5i25 + 7i77 installation problems
- automaticon
15 Jun 2015 21:28 - 15 Jun 2015 22:20 #59849
by automaticon
5i25 + 7i77 installation problems was created by automaticon
Hello Friends,
I tried to set-up using pncconfig a cnc machine with 3 Axes. I din't used inputs or outputs to can understand how the closed loop is working.
In any configuration I done have the same error, the 5i25 driver is not installing because I set-up 3 encoders and they are only 2 available. Can somebody help me. I attached the error file for the refference.
Thank's
Claudiu
Thank's
Claudiu
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.8
Machine configuration directory is '/home/atm/linuxcnc/configs/AXA'
Machine configuration file is 'AXA.ini'
INIFILE=/home/atm/linuxcnc/configs/AXA/AXA.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=7686
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko: Invalid parameters
AXA.hal:9: exit value: 1
AXA.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
7686
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003f6f0000 (usable)
[ 0.000000] BIOS-e820: 000000003f6f0000 - 000000003f6fb000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003f6fb000 - 000000003f700000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003f700000 - 0000000040000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb80000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: FUJITSU SIEMENS ESPRIMO C/D1784 , BIOS 5.00 R1.13.1784 06/17/2005
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3f6f0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 03F800000 mask FFF800000 uncachable
[ 0.000000] 2 base 03F700000 mask FFFF00000 uncachable
[ 0.000000] 3 base 03F800000 mask FFF800000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f71a0] f71a0
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36532000 - 37291000
[ 0.000000] ACPI: RSDP 000f7200 00024 (v02 PTLTD )
[ 0.000000] ACPI: XSDT 3f6f653e 00054 (v01 PTLTD ? XSDT 00050000 LTP 00000000)
[ 0.000000] ACPI: FACP 3f6f6606 000F4 (v03 FSC \xffffffff\xfffffff6r\xffffffff\xfffffff5\xffffffed\xffffffff\xfffffffc 00050000 000F4240)
[ 0.000000] ACPI: DSDT 3f6f66fa 0463B (v01 FSC D1784 00050000 MSFT 02000002)
[ 0.000000] ACPI: FACS 3f6fbfc0 00040
[ 0.000000] ACPI: ASF! 3f6fad35 00085 (v16 OEMID OEMTBL 00050000 PTL 00000001)
[ 0.000000] ACPI: SSDT 3f6fadba 0017C (v01 FSC EISTCPU0 00050000 CSF 00000001)
[ 0.000000] ACPI: MCFG 3f6faf36 00040 (v01 PTLTD MCFG 00050000 LTP 00000000)
[ 0.000000] ACPI: APIC 3f6faf76 00062 (v01 FSC ? APIC 00050000 CSF 00000000)
[ 0.000000] ACPI: BOOT 3f6fafd8 00028 (v01 PTLTD $SBFTBL$ 00050000 LTP 00000001)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 126MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003f6f0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003f6f0
[ 0.000000] On node 0 totalpages: 259711
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5d42200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 254 pages used for memmap
[ 0.000000] HighMem zone: 32244 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0xf008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 1 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000dc000
[ 0.000000] PM: Registered nosave memory: 00000000000dc000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:bec00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77d5000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257681
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=8b68111b-f7e4-45d9-8a86-45ad75d947ff ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2078464 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003f6f0)
[ 0.000000] Memory: 1008168k/1039296k available (3495k kernel code, 30676k reserved, 1237k data, 416k init, 129992k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f5808000 soft=f580a000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 3192.011 MHz processor.
[ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 6384.02 BogoMIPS (lpj=12768044)
[ 0.004010] pid_max: default: 32768 minimum: 301
[ 0.004082] Security Framework initialized
[ 0.004088] AppArmor: AppArmor disabled by boot time parameter
[ 0.004117] Mount-cache hash table entries: 512
[ 0.004404] Initializing cgroup subsys cpuacct
[ 0.004408] Initializing cgroup subsys memory
[ 0.004422] Initializing cgroup subsys devices
[ 0.004427] Initializing cgroup subsys freezer
[ 0.004430] Initializing cgroup subsys net_cls
[ 0.004433] Initializing cgroup subsys blkio
[ 0.004446] Initializing cgroup subsys perf_event
[ 0.004496] CPU: Physical Processor ID: 0
[ 0.004499] CPU: Processor Core ID: 0
[ 0.004503] mce: CPU supports 4 MCE banks
[ 0.004515] CPU0: Thermal monitoring enabled (TM1)
[ 0.004596] SMP alternatives: switching to UP code
[ 0.011605] ACPI: Core revision 20120320
[ 0.016071] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.016447] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.057213] CPU0: Intel(R) Pentium(R) 4 CPU 3.20GHz stepping 03
[ 0.060003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.060003] ... version: 0
[ 0.060003] ... bit width: 40
[ 0.060003] ... generic registers: 18
[ 0.060003] ... value mask: 000000ffffffffff
[ 0.060003] ... max period: 0000007fffffffff
[ 0.060003] ... fixed-purpose events: 0
[ 0.060003] ... event mask: 000000000003ffff
[ 0.068033] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.068094] Brought up 1 CPUs
[ 0.068104] Total of 1 processors activated (6384.02 BogoMIPS).
