Setting up a probe touch off
25 Mar 2015 22:22 #57181 by Clive S
Setting up a probe touch off was created by Clive S
I am trying to set up a probe touch off plate by following this :- 7xcnc.com/software/probing/z-touch-plate/
I am using axis but also have been playing around with gmoccapy that I want to use so some of my ini file have that stuff in as well.
I am getting an error on start up with debounce . I have attached the debug file
I am also not certain where to put the code for the custompanel.xml bit.
Thanks. Clive
File Name: Warco_18_2...3-25.ini
File Size:2 KB
File Name: custom_postgui.hal
File Size:0 KB
File Name: debug.txt
File Size:65 KB
27 Mar 2015 18:55 - 27 Mar 2015 18:58 #57232 by BigJohnT
Replied by BigJohnT on topic Setting up a probe touch off
[ 4013.613077] debounce: `' invalid for parameter `cfg'
linuxcnc.org/docs/html/man/man9/debounce.9.html
I'm pretty sure the space after the = is the problem.
JT
Last edit: 27 Mar 2015 18:58 by BigJohnT.
03 Apr 2015 10:25 #57469 by pippin88
Replied by pippin88 on topic Setting up a probe touch off
Clive,
That's my guide.
You put the custompanel code in a file called "custompanel.xml" in your config directory (same directory as your .hal and .ini files).
The 100.ngc file must be in your GCode directory (not your config directory)
03 Apr 2015 15:42 #57474 by Clive S
Replied by Clive S on topic Setting up a probe touch off
Clive,
That's my guide.
Thanks for getting back to me. Funny thing is that I have just read the whole of the thread (about 21 pages) over on the zone.
I am using Linuxcnc version 2.8.0-pre and I have a feeling some things have changed regarding the panel.
I am still have trouble with errors like this Debug file information:
./my-mill.hal:45: Signal 'probe-in' can not add OUT pin 'parport.0.pin-15-in', it already has OUT pin 'debounce.0.0.out'
I am going to set up a new my-mill profile as a test without any homing switches etc and start from scratch again and report back
The profile for my Warco mill using Gmoccappy as the display is working fine. (I did comment out the gmoccapy so that I was using axis in the ini file)
Clive
03 Apr 2015 16:24 #57476 by pippin88
So does the Touch off plate work with Gmoccapy? I haven't tried using pyvcp with Gmoccapy, so don't have any experience.
You could try:
net debounce.0.0.out => motion.probe-input
in place of
net probe-in debounce.0.0.out
net probe-in => motion.probe-input
Can you post up your most current hal file. I can't see why you would get that error from the hal file you posted earlier.
03 Apr 2015 17:26 #57478 by Clive S
quote [So does the Touch off plate work with Gmoccapy? I haven't tried using pyvcp with Gmoccapy, so don't have any experience.
Gmoccapy does not use the Axis screen and I don't think there is a touch off plate in it yet. But the good people are working on touch off buttons to go with the gmoccapy screen. www.linuxcnc.org/index.php/english/forum...ing-tab?limitstart=0
I will repost the files later after I have done what you have suggested above and see if that cures the errors. Thanks Clive
03 Apr 2015 18:57 - 03 Apr 2015 18:57 #57480 by Clive S
Ok I have attached two sets of files. Not sure if I can attach zips
With the Warco it seem that there is a problem with the line:
Can not find -sec APPLICATIONS -var DELAY -num 1
custom_postgui.hal:6: Pin 'halui.mdi-command-00' does not exist
If I comment the line out in custom_postgui: net remote-o100 halui.mdi-command-00 <= pyvcp.o100 Then Axis will start up.
The my-mill profile:-
custom_postgui.hal:14: Pin 'halui.mdi-command-00' does not exist
The my-mil profile was a test with a completely new profile as I had modified the Warco profile with the gmocappy stuf
Clive
Last edit: 03 Apr 2015 18:57 by Clive S.
03 Apr 2015 19:02 - 03 Apr 2015 19:06 #57481 by Clive S
Ok not sure how to attach zips.
so here they are as separate files
(my_mill first)
File Name: custom.hal
File Size:0 KB
File Name: custom_pos...4-03.hal
File Size:1 KB
File Name: custompanel.xml
File Size:1 KB
File Name: Debugmy-mill.txt
File Size:60 KB
File Name: my-mill.hal
File Size:3 KB
File Name: my-mill.ini
File Size:2 KB
(Warco mill)
Last edit: 03 Apr 2015 19:06 by Clive S. Reason: added files
03 Apr 2015 19:04 - 03 Apr 2015 19:04 #57482 by pippin88
Clive,
Is there a reason that you are using a pre-release / developmental version of LinuxCNC? I would think it makes things harder unless you are fairly experienced.
A few things:
This Z-Axis touch off method is not specific to the 'Axis' GUI at all. It just uses a virtual control panel (in this case pyvcp) to trigger a hal pin. You can do it with GladeVCP also. Gmoccapy has inbuilt support for GladeVCP.
I believe you can attach zips.
Your problem is likely your typo in your .ini file
You have:
"MIDI_COMMAND = o100 call" (there is an extra i in there)
It should be:
"MDI_COMMAND = o100 call"
Last edit: 03 Apr 2015 19:04 by pippin88.
03 Apr 2015 19:13 #57483 by Clive S
quote Is there a reason that you are using a pre-release / developmental version of LinuxCNC? I would think it makes things harder unless you are fairly experienced
I installed from here www.linuxcnc.org/index.php/english/download 2.6 then updated with sudo apt and it brought it up to version 2.8.0
Silly me I will go and alter it.
Many thanks for helping me out with this. Clive
Time to create page: 0.190 seconds
