Plotter
- Jeff-504
23 Nov 2014 06:41 - 23 Nov 2014 08:30 #53301
by Jeff-504
Plotter was created by Jeff-504
IS there some kind of plotter available for LinuxCnc
I may be wording this wrong but asking for a tool in cnc
that works like a pen
beginner here using i-picture to to convert image to .gee extension
then run and see lay out of the run with linuxcnc
but not supported
Last edit: 23 Nov 2014 08:30 by Jeff-504. Reason: no replies
- BigJohnT
- Thank you received: 1176
23 Nov 2014 20:59 #53313
by BigJohnT
Replied by BigJohnT on topic Plotter
LinuxCNC can draw lines like a plotter but you have to feed it G code.
JT
JT
- Jeff-504
01 Dec 2014 13:56 #53563
by Jeff-504
Replied by Jeff-504 on topic Plotter
understood
- Thank you received: 4967
03 Dec 2014 05:45 #53616
Replied by andypugh on topic Plotter
Possibly Gcodetools (an Inkscape plug-in).
It rather depends on if the source image is vector or raster. Raster is hard.
Time to create page: 0.070 seconds
