gantry
  • thor44
  • thor44's Avatar Topic Author
  • Premium Member
  • Premium Member
14 Mar 2015 10:04 #56801 by thor44
gantry was created by thor44
so I have a few questions but instead of just asking I thought I would do some snooping around and see if I could find the answers on my own but instead I found more questions. So now the question that I have is about gantry's and some kind of file in Linuxcnc that has to do with running an overhead gantry type machine. Can anyone share some light on this issue?
14 Mar 2015 18:27 #56806 by pippin88
Replied by pippin88 on topic gantry
thor,
I'm not really sure what question you are asking?
My best guess is that you are talking about machine with a gantry driven from two sides, that is two motors to drive one axis. If so I think you are referring to gantrykins?
23 Mar 2015 09:58 #57099 by yoshimitsuspeed
Replied by yoshimitsuspeed on topic gantry
Tell us more about your setup and exactly what you are trying to do.
I have a gantry setup with two steppers running my y axis. I used the simplest method of running the two motors siamesed. This is very easy to setup in stepconf but has it's limitations like not being able to home the motors separately.
At some point I would like to separate the two motors and set everything up with home switches but for now this works well enough.
