Traverse problems
- Sven
22 Jun 2015 05:00 #60044
by Sven
Traverse problems was created by Sven
Newbie question. I just finished building a 3 axis CNC router. It cuts accurately for the most part, but when it does a fast traverse it will sometimes be significantly off. Not that it needs measuring to see, it pretty obvious.
I wonder if I am traversing too fast? What are typical causes for something like this?
-Steve
-Steve
- Sven
22 Jun 2015 06:47 #60046
by Sven
Replied by Sven on topic Traverse problems [solved]
The MAX_VELOCITY displayed in the GUI was set to 600 in/min, which is way too fast for my machine. I was using G0 to move around and my machine didn't like that. Changing the G0's to G1's slowed down the rapid traverse to 60 in/min, same as the cutting speed, and it worked very well.
Anyone know what the MAX_VELICITY is in? The setting under [DISPLAY] is set to 10.00, but shows as 600 in/min in the GUI. I can probably share my .ini file if that'll help.
-Steve
-Steve
- Thank you received: 1464
22 Jun 2015 09:09 #60047
Replied by Todd Zuercher on topic Traverse problems [solved]
It is in machine units (in your case inches) per second. 10 IPS X 60 = 600 IPM
The following user(s) said Thank You: Sven
- Sven
22 Jun 2015 09:15 #60048
by Sven
Thanks Todd! That's awesome.
I wonder if that can be put in the docs? At least it's not where I was looking.
linuxcnc.org/docs/html/gcode/gcode.html#sec:G0
Until I found this:
wiki.linuxcnc.org/cgi-bin/wiki.pl?IniFile
Thanks again!
-Steve
Until I found this:
Thanks again!
-Steve
- BigJohnT
- Thank you received: 1176
22 Jun 2015 17:45 #60054
by BigJohnT
Replied by BigJohnT on topic Traverse problems [solved]
Time to create page: 0.051 seconds
