joint 0 on limit switch error
- Thank you received: 4652
02 Feb 2019 15:05 #125542
Replied by andypugh on topic joint 0 on limit switch error
Add an input filter to the VFD supply. (Search eBay for “Rasmi”) and / or low-pass filter the limit signals in HAL.
The following user(s) said Thank You: daxur666
- Leon82
- Thank you received: 79
02 Feb 2019 15:59 - 02 Feb 2019 16:00 #125545
by Leon82
I had the same issue I had to put a home offset in.
It looks like yours is with one of the axes limit switches
Replied by Leon82 on topic joint 0 on limit switch error
Hello, sorry to bother, I have the same issue, when I start the spindle I get "joint 0,1,2 on limit switch error", I am using pin 11, 12 and 13 as "Both Limit + Home" for Z, Y and X axis, I am controlling spindle speed directly from the VFD.
Last edit: 02 Feb 2019 16:00 by Leon82.
- daxur666
04 Feb 2019 16:08 #125663
by daxur666
Replied by daxur666 on topic joint 0 on limit switch error
I will check, thank you for the help.
Time to create page: 0.152 seconds
