Screen (AXIS) Frozen while Running
  • Askjerry
  • Askjerry's Avatar Topic Author
  • Elite Member
  • Elite Member
02 Jan 2015 11:16 #54481 by Askjerry
Screen (AXIS) Frozen while Running was created by Askjerry
I'm running a job... 14 passes to get it done... about an hour to cut.
I'm 35 or 40 minutes into it... and I look at the screen... it is FROZEN.
The machine is still running... still cutting properly... but out of 14 passes... the screen stopped at pass #4.
???? Huh?
I hit "P" to pause... nothing.
Mouse doesn't move... like it is totally locked up. At this point... the only way to stop it would be to turn off the computer aparently. Ever happen to anyone else???
I'm going to let it finish... if it can run the remaining 10 minutes or so... the part will be done... then I'll reset the computer.
ODD!
  • Askjerry
  • Elite Member
  • Elite Member
02 Jan 2015 12:24 #54482 by Askjerry
Replied by Askjerry on topic Screen (AXIS) Frozen while Running
The job finished fine... I shut the PC down and rebooted it... normal functionalty now.
The only thing I can think of is something to do with the screensaver timing? I made some changes... hopefully it doesn't do that again... I didn't like not being able to hit the E-STOP or change the feed rate.
I mean yeah... I have a secondary kill switch on the rotary inverter and Geckodrive power suply... but wow.
02 Jan 2015 21:43 - 02 Jan 2015 21:44 #54490 by PCW
Replied by PCW on topic Screen (AXIS) Frozen while Running
If this happens again, I would suggest _not_ immediately rebooting but rather opening a terminal window
and running at least dmesg to see if there are any clues to what happened.
If your KB and mouse are not working in X, sometimes you can get an alternate console to work (control-alt-F1)
If this doesn't work, you can try a remote login.
Last edit: 02 Jan 2015 21:44 by PCW.
02 Jan 2015 21:46 #54491 by Todd Zuercher
Replied by Todd Zuercher on topic Screen (AXIS) Frozen while Running
Looks like you answered the argument for adding hard E-stop buttons.
03 Jan 2015 01:00 #54500 by cncbasher
Replied by cncbasher on topic Screen (AXIS) Frozen while Running
at least it finished the work , which is more than a windows machine would have done ..
check your graphics card.( perhaps overheating if a long job ) for instance
  • Askjerry
  • Elite Member
  • Elite Member
03 Jan 2015 02:43 #54504 by Askjerry
Oh yeah... putting them in this week. Can you imagine the Z-Axis heading for the table and NO Stop???
At least I have an ON/OFF switch for the Geckodrive power... I'll loose my homing... but save the piece and the machine!
03 Jan 2015 04:11 #54510 by newbynobi
Replied by newbynobi on topic Screen (AXIS) Frozen while Running
And please :
set up sensors and take a look at the values.
It helps me to find out, that my VGA Card did reach to high temperatures resulting in freesing the PC!
Norbert
  • Askjerry
  • Elite Member
  • Elite Member
03 Jan 2015 04:34 #54511 by Askjerry
It wasn't the video card... no response to the keyboard, no mouse. Like if you hit "P" it is a keyboard shortcut for PAUSE... but nothing... it just kept running. Like the core program was running... but nothing else. It continued for 10 minutes, the G-Code finished, and the machine stopped, mist coolant shut off... everything was fine... I just could NOT do anything to influence the machine except hod the power button until it turned off.
It was like there were two computers... one running the mill... and one running the human interface... and the human interface just went away... nobody home...
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
06 Jan 2015 08:08 #54630 by andypugh
Replied by andypugh on topic Screen (AXIS) Frozen while Running
That is pretty much exactly what you get with the real-time kernel.
If you had feed-override knobs connected to HAL via encoders then they would carry on working too. But the GUI version wouldn't work (as you found out).
It is hard to say what the problem is, it might be the graphics drivers. If it happens again then you can try running with an alternative GUI with no graphical preview and see if that avoids the problem, purely as an experimental step.
  • Askjerry
  • Elite Member
  • Elite Member
06 Jan 2015 08:19 #54633 by Askjerry
Hasn't happened again... I'm thinking I made some screensaver change that goobered it up. I set it differently now.
Time will tell eh?
Jerry
Time to create page: 0.177 seconds
