Advice requested on 6i25/G540 Configuration
20 Jan 2015 01:30 #55177 by pws
Folks,
Now that I have resolved the latency issues, I am now on the road to having a mill that can actually do things!!
Generally, things appear to be working correctly - I have been able to run the machine through "LinuxCNC" beginning to end and all seems well.
Things seem to be slower than I expected, so I think I need to bone up on Acceleration and Velocity!
Before I start on that endeavor, I am asking if someone would review where I am at and give me some advise. I have included a ZIP if my INI and HAL files. Could I please get some input on these files?
Much appreciated!
Paul
File Name: Grizz_6i25_011915.zip
File Size:4 KB
20 Jan 2015 02:50 #55179 by PCW
Current settings are 100 IPM max velocity and 120IPM/S acceleration
Depending on gearing, axis mass, and required torque, you may be able to increase these quite a bit
(these are set in the ini file with velocity units of IPS and acceleration units of IPS/S)
20 Jan 2015 02:57 #55180 by pws
Thanks!
Do you have any suggestions for an X2 Mini-Mill, no gearing, NEMA23 381oz in, PSU 48V/12.5A
20 Jan 2015 02:58 #55181 by Todd Zuercher
Replied by Todd Zuercher on topic Advice requested on 6i25/G540 Configuration
It looks like in your ini file under DISPLAY, you have the MAX_LINEAR_VELOCITY = 1.000000 (which would be 60inches/min)
Similarly, you have the max feed for each axis set to 100 inches/min.
Those are not particularly blazing fast speeds, are they the ones you wanted?
Also your accelerations are not very high, the slower machines I have use accelerations about 3-5 times higher.
Nothing jumps out at me as wrong, (if it works it must be right) But I didn't try to run it, or look too closely.
20 Jan 2015 03:05 - 20 Jan 2015 03:16 #55182 by Todd Zuercher
You guys type faster than me,
No gearing???? What at are your screw pitches? (it counts as gearing)
Last edit: 20 Jan 2015 03:16 by Todd Zuercher.
20 Jan 2015 03:34 #55183 by pws
.200 pitch
CNCFusion Kit
20 Jan 2015 04:40 #55186 by Todd Zuercher
I would not be surprised if you could go ten times higher on acceleration (20ips/s) and maybe twice as fast on velocities (or more).
20 Jan 2015 04:42 #55187 by pws
They are not necessarily what I WANT! What I do want is to set it up to run right, and much quicker than it does as I am sure it is capable.
Thanks!
Paul
20 Jan 2015 04:53 #55188 by pws
Sounds like a great place to start!
Time to create page: 0.064 seconds
