It would perform very similarly. It is possible that the commercial control might be slightly better optimised for wood routing.DuNuNuBatman wrote: How does LinuxCNC compare to commercial offerings offered by companies such as Laguna tools software controller for example?
As an example, if I were to put together a machine identical to a commercial offering, would it perform the same?
No, LinuxCNC _is_ a motion controller. It just happens to run on commodity PC hardware. It can often be helped-out by dedicated step-generation or pwm-generation hardware or hardware encoder counters, but the motion planing is still all handled by LinuxCNC.Does LinuxCNC require a hardware controller to coordinate movement between servo controllers?
Ultimately, the plan is to either get in the deep end and purchase a $125,000 router with ATC and material handling, or start smaller by building a machine with high quality electronics and a sturdy 5000lb frame and add features such as ATC and material handling as it becomes necessary or I want to start taking it on.
