Y-axis motor turns one direction
- awilcox
30 May 2015 23:36 #59235
by awilcox
Y-axis motor turns one direction was created by awilcox
I have used emc2 for 5 years with no issues. I replaced the z-axis controller and ran the stepconfig file. I attempted to home the machine and my y-axis motor only moves in the negative direction. I compared the new stepconfig to the original one and the values are the same.
I downloaded the 2.5 iso to see if the problem would go away but it didn't. What am I missing?
Background info:
Ubuntu 10.4
Emc2 2.4.3
Drivers: oms mh10
Background info:
Ubuntu 10.4
Emc2 2.4.3
Drivers: oms mh10
- BigJohnT
- Thank you received: 1176
31 May 2015 01:12 #59236
by BigJohnT
Replied by BigJohnT on topic Y-axis motor turns one direction
Check your Y axis direction pin connections.
JT
JT
- awilcox
03 Jun 2015 18:50 #59372
by awilcox
Replied by awilcox on topic Y-axis motor turns one direction
John,
I rechecked all connections and the problem appears to be the controller. I switched connections with a working axis and the motor work perfectly. I then switched the step/direction connection and it continued to work.
I ordered another controller (Centent 142) and installed it Saturday. Much to my surprise, I have a new issue. The motor makes a loud hammering sound and barely turns. In fact it will turn both directions. I installed the controller on the z-axis and it did the same thing. I am hoping for a senior moment and not another bad axis.
What am I missing?
Thanks for your help!
Adrian
What am I missing?
Adrian
- BigJohnT
03 Jun 2015 19:11 #59373
by BigJohnT
I don't know what a Centent 142 drive costs but
Gecko 203v
drives are bullet proof and just work for me. If you swap the drive and the problem follows the drive you know the answer...
JT
JT
The following user(s) said Thank You: awilcox
- Thank you received: 4966
04 Jun 2015 05:26 #59407
Replied by andypugh on topic Y-axis motor turns one direction
Are you sure that your step-timing is correct for the Centent drive?
Try some really long numbers (25,000) and see what happens.
- awilcox
04 Jun 2015 06:03 #59410
by awilcox
Andy,
I will give that a try. My understanding is centent drives are nearly identical to Oregon micro system drives. This driver placement for the centent. I will give it a try and report back.
Adrian
Adrian
Time to create page: 0.132 seconds
