Mesa 7i77 with VFD
16 Jan 2015 02:51 - 16 Jan 2015 02:53 #55038 by tjones
Mesa 7i77 with VFD was created by tjones
Hello,
My current set up is using an analog output from the 7i77 connecting to the AI3 analog input on the GS3-2010 VFD. My problem is I have next to no control of my spindle, it's either on or off. I have the max rpm range on the VFD set to 2000rpm. I suspect the reason why I don't have any control is the scaling from LinuxCNC doesn't know max rpm. I have searched the PNCCONF and I don't know where to change this. Maybe this isn't my problem at all. Any help would be great!
Thanks,
Tosh
Last edit: 16 Jan 2015 02:53 by tjones.
16 Jan 2015 03:04 #55041 by andypugh
Replied by andypugh on topic Mesa 7i77 with VFD
I don't know where to change it in Pncconf, but if you look in the HAL file for the related "scalemax" then that needs to be 2000 rpm too.
29 Jan 2015 09:39 #55438 by tjones
Replied by tjones on topic Mesa 7i77 with VFD
File Name: ctc_mill.hal
File Size:10 KB
File Name: ctc_mill.ini
File Size:4 KB
I have uploaded the files that I thought useful and where the changes need to be made. Do I need to just change the code or add some code to set the spindle max to 2000 rpm? My coding experience is next to none and not sure what I need to do.
Thanks,
Tosh
29 Jan 2015 11:59 - 29 Jan 2015 11:59 #55439 by PCW
Replied by PCW on topic Mesa 7i77 with VFD
in your INI file, try changing this:
# Spindle
[SPINDLE_9]
OUTPUT_SCALE = .005
OUTPUT_MIN_LIMIT = -10.0
OUTPUT_MAX_LIMIT = 10.0
to this:
# Spindle
[SPINDLE_9]
OUTPUT_SCALE = 2000
OUTPUT_MIN_LIMIT = -2000
OUTPUT_MAX_LIMIT = 2000
Last edit: 29 Jan 2015 11:59 by PCW.
Time to create page: 0.057 seconds
