Soft limits
- allenwg2005
- Thank you received: 4
13 Feb 2015 04:38 #55938
by allenwg2005
Soft limits was created by allenwg2005
Could someone point me to the tutorial on setting soft limits please.
- emcPT
- Thank you received: 139
13 Feb 2015 06:04 #55939
by emcPT
Replied by emcPT on topic Soft limits
Soft limits are placed on your INI file.
www.linuxcnc.org/docs/html/config/ini_config.html
see section
2.10. [AXIS_<num>] Section
see section
The following user(s) said Thank You: allenwg2005
- allenwg2005
13 Feb 2015 07:46 #55940
by allenwg2005
Replied by allenwg2005 on topic Soft limits
I beleave I have my ini file slightly screwed up.
This is a gantry router so things are backwards, it's been a struggle squaring this away.
I had it working, but I don't think it's correct, so I'm going to fix it now if I can.
Everything looks as it should on the interface (Axis), but I get the following error when homing.
"Exceeded positive soft limit on joint 2"
"Exceeded negative soft limit on joint 2"
If I reverse the symbols - and +, the machine limits on the interface are backwards.
It works like this but again, if I can correct it I would feel more secure about my set-up.
Anyone care to weigh in?
- allenwg2005
13 Feb 2015 09:20 #55941
by allenwg2005
Never mind, I got it.
Time to create page: 0.170 seconds
