VOLATILE HOME
- allenwg2005
- Thank you received: 4
31 May 2015 04:43 #59250
by allenwg2005
VOLATILE HOME was created by allenwg2005
I hope this is an appropriate place to post this question.
I'm not finding much on the subject of VOLATILE_HOME on the forum.
Can someone point me in the direction of good documentation for this, it might be useful.
- BigJohnT
- Thank you received: 1176
31 May 2015 04:56 #59251
by BigJohnT
Replied by BigJohnT on topic VOLATILE HOME
The manual is usually the best place to start reading about anything.
linuxcnc.org/docs/html/config/ini_config.html#sub:AXIS-section
JT
JT
The following user(s) said Thank You: allenwg2005
- allenwg2005
31 May 2015 05:40 #59256
by allenwg2005
Replied by allenwg2005 on topic VOLATILE HOME
Thanks John,
I was hoping for a bit more information, is this it?
I am running steppers so I would imagine this woulod be helpful, or is it?
- BigJohnT
31 May 2015 17:56 #59263
by BigJohnT
That pretty much sums it up, on a stepper axis I'd set it to 1.
JT
JT
Time to create page: 0.048 seconds