[ 0.069103] devtmpfs: initialized
[ 0.069496] PM: Registering ACPI NVS region [mem 0x3f6fb000-0x3f6fffff] (20480 bytes)
[ 0.069654] dummy:
[ 0.069744] NET: Registered protocol family 16
[ 0.069946] ACPI: bus type pci registered
[ 0.070039] PCI: MMCONFIG for domain 0000 [bus 00-0a] at [mem 0xd0000000-0xd0afffff] (base 0xd0000000)
[ 0.070045] PCI: not using MMCONFIG
[ 0.070239] PCI: PCI BIOS revision 2.10 entry at 0xfd89b, last bus=11
[ 0.070242] PCI: Using configuration type 1 for base access
[ 0.071208] bio: create slab <bio-0> at 0
[ 0.071354] ACPI: Added _OSI(Module Device)
[ 0.071359] ACPI: Added _OSI(Processor Device)
[ 0.071363] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.071367] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.073072] ACPI: EC: Look up EC in DSDT
[ 0.079274] ACPI: Interpreter enabled
[ 0.079291] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.079347] ACPI: Using IOAPIC for interrupt routing
[ 0.079379] PCI: MMCONFIG for domain 0000 [bus 00-0a] at [mem 0xd0000000-0xd0afffff] (base 0xd0000000)
[ 0.080872] PCI: MMCONFIG at [mem 0xd0000000-0xd0afffff] reserved in ACPI motherboard resources
[ 0.080877] PCI: Using MMCONFIG for extended config space
[ 0.088708] ACPI: No dock devices found.
[ 0.088718] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.088891] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.089190] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.089196] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.089200] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.089204] pci_root PNP0A08:00: host bridge window [mem 0x000c8000-0x000dffff] (ignored)
[ 0.089208] pci_root PNP0A08:00: host bridge window [mem 0x40000000-0xcfffffff] (ignored)
[ 0.089212] pci_root PNP0A08:00: host bridge window [mem 0xe0000000-0xfebfffff] (ignored)
[ 0.089216] pci_root PNP0A08:00: host bridge window [mem 0xfed00400-0xfedfffff] (ignored)
[ 0.089221] pci_root PNP0A08:00: host bridge window [mem 0xfef00000-0xffafffff] (ignored)
[ 0.089225] pci_root PNP0A08:00: host bridge window [mem 0xffc00000-0xffefffff] (ignored)
[ 0.089229] PCI: root bus 00: using default resources
[ 0.089283] PCI host bridge to bus 0000:00
[ 0.089288] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.089293] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.089310] pci 0000:00:00.0: [8086:2580] type 00 class 0x060000
[ 0.089373] pci 0000:00:02.0: [8086:2582] type 00 class 0x030000
[ 0.089391] pci 0000:00:02.0: reg 10: [mem 0xf0000000-0xf007ffff]
[ 0.089401] pci 0000:00:02.0: reg 14: [io 0x1000-0x1007]
[ 0.089411] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff pref]
[ 0.089421] pci 0000:00:02.0: reg 1c: [mem 0xf0080000-0xf00bffff]
[ 0.089500] pci 0000:00:1c.0: [8086:2660] type 01 class 0x060400
[ 0.089576] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.089613] pci 0000:00:1c.1: [8086:2662] type 01 class 0x060400
[ 0.089689] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.089722] pci 0000:00:1c.2: [8086:2664] type 01 class 0x060400
[ 0.089797] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.089831] pci 0000:00:1c.3: [8086:2666] type 01 class 0x060400
[ 0.089906] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.089939] pci 0000:00:1d.0: [8086:2658] type 00 class 0x0c0300
[ 0.089992] pci 0000:00:1d.0: reg 20: [io 0x2400-0x241f]
[ 0.090033] pci 0000:00:1d.1: [8086:2659] type 00 class 0x0c0300
[ 0.090086] pci 0000:00:1d.1: reg 20: [io 0x2800-0x281f]
[ 0.090125] pci 0000:00:1d.2: [8086:265a] type 00 class 0x0c0300
[ 0.090177] pci 0000:00:1d.2: reg 20: [io 0x2c00-0x2c1f]
[ 0.090219] pci 0000:00:1d.3: [8086:265b] type 00 class 0x0c0300
[ 0.090272] pci 0000:00:1d.3: reg 20: [io 0x3000-0x301f]
[ 0.090322] pci 0000:00:1d.7: [8086:265c] type 00 class 0x0c0320
[ 0.090347] pci 0000:00:1d.7: reg 10: [mem 0xf00c0000-0xf00c03ff]
[ 0.090435] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.090464] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.090538] pci 0000:00:1e.2: [8086:266e] type 00 class 0x040100
[ 0.090558] pci 0000:00:1e.2: reg 10: [io 0x3800-0x38ff]
[ 0.090570] pci 0000:00:1e.2: reg 14: [io 0x3400-0x343f]
[ 0.090583] pci 0000:00:1e.2: reg 18: [mem 0xf00c0800-0xf00c09ff]
[ 0.090595] pci 0000:00:1e.2: reg 1c: [mem 0xf00c0400-0xf00c04ff]
[ 0.090642] pci 0000:00:1e.2: PME# supported from D0 D3hot D3cold
[ 0.090673] pci 0000:00:1f.0: [8086:2640] type 00 class 0x060100
[ 0.090772] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.090783] pci 0000:00:1f.0: quirk: [io 0xf000-0xf07f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.090790] pci 0000:00:1f.0: quirk: [io 0xf180-0xf1bf] claimed by ICH6 GPIO
