asm/msr.h and ac_nonexistent.h not found
- chenaichenluo
22 Apr 2015 12:53 #57990
by chenaichenluo
asm/msr.h and ac_nonexistent.h not found was created by chenaichenluo
hello everyone ,
when i run ./configure --enable -simulator of emc2.4.3, there are two fatal errors in config.log:
conftest.c:10: fatal error: ac_nonexistent.h: No such file or directory
conftest.c:11: fatal error: asm/msr.h: No such file or directory
can anyone help me out?
- ArcEye
- Thank you received: 758
22 Apr 2015 13:26 #57992
by ArcEye
Replied by ArcEye on topic asm/msr.h and ac_nonexistent.h not found
Hi
If this is related to your previous posts, you are trying to build a simulator version of practically defunct version of linuxcnc, on a machine with an ARM7 processor, in order to run a real machine config on it.
It is just not going to work.
Might I suggest that instead of asking us how to get the wrong approach to work, you actually tell us what the end aim is and we can advise how best to achieve it.
- ArcEye
22 Apr 2015 14:46 - 23 Apr 2015 13:38 #57994
by ArcEye
To flesh it, to show I am not simply being negative.
A simulator, simulates the movements of a machine, in terms of axes at least.
You cannot run a configuration which has an IO card, servo amps, servos, PID tuning of those servos, encoders, home switches etc etc in a simulator.
The required inputs and output feedbacks are not present.
Linuxcnc does not support ARM.
That does not mean that with sufficient knowledge you cannot get it to run on ARM, you just won't get any support for it.
2.4.3 is now very old.
Besides any bugfixes and improvements you will be missing, there are also possible kernel specific assumptions in the code.
Starting somewhere in the 2.6.X kernels for instance, the includes were changed and the /asm /bits /gnu and /sys subdirs were moved out of the main /usr/include dir and into sub dirs within a dir named based upon the
kernel type eg /x86_amd64-linux-gnu on this machine
When this first happened, builds of linuxcnc failed all the time for being unable to find includes.
If you just want to simulate and test gcode, build a new version of Linuxcnc as a simulator, on a x86 based computer and it will be trivial.
EDIT: Or you could just install a package, I often forget about them
because I never use them
If you want to do something else, you will have to spell it out and we can tell you if it is possible and if so point you in the right direction.
Last edit: 23 Apr 2015 13:38 by ArcEye.
Time to create page: 0.049 seconds
