32 or 64 bit install
05 May 2015 08:02 #58391 by jpchi58
32 or 64 bit install was created by jpchi58
Trying to install after making disk and my computer asks if I want to continue sith the 32 bit install
05 May 2015 10:43 #58393 by JoeHildreth
Replied by JoeHildreth on topic 32 or 64 bit install
I believe both the Ubuntu and Hybrid Debian installs are 32 bit. You should have no problems running the 32 bit software on a 64 bit machine. Unless you have more than 4GB RAM installed, then you can only access the first 4GB. Still that isn't an issue running LinuxCNC.
Joe
Time to create page: 0.054 seconds