[ 0.090796] pci 0000:00:1f.0: LPC Generic IO decode 1 PIO at 0800-087f
[ 0.090823] pci 0000:00:1f.2: [8086:2651] type 00 class 0x010180
[ 0.090843] pci 0000:00:1f.2: reg 10: [io 0x0000-0x0007]
[ 0.090855] pci 0000:00:1f.2: reg 14: [io 0x0000-0x0003]
[ 0.090866] pci 0000:00:1f.2: reg 18: [io 0x0000-0x0007]
[ 0.090878] pci 0000:00:1f.2: reg 1c: [io 0x0000-0x0003]
[ 0.090889] pci 0000:00:1f.2: reg 20: [io 0x4000-0x400f]
[ 0.090928] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.090951] pci 0000:00:1f.3: [8086:266a] type 00 class 0x0c0500
[ 0.091014] pci 0000:00:1f.3: reg 20: [io 0x3c00-0x3c1f]
[ 0.091134] pci 0000:03:00.0: [14e4:1677] type 00 class 0x020000
[ 0.091165] pci 0000:03:00.0: reg 10: [mem 0xf0100000-0xf010ffff 64bit]
[ 0.091277] pci 0000:03:00.0: PME# supported from D3hot D3cold
[ 0.091303] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.091320] pci 0000:00:1c.0: PCI bridge to [bus 03-03]
[ 0.091329] pci 0000:00:1c.0: bridge window [mem 0xf0100000-0xf01fffff]
[ 0.091390] pci 0000:00:1c.1: PCI bridge to [bus 05-05]
[ 0.091453] pci 0000:00:1c.2: PCI bridge to [bus 07-07]
[ 0.091515] pci 0000:00:1c.3: PCI bridge to [bus 09-09]
[ 0.091575] pci 0000:0b:05.0: [2718:5125] type 00 class 0x110000
[ 0.091597] pci 0000:0b:05.0: reg 10: [mem 0xf0200000-0xf020ffff]
[ 0.091730] pci 0000:00:1e.0: PCI bridge to [bus 0b-0b] (subtractive decode)
[ 0.091739] pci 0000:00:1e.0: bridge window [mem 0xf0200000-0xf02fffff]
[ 0.091748] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.091752] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.091782] pci_bus 0000:00: on NUMA node 0
[ 0.091788] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.092204] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEXB._PRT]
[ 0.092341] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEXC._PRT]
[ 0.092476] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEXD._PRT]
[ 0.092611] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEXE._PRT]
[ 0.092785] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIH._PRT]
[ 0.093226] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.102620] ACPI: PCI Interrupt Link [LNKA] (IRQs *9 10 11)
[ 0.102757] ACPI: PCI Interrupt Link [LNKB] (IRQs 9 10 11) *5
[ 0.102893] ACPI: PCI Interrupt Link [LNKC] (IRQs 9 10 *11)
[ 0.103027] ACPI: PCI Interrupt Link [LNKD] (IRQs *9 10 11)
[ 0.103160] ACPI: PCI Interrupt Link [LNKE] (IRQs 9 10 *11)
[ 0.103294] ACPI: PCI Interrupt Link [LNKF] (IRQs *9 10 11)
[ 0.103427] ACPI: PCI Interrupt Link [LNKG] (IRQs 9 *10 11)
[ 0.103561] ACPI: PCI Interrupt Link [LNKH] (IRQs 9 10 *11)
[ 0.103689] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.103707] vgaarb: loaded
[ 0.103710] vgaarb: bridge control possible 0000:00:02.0
[ 0.103763] PCI: Using ACPI for IRQ routing
[ 0.103952] PCI: pci_cache_line_size set to 64 bytes
[ 0.104062] reserve RAM buffer: 000000000009f800 - 000000000009ffff
[ 0.104067] reserve RAM buffer: 000000003f6f0000 - 000000003fffffff
[ 0.104340] hpet clockevent registered
[ 0.104350] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.104360] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.106380] Switching to clocksource hpet
[ 0.106461] pnp: PnP ACPI init
[ 0.106480] ACPI: bus type pnp registered
[ 0.106668] pnp 00:00: [bus 00-ff]
[ 0.106674] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.106678] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.106683] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.106687] pnp 00:00: [mem 0x000c8000-0x000dffff window]
[ 0.106691] pnp 00:00: [mem 0x40000000-0xcfffffff window]
[ 0.106695] pnp 00:00: [mem 0xe0000000-0xfebfffff window]
[ 0.106699] pnp 00:00: [mem 0xfed00400-0xfedfffff window]
[ 0.106703] pnp 00:00: [mem 0xfef00000-0xffafffff window]
[ 0.106707] pnp 00:00: [mem 0xffc00000-0xffefffff window]
[ 0.106711] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.106780] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.106970] pnp 00:01: [io 0x0cb0-0x0cbb]
[ 0.107044] system 00:01: [io 0x0cb0-0x0cbb] has been reserved
[ 0.107051] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.107343] pnp 00:02: [mem 0xffb00000-0xffbfffff]
[ 0.107399] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.107596] pnp 00:03: [io 0x0010-0x001f]
[ 0.107601] pnp 00:03: [io 0x0022-0x002d]
[ 0.107605] pnp 00:03: [io 0x0030-0x003f]
[ 0.107608] pnp 00:03: [io 0x0050-0x0053]
[ 0.107612] pnp 00:03: [io 0x0062-0x0063]
[ 0.107615] pnp 00:03: [io 0x0065-0x006f]
[ 0.107619] pnp 00:03: [io 0x0074-0x007f]
[ 0.107622] pnp 00:03: [io 0x0090-0x009f]
[ 0.107626] pnp 00:03: [io 0x00a2-0x00b1]
