External control box on Serial Port
- Gloup
19 Jan 2015 19:10 #55160
by Gloup
External control box on Serial Port was created by Gloup
Hello,
I have some difficult to find some information, maybe because my english isn't enought good !
I have a CNC milling, axis controller board is plugged on parallel port and I make the configuration using stepconf. Everything is good !
Now, I want make an external control box plugged on serial port (COM1) with 6 buttons : X+ X- Y+ Y- Z+ Z-
In fact, I want do exactly the same thing that we can do with the keyboard but on a smaller box.
I imagine this function is possible. Could you give me some link to the good documentation, or some example, keywords, ...
- ArcEye
- Thank you received: 758
19 Jan 2015 19:47 #55161
by ArcEye
Replied by ArcEye on topic External control box on Serial Port
Hi
This sort of pendant is only possible if you can write a handler component which will either stuff the output into the keystroke buffer to make it a HID device, or interfaces directly with Linuxcnc via serial comms.
A USB HID device that emulates a keyboard will work 'as is', linux does not have a problem with how many 'keyboards' are connected.
A USB over serial pendant such as the Arduino also works, but again requires such a component to connect to Linuxcnc
www.linuxcnc.org/index.php/english/forum...pendant-for-linuxcnc
If you have not made this box already, I would advise that either you consider a pre-built supported pendant like the XHC
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...Wireless_MPG_Pendant
or
consider something like the arduino interface USB to UART
or
- Gloup
19 Jan 2015 23:12 #55167
by Gloup
Replied by Gloup on topic External control box on Serial Port
Ok thank you, I will look on this way.
Time to create page: 0.098 seconds
