000
MAX_VELOCITY =                  25
# NOTE:  the step generator module applies its own limits to
# acceleration and velocity.  We have discovered that it needs
# to have a little "headroom" over the accel by the trajectory
# planner, otherwise it can fall slightly behind during accel
# and later overshoot as it catches up.  In the long term we
# hope to come up with a clean fix for this problem.  In the
# meantime, please set STEPGEN_MAXACCEL below to a few percent
# higher than the regular acceleration limit MAX_ACCELERATION
MAX_ACCELERATION =              200
STEPGEN_MAXACCEL =              400
BACKLASH = 0.1700000
SCALE =                   -133.333333333333333333333
MIN_LIMIT =                     0
MAX_LIMIT =                     257
FERROR = 26
MIN_FERROR = 0.26
HOME_OFFSET =                    0
HOME_SEARCH_VEL =                -18
HOME_LATCH_VEL =                 3
HOME_USE_INDEX =                 NO
HOME_IGNORE_LIMITS =             YES
HOME_SEQUENCE=1
#+ Second axis
[AXIS_1]
TYPE =                          LINEAR
HOME =                          290
MAX_VELOCITY =                  25
BACKLASH = 0.2000
SCALE =                   133.333333333333333333333
MIN_LIMIT =                     0
MAX_LIMIT =                     290
FERROR = 26
MIN_FERROR = 0.26
HOME_OFFSET =                    290
HOME_SEARCH_VEL =                18
HOME_LATCH_VEL =                 -3
HOME_USE_INDEX =                 NO
HOME_SEQUENCE=1
#VOLATILE_HOME=1
#+ Third axis
[AXIS_2]
TYPE =                          LINEAR
HOME =                          0
MAX_VELOCITY =                  18
STEPGEN_MAXACCEL =              800
BACKLASH = 0.1500
SCALE =                   133.33333333333333333333333
MIN_LIMIT =                     -90
MAX_LIMIT =                     0
FERROR = 26
MIN_FERROR = 0.26
HOME_OFFSET =                    0
HOME_LATCH_VEL =                 -3
HOME_USE_INDEX =                 NO
HOME_SEQUENCE=0
#+ Fourth axis
[AXIS_3]
TYPE =                          ANGULAR
WRAPPED_ROTARY = 		1
HOME =                          0
MAX_VELOCITY =                  3600
MAX_ACCELERATION =              6000
STEPGEN_MAXACCEL =              8000
BACKLASH = 0
SCALE =                   8.888888888888888
MIN_LIMIT =                     -99999999999999999999
MAX_LIMIT =                     9999999999999999999999999999
FERROR = 50
MIN_FERROR = 0.100
HOME_OFFSET =                    0
HOME_SEARCH_VEL =                0
HOME_LATCH_VEL =                 0
HOME_USE_INDEX =                 NO
HOME_IGNORE_LIMITS =             NO
HOME_SEQUENCE=0
# section for main IO controller parameters
[EMCIO]
EMCIO = 		io
CYCLE_TIME =            0.100
TOOL_TABLE =            tool.tbl
17 Dec 2014 12:53 #54082 by joekline9
Replied by joekline9 on topic Rotary axis feedrate.
You are saying 3600 degrees per sec. Do you mean per minute?
Axis displays velocity in units per minute.
For A to move 3600 deg/min is 96.0 deg / sec.
Set as below:
[DISPLAY]
MAX_ANGULAR_VELOCITY = 96.0
[AXIS 3]
MAX_VELOCITY = 96.0
17 Dec 2014 13:00 #54083 by joekline9
Sorry. I forgot you also need:
[TRAJ]
MAX_ANGULAR_VELOCITY = 96.00
17 Dec 2014 16:20 #54088 by eslavko
Replied by eslavko on topic Rotary axis feedrate.
Hello...
I mean 3600deg/sec (10 revolutions per second)
But I find other way to solve my problem with python component as I need fast data streaming too.
Slavko.
The following user(s) said Thank You: joekline9
Time to create page: 0.075 seconds