[ 0.107629] pnp 00:03: [io 0x00b2-0x00b3]
[ 0.107633] pnp 00:03: [io 0x00b4-0x00bf]
[ 0.107636] pnp 00:03: [io 0x00ec-0x00ef]
[ 0.107640] pnp 00:03: [io 0x0072-0x0073]
[ 0.107643] pnp 00:03: [io 0x002e-0x002f]
[ 0.107647] pnp 00:03: [io 0x04d0-0x04d1]
[ 0.107651] pnp 00:03: [io 0xf000-0xf07f]
[ 0.107654] pnp 00:03: [io 0xf100-0xf10f]
[ 0.107658] pnp 00:03: [io 0xf180-0xf1bf]
[ 0.107661] pnp 00:03: [io 0x0800-0x087f]
[ 0.107665] pnp 00:03: [io 0xf820-0xf82f]
[ 0.107668] pnp 00:03: [io 0xfe00]
[ 0.107672] pnp 00:03: [mem 0xfec00000-0xfecfffff]
[ 0.107676] pnp 00:03: [mem 0xfee00000-0xfeefffff]
[ 0.107680] pnp 00:03: [mem 0xfebfc000-0xfebfffff]
[ 0.107683] pnp 00:03: [mem 0xfed13000-0xfed13fff]
[ 0.107687] pnp 00:03: [mem 0xfed14000-0xfed17fff]
[ 0.107691] pnp 00:03: [mem 0xfed18000-0xfed18fff]
[ 0.107694] pnp 00:03: [mem 0xfed19000-0xfed19fff]
[ 0.107698] pnp 00:03: [mem 0xd0000000-0xdfffffff]
[ 0.107803] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.107809] system 00:03: [io 0xf000-0xf07f] has been reserved
[ 0.107813] system 00:03: [io 0xf100-0xf10f] has been reserved
[ 0.107818] system 00:03: [io 0xf180-0xf1bf] has been reserved
[ 0.107822] system 00:03: [io 0x0800-0x087f] has been reserved
[ 0.107826] system 00:03: [io 0xf820-0xf82f] has been reserved
[ 0.107831] system 00:03: [io 0xfe00] has been reserved
[ 0.107837] system 00:03: [mem 0xfec00000-0xfecfffff] could not be reserved
[ 0.107841] system 00:03: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.107846] system 00:03: [mem 0xfebfc000-0xfebfffff] has been reserved
[ 0.107851] system 00:03: [mem 0xfed13000-0xfed13fff] has been reserved
[ 0.107855] system 00:03: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.107860] system 00:03: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.107865] system 00:03: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.107869] system 00:03: [mem 0xd0000000-0xdfffffff] has been reserved
[ 0.107874] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.107900] pnp 00:04: [io 0x0000-0x000f]
[ 0.107905] pnp 00:04: [io 0x0080-0x008f]
[ 0.107908] pnp 00:04: [io 0x00c0-0x00df]
[ 0.107912] pnp 00:04: [dma 4]
[ 0.107968] pnp 00:04: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.107968] pnp 00:05: [io 0x0070-0x0071]
[ 0.107968] pnp 00:05: [irq 8]
[ 0.107968] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.107968] pnp 00:06: [io 0x00f0-0x00fe]
[ 0.107968] pnp 00:06: [irq 13]
[ 0.107968] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.107968] pnp 00:07: [io 0x0061]
[ 0.107968] pnp 00:07: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.107968] pnp 00:08: [io 0x0060]
[ 0.107968] pnp 00:08: [io 0x0064]
[ 0.107968] pnp 00:08: [irq 1]
[ 0.107968] pnp 00:08: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.107968] pnp 00:09: [irq 12]
[ 0.107968] pnp 00:09: Plug and Play ACPI device, IDs PNP0f13 (active)
[ 0.107968] pnp 00:0a: [io 0x0378-0x037f]
[ 0.107968] pnp 00:0a: [io 0x0778-0x077f]
[ 0.107968] pnp 00:0a: [irq 7]
[ 0.107968] pnp 00:0a: [dma 3]
[ 0.107968] pnp 00:0a: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.107968] pnp 00:0b: [io 0x03f8-0x03ff]
[ 0.107968] pnp 00:0b: [irq 4]
[ 0.107968] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.107968] pnp 00:0c: [io 0x02f8-0x02ff]
[ 0.107968] pnp 00:0c: [irq 3]
[ 0.107968] pnp 00:0c: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.107968] pnp: PnP ACPI: found 13 devices
[ 0.107968] ACPI: ACPI bus type pnp unregistered
[ 0.107968] PnPBIOS: Disabled by ACPI PNP
[ 0.145148] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 0.145156] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 0.145169] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 05-05] add_size 1000
[ 0.145175] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05-05] add_size 200000
[ 0.145180] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff] to [bus 05-05] add_size 200000
[ 0.145192] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 07-07] add_size 1000
[ 0.145197] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 07-07] add_size 200000
[ 0.145202] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff] to [bus 07-07] add_size 200000
[ 0.145214] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 09-09] add_size 1000
[ 0.145219] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 09-09] add_size 200000
[ 0.145224] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 09-09] add_size 200000
