corner finder
  • thor44
  • thor44's Avatar Topic Author
  • Premium Member
  • Premium Member
01 Mar 2015 10:48 #56371 by thor44
corner finder was created by thor44
does any one know if and or where I can find a plug in or something that will automatically find the edges of the work piece and set the axis to zero?
01 Mar 2015 15:36 #56372 by ArcEye
Replied by ArcEye on topic corner finder
These should cover it, plus hole probing.
timeguy.com/cradek/01262579508
01 Mar 2015 16:35 #56374 by Rick G
Replied by Rick G on topic corner finder
  • thor44
  • Premium Member
  • Premium Member
02 Mar 2015 05:39 #56387 by thor44
Replied by thor44 on topic corner finder
so I just run the script and then I'm ready to go right!.
What kind of probe do I need?
02 Mar 2015 19:26 #56399 by Rick G
02 Mar 2015 20:37 #56404 by BigJohnT
Replied by BigJohnT on topic corner finder
I use an mechanical edge finder to locate the front face of the rear vise jaw and that is always Y0. I have a 1/2" dowel that I put in the spindle and push the material up to the dowel. That is either X-0.250 or X0.250 depending on what side the dowel is on. Takes a few seconds to do. Then you can either use the paper method or a dowel to locate the Z0 for your tool.
JT
Time to create page: 0.056 seconds
