Threading G76 with spindle in reverse
09 Jul 2015 15:35 #60537 by cncbasher
Replied by cncbasher on topic Threading G76 with spindle in reverse
regarding the ratchet and pawl , as your cutting in reverse , all the forces will now be on the gearing , and the motor shaft
due to the gear ratio it should be able to take the load of cutting light loads such as threading say metric threads , but yes i'd be careful
if i get a chance i'll try and see if i can measure encountered forces
Time to create page: 0.044 seconds