[ 0.145253] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.145258] pci 0000:00:1c.1: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.145262] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.145267] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.145271] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.145276] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.145280] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.145285] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.145289] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.145293] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.145297] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.145304] pci 0000:00:1c.0: BAR 15: assigned [mem 0x40000000-0x401fffff 64bit pref]
[ 0.145309] pci 0000:00:1c.1: BAR 14: assigned [mem 0x40200000-0x403fffff]
[ 0.145314] pci 0000:00:1c.1: BAR 15: assigned [mem 0x40400000-0x405fffff 64bit pref]
[ 0.145318] pci 0000:00:1c.2: BAR 14: assigned [mem 0x40600000-0x407fffff]
[ 0.145323] pci 0000:00:1c.2: BAR 15: assigned [mem 0x40800000-0x409fffff 64bit pref]
[ 0.145328] pci 0000:00:1c.3: BAR 14: assigned [mem 0x40a00000-0x40bfffff]
[ 0.145332] pci 0000:00:1c.3: BAR 15: assigned [mem 0x40c00000-0x40dfffff 64bit pref]
[ 0.145337] pci 0000:00:1c.0: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.145342] pci 0000:00:1c.1: BAR 13: assigned [io 0x6000-0x6fff]
[ 0.145347] pci 0000:00:1c.2: BAR 13: assigned [io 0x7000-0x7fff]
[ 0.145351] pci 0000:00:1c.3: BAR 13: assigned [io 0x8000-0x8fff]
[ 0.145363] pci 0000:00:1c.0: PCI bridge to [bus 03-03]
[ 0.145369] pci 0000:00:1c.0: bridge window [io 0x5000-0x5fff]
[ 0.145376] pci 0000:00:1c.0: bridge window [mem 0xf0100000-0xf01fffff]
[ 0.145382] pci 0000:00:1c.0: bridge window [mem 0x40000000-0x401fffff 64bit pref]
[ 0.145391] pci 0000:00:1c.1: PCI bridge to [bus 05-05]
[ 0.145396] pci 0000:00:1c.1: bridge window [io 0x6000-0x6fff]
[ 0.145403] pci 0000:00:1c.1: bridge window [mem 0x40200000-0x403fffff]
[ 0.145409] pci 0000:00:1c.1: bridge window [mem 0x40400000-0x405fffff 64bit pref]
[ 0.145418] pci 0000:00:1c.2: PCI bridge to [bus 07-07]
[ 0.145422] pci 0000:00:1c.2: bridge window [io 0x7000-0x7fff]
[ 0.145429] pci 0000:00:1c.2: bridge window [mem 0x40600000-0x407fffff]
[ 0.145435] pci 0000:00:1c.2: bridge window [mem 0x40800000-0x409fffff 64bit pref]
[ 0.145444] pci 0000:00:1c.3: PCI bridge to [bus 09-09]
[ 0.145449] pci 0000:00:1c.3: bridge window [io 0x8000-0x8fff]
[ 0.145456] pci 0000:00:1c.3: bridge window [mem 0x40a00000-0x40bfffff]
[ 0.145462] pci 0000:00:1c.3: bridge window [mem 0x40c00000-0x40dfffff 64bit pref]
[ 0.145470] pci 0000:00:1e.0: PCI bridge to [bus 0b-0b]
[ 0.145478] pci 0000:00:1e.0: bridge window [mem 0xf0200000-0xf02fffff]
[ 0.145512] pci 0000:00:1c.1: enabling device (0100 -> 0103)
[ 0.145534] pci 0000:00:1c.2: enabling device (0100 -> 0103)
[ 0.145553] pci 0000:00:1c.3: enabling device (0100 -> 0103)
[ 0.145574] pci 0000:00:1e.0: setting latency timer to 64
[ 0.145582] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.145587] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.145591] pci_bus 0000:03: resource 0 [io 0x5000-0x5fff]
[ 0.145594] pci_bus 0000:03: resource 1 [mem 0xf0100000-0xf01fffff]
[ 0.145598] pci_bus 0000:03: resource 2 [mem 0x40000000-0x401fffff 64bit pref]
[ 0.145602] pci_bus 0000:05: resource 0 [io 0x6000-0x6fff]
[ 0.145606] pci_bus 0000:05: resource 1 [mem 0x40200000-0x403fffff]
[ 0.145610] pci_bus 0000:05: resource 2 [mem 0x40400000-0x405fffff 64bit pref]
[ 0.145614] pci_bus 0000:07: resource 0 [io 0x7000-0x7fff]
[ 0.145618] pci_bus 0000:07: resource 1 [mem 0x40600000-0x407fffff]
[ 0.145622] pci_bus 0000:07: resource 2 [mem 0x40800000-0x409fffff 64bit pref]
[ 0.145626] pci_bus 0000:09: resource 0 [io 0x8000-0x8fff]
[ 0.145629] pci_bus 0000:09: resource 1 [mem 0x40a00000-0x40bfffff]
[ 0.145633] pci_bus 0000:09: resource 2 [mem 0x40c00000-0x40dfffff 64bit pref]
[ 0.145637] pci_bus 0000:0b: resource 1 [mem 0xf0200000-0xf02fffff]
[ 0.145641] pci_bus 0000:0b: resource 4 [io 0x0000-0xffff]
[ 0.145645] pci_bus 0000:0b: resource 5 [mem 0x00000000-0xffffffff]
[ 0.145732] NET: Registered protocol family 2
[ 0.145816] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.146070] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.146543] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.146785] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.146788] TCP: reno registered
[ 0.146793] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.146804] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.146908] NET: Registered protocol family 1
[ 0.146934] pci 0000:00:02.0: Boot video device
[ 0.147139] PCI: CLS 32 bytes, default 64
[ 0.147217] Unpacking initramfs...
