Package updates in 2.6
- justinj
29 Dec 2014 07:46 #54353
by justinj
Package updates in 2.6 was created by justinj
Sorry if this is a newbie question, but I'm just getting started. I saw on the downloads page that under 2.5 it says NOT to update any of the Ubuntu LTS packages, however 2.6 is built on Debian. When starting the machine up, Debian is giving me alerts that there are X amount of packages with updates, some of which are LinuxCNC updates. Which of these updates are safe to install and which should be ignored?
- emcPT
- Thank you received: 139
29 Dec 2014 15:21 #54358
by emcPT
Replied by emcPT on topic Package updates in 2.6
That is a trick question. Basically it would be safe to download all not related with LinuxCNC so that no change on your current configuration is needed. The problem is to know what is related with LinuxCNC as it uses a lot of different parts of the installed Linux.
You can also skip updating all. I doubt that you need to update any package, unless you saw a problem in general with Linux. I normally ignore updates if I feel that my machine is working stable.
- justinj
29 Dec 2014 17:34 #54359
by justinj
Replied by justinj on topic Package updates in 2.6
Is it not recommended to keep LinuxCNC updated to the latest version? I just thought it was odd that the LinuxCNC updates also appeared in there so I wasn't sure if it's changed in 2.6 with not updating.
- BigJohnT
- Thank you received: 1176
30 Dec 2014 07:33 #54393
by BigJohnT
Replied by BigJohnT on topic Package updates in 2.6
It's best to keep LinuxCNC up to date as once a major release comes out the updates are all bug fixes. So the latest version of 2.6 is 2.6.5.
JT
JT
- justinj
30 Dec 2014 12:55 #54403
by justinj
So that brings me back to the initial question, which updates in update manager should be selected?
Should I ONLY select the linuxcnc, linuxcnc-dev, linuxcnc-doc-en packages or should I be updating all available packages?
- ArcEye
- Thank you received: 758
30 Dec 2014 20:38 #54409
by ArcEye
The advice for Ubuntu was because the package manager would try to 'update' the kernel, which would delete the rtai kernel and leave the system unable to run linuxcnc.
This should not happen with the Debian distro, as the stock debian kernel is 3.2.0-4 ish and the rtai kernel is 3.4.9
I would just use the update manager, but scroll through the list first, checking there are no packages related to linux-kernel-image, kernel headers etc
The other stuff should be OK and some like bash and openssl needs updating because there are security flaws in them
Replied by ArcEye on topic Package updates in 2.6
- justinj
31 Dec 2014 06:41 #54439
by justinj
Being new to this I didn't want to spend time trying to fix something that I didn't realise I had broken by way of updates etc!
Thanks for thatThe advice for Ubuntu was because the package manager would try to 'update' the kernel, which would delete the rtai kernel and leave the system unable to run linuxcnc.
Time to create page: 0.055 seconds