[ 0.530722] Freeing initrd memory: 13692k freed
[ 0.538115] Simple Boot Flag at 0x69 set to 0x1
[ 0.538655] audit: initializing netlink socket (disabled)
[ 0.538678] type=2000 audit(1434355020.532:1): initialized
[ 0.552895] highmem bounce pool size: 64 pages
[ 0.552904] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.553109] VFS: Disk quotas dquot_6.5.2
[ 0.553144] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.553253] msgmni has been set to 1741
[ 0.553494] alg: No test for stdrng (krng)
[ 0.553532] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.553538] io scheduler noop registered
[ 0.553541] io scheduler deadline registered
[ 0.553562] io scheduler cfq registered (default)
[ 0.553986] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.554018] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.554022] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.554635] GHES: HEST is not enabled!
[ 0.554656] isapnp: Scanning for PnP cards...
[ 0.908371] isapnp: No Plug & Play device found
[ 0.908429] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.928840] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.949266] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.970002] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.990485] 00:0c: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.990654] Linux agpgart interface v0.103
[ 0.990767] agpgart-intel 0000:00:00.0: Intel 915G Chipset
[ 0.990886] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 0.991303] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 0.991428] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 0.991619] i8042: PNP: PS/2 Controller [PNP0303:KEYB,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.994634] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.994683] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.994828] mousedev: PS/2 mouse device common for all mice
[ 0.994897] rtc_cmos 00:05: RTC can wake from S4
[ 0.995052] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.995084] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.995248] TCP: cubic registered
[ 0.995310] NET: Registered protocol family 10
[ 0.995612] Mobile IPv6
[ 0.995618] NET: Registered protocol family 17
[ 0.995626] Registering the dns_resolver key type
[ 0.995696] Using IPI No-Shortcut mode
[ 0.995832] PM: Hibernation image not present or could not be loaded.
[ 0.995856] registered taskstats version 1
[ 0.996341] rtc_cmos 00:05: setting system clock to 2015-06-15 07:57:01 UTC (1434355021)
[ 0.996457] Freeing unused kernel memory: 416k freed
[ 0.996701] Write protecting the kernel text: 3496k
[ 0.996724] Write protecting the kernel read-only data: 984k
[ 1.017664] udevd[45]: starting version 175
[ 1.063953] tg3.c:v3.123 (March 21, 2012)
[ 1.139563] usbcore: registered new interface driver usbfs
[ 1.139599] usbcore: registered new interface driver hub
[ 1.153285] tg3 0000:03:00.0: eth0: Tigon3 [partno(BCM95751) rev 4001] (PCI Express) MAC address 00:30:05:c6:0a:20
[ 1.153294] tg3 0000:03:00.0: eth0: attached PHY is 5750 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 1.153299] tg3 0000:03:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.153304] tg3 0000:03:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 1.173466] usbcore: registered new device driver usb
[ 1.177347] SCSI subsystem initialized
[ 1.181658] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.181752] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.181759] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.181797] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.181839] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.185342] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.194664] libata version 3.00 loaded.
[ 1.199470] microcode: CPU0 sig=0xf43, pf=0x10, revision=0x4
[ 1.199927] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 1.199965] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf00c0000
[ 1.208251] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.208319] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.208325] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.208329] usb usb1: Product: EHCI Host Controller
[ 1.208332] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.208336] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.208513] hub 1-0:1.0: USB hub found
[ 1.208522] hub 1-0:1.0: 8 ports detected
[ 1.209277] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.209284] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.209304] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.209336] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00002400
[ 1.209391] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.209396] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.209399] usb usb2: Product: UHCI Host Controller
[ 1.209403] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.209406] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.209701] hub 2-0:1.0: USB hub found
[ 1.209711] hub 2-0:1.0: 2 ports detected
[ 1.209854] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.209860] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.209874] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.209921] uhci_hcd 0000:00:1d.1: irq 22, io base 0x00002800
[ 1.209976] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.209981] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.209984] usb usb3: Product: UHCI Host Controller
[ 1.209987] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.209991] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.210148] hub 3-0:1.0: USB hub found
[ 1.210158] hub 3-0:1.0: 2 ports detected
[ 1.210294] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.210300] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.210312] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.210356] uhci_hcd 0000:00:1d.2: irq 21, io base 0x00002c00
[ 1.210412] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.210417] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.210420] usb usb4: Product: UHCI Host Controller
[ 1.210424] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.210427] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.210598] hub 4-0:1.0: USB hub found
[ 1.210607] hub 4-0:1.0: 2 ports detected
[ 1.210733] ata_piix 0000:00:1f.2: version 2.13
[ 1.210755] ata_piix 0000:00:1f.2: MAP [ IDE IDE P1 P3 ]
[ 1.252010] microcode: CPU0 updated to revision 0x5, date = 2005-04-21
[ 1.252709] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.364050] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.364787] scsi0 : ata_piix
[ 1.365007] scsi1 : ata_piix
[ 1.366332] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x4000 irq 14
[ 1.366338] ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0x4008 irq 15
[ 1.366490] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.366497] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.366515] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.366566] uhci_hcd 0000:00:1d.3: irq 20, io base 0x00003000
[ 1.366624] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.366629] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.366633] usb usb5: Product: UHCI Host Controller
[ 1.366637] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.366640] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.366928] hub 5-0:1.0: USB hub found
[ 1.366938] hub 5-0:1.0: 2 ports detected
[ 1.528323] ata1.00: ATAPI: HL-DT-STCD-RW/DVD DRIVE GCC-4244N, 1.00, max UDMA/33
[ 1.532253] ata2.00: ATA-7: WDC WD800JD-55MUA1, 10.01E01, max UDMA/133
[ 1.532260] ata2.00: 156301488 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.540264] ata2.00: configured for UDMA/133
[ 1.544203] ata1.00: configured for UDMA/33
[ 1.548047] Refined TSC clocksource calibration: 3191.999 MHz.
[ 1.548056] Switching to clocksource tsc
[ 1.549520] scsi 0:0:0:0: CD-ROM HL-DT-ST RW/DVD GCC-4244N 1.00 PQ: 0 ANSI: 5
[ 1.549850] scsi 1:0:0:0: Direct-Access ATA WDC WD800JD-55MU 10.0 PQ: 0 ANSI: 5
[ 1.563640] sd 1:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 1.563757] sd 1:0:0:0: [sda] Write Protect is off
[ 1.563763] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.563812] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.615977] sda: sda1 sda2 < sda5 >
[ 1.616508] sd 1:0:0:0: [sda] Attached SCSI disk
[ 1.620764] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 1.620879] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1.622837] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 1.622844] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.623385] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 1.676032] usb 5-1: new low-speed USB device number 2 using uhci_hcd
[ 1.852632] usb 5-1: New USB device found, idVendor=1a2c, idProduct=0e24
[ 1.852640] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.852645] usb 5-1: Product: USB Keyboard
[ 1.852649] usb 5-1: Manufacturer: SEM
[ 1.878275] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:1d.3/usb5/5-1/5-1:1.0/input/input0
[ 1.879141] generic-usb 0003:1A2C:0E24.0001: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-0000:00:1d.3-1/input0
[ 1.901777] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:1d.3/usb5/5-1/5-1:1.1/input/input1
[ 1.901917] generic-usb 0003:1A2C:0E24.0002: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-0000:00:1d.3-1/input1
[ 1.902006] usbcore: registered new interface driver usbhid
[ 1.902010] usbhid: USB HID core driver
[ 2.092032] usb 5-2: new low-speed USB device number 3 using uhci_hcd
[ 2.256629] usb 5-2: New USB device found, idVendor=0000, idProduct=0538
[ 2.256636] usb 5-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.256641] usb 5-2: Product: USB OPTICAL MOUSE
[ 2.275288] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.3/usb5/5-2/5-2:1.0/input/input2
[ 2.275407] generic-usb 0003:0000:0538.0003: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.3-2/input0
[ 4.176056] floppy0: no floppy controllers found
[ 9.206441] PM: Starting manual resume from disk
[ 9.206448] PM: Hibernation image partition 8:5 present
[ 9.206451] PM: Looking for hibernation image.
[ 9.206679] PM: Image not found (code -22)
[ 9.206683] PM: Hibernation image not present or could not be loaded.
[ 9.253183] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.408782] udevd[317]: starting version 175
[ 11.725089] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 11.725100] ACPI: Power Button [PWRB]
[ 11.725224] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 11.725231] ACPI: Power Button [PWRF]
[ 11.887958] intel_rng: FWH not detected
[ 11.905809] iTCO_vendor_support: vendor-support=0
[ 11.906640] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 11.906764] iTCO_wdt: Found a ICH6 or ICH6R TCO device (Version=2, TCOBASE=0xf060)
[ 11.906838] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 12.275540] [drm] Initialized drm 1.1.0 20060810
[ 12.742457] i915 0000:00:02.0: setting latency timer to 64
[ 12.770105] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 12.770111] [drm] Driver supports precise vblank timestamp query.
[ 12.770185] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 12.834144] parport_pc 00:0a: reported by Plug and Play ACPI
[ 12.834211] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 12.901294] [drm] initialized overlay support
[ 13.014925] fbcon: inteldrmfb (fb0) is primary device
[ 13.074020] Console: switching to colour frame buffer device 160x64
[ 13.078953] fb0: inteldrmfb frame buffer device
[ 13.078958] drm: registered panic notifier
[ 13.078968] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 13.079056] snd_intel8x0 0000:00:1e.2: setting latency timer to 64
[ 13.500037] intel8x0_measure_ac97_clock: measured 52454 usecs (2528 samples)
[ 13.500044] intel8x0: clocking to 48000
[ 14.912064] floppy0: no floppy controllers found
[ 15.949850] Adding 2075644k swap on /dev/sda5. Priority:-1 extents:1 across:2075644k
[ 15.970522] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 16.284037] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 16.462985] loop: module loaded
[ 18.196690] RPC: Registered named UNIX socket transport module.
[ 18.196696] RPC: Registered udp transport module.
[ 18.196699] RPC: Registered tcp transport module.
[ 18.196702] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 18.238775] FS-Cache: Loaded
[ 18.279680] NFS: Registering the id_resolver key type
[ 18.279711] FS-Cache: Netfs 'nfs' registered for caching
[ 18.287249] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 20.328602] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 22.160214] Bluetooth: Core ver 2.16
[ 22.160523] NET: Registered protocol family 31
[ 22.160528] Bluetooth: HCI device and connection manager initialized
[ 22.160532] Bluetooth: HCI socket layer initialized
[ 22.160535] Bluetooth: L2CAP socket layer initialized
[ 22.160545] Bluetooth: SCO socket layer initialized
[ 22.203073] Bluetooth: RFCOMM TTY layer initialized
[ 22.203085] Bluetooth: RFCOMM socket layer initialized
[ 22.203089] Bluetooth: RFCOMM ver 1.11
[ 22.216373] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.216379] Bluetooth: BNEP filters: protocol multicast
[ 22.284746] lp0: using parport0 (interrupt-driven).
[ 22.468660] ppdev: user-space parallel port driver
[ 25.232447] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 26.819062] tg3 0000:03:00.0: eth0: Link is up at 100 Mbps, full duplex
[ 26.819069] tg3 0000:03:00.0: eth0: Flow control is on for TX and on for RX
[ 26.819201] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 38.120012] eth0: no IPv6 routers present
[ 206.859286] udevd[7249]: starting version 175
[ 370.536695] I-pipe: head domain RTAI registered.
[ 370.536703] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 370.536712] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 370.536718] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12468720, CLK_FREQ 3192011000, CPU_FREQ 3192011000
[ 370.536722] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 370.536727] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12468720, 12468720, 12416250
[ 370.589959] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 370.590002] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 370.590010] RTAI[sched]: hard timer type/freq = APIC/12468720(Hz); default timing: oneshot; linear timed lists.
[ 370.590016] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3192011000 hz.
[ 370.590019] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 370.667572] RTAI[math]: loaded.
[ 370.712275] config string '0x0378 out'
[ 370.718316] hm2: loading Mesa HostMot2 driver version 0.15
[ 370.721566] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 370.721617] hm2_pci: discovered 5i25 at 0000:0b:05.0
[ 370.721776] hm2/hm2_5i25.0: config.num_encoders=3, but only 2 are available, not loading driver
[ 370.721781] hm2/hm2_5i25.0: failed to parse Module Descriptor 2
[ 370.721792] hm2_5i25.0: board fails HM2 registration
[ 370.721818] hm2_pci: probe of 0000:0b:05.0 failed with error -22
[ 371.454111] hm2: unloading
[ 475.673909] RTAI[math]: unloaded.
[ 475.678997] SCHED releases registered named ALIEN PEDV$D
[ 475.688300] RTAI[malloc]: unloaded.
[ 475.788030] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 475.790381] I-pipe: head domain RTAI unregistered.
[ 475.790395] RTAI[hal]: unmounted.
[ 523.159427] I-pipe: head domain RTAI registered.
[ 523.159437] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 523.159446] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 523.159451] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12468720, CLK_FREQ 3192011000, CPU_FREQ 3192011000
[ 523.159455] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 523.159460] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12468720, 12468720, 12428000
[ 523.173771] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 523.173816] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 523.173824] RTAI[sched]: hard timer type/freq = APIC/12468720(Hz); default timing: oneshot; linear timed lists.
[ 523.173829] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3192011000 hz.
[ 523.173833] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 523.187000] RTAI[math]: loaded.
[ 523.365158] hm2: loading Mesa HostMot2 driver version 0.15
[ 523.367949] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 523.367996] hm2_pci: discovered 5i25 at 0000:0b:05.0
[color=#ff0044][color=#ff4400][ 523.368159] hm2/hm2_5i25.0: config.num_encoders=3, but only 2 are available, not loading driver
[ 523.368165] hm2/hm2_5i25.0: failed to parse Module Descriptor
[ 523.368175] hm2_5i25.0: board fails HM2 registration
[ 523.368199] hm2_pci: probe of 0000:0b:05.0 failed with error -22
[ 523.781020] hm2: unloading
[ 523.852137] RTAI[math]: unloaded.
[ 523.854629] SCHED releases registered named ALIEN PEDV$D
[ 523.863422] RTAI[malloc]: unloaded.
[ 523.960020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 523.962645] I-pipe: head domain RTAI unregistered.
[ 523.962660] RTAI[hal]: unmounted.
Last edit: 15 Jun 2015 22:20 by BigJohnT.
- Thank you received: 5229
15 Jun 2015 21:39 #59850
Replied by PCW on topic 4i25 + 7i77 installation problems
Sounds like you have the wrong firmware in the 5I25
You use mesaflash to update the firmware
first download the support image:
www.mesanet.com/software/parallel/5i25.zip
unzip this file and cd to the configs/hostmot2 directory
then run this command:
sudo mesaflash --device 5i25 --write 5i25_7i77x2.bit
then power cycle your machine and try again
Time to create page: 0.055 seconds
