Spindle digitial out + Modbus control?
- giggler999
22 Jun 2015 20:01 #60058
by giggler999
Spindle digitial out + Modbus control? was created by giggler999
I've got a huanyang vfd now working with modbus. I used to use a router through solid state relay control via parallel port digital output.
I still need the digital output for spindle on/off because I have a lamp stick that changes on steps + spindle on/off. The lack of signal means the lamp stick does not change now as the command is sent over modbus instead.
Is there any way to get my hal to map the signal to two modules? i.e. my old parallel port pin and the modbus? Or another signal to pick up on and route to the parallel port output?
I am aware that the drive has some I/O but looking at posts it is not obvious how to configure it and that most people don't seem to be using it.
Regards,
giggler
Regards,
giggler
- Thank you received: 1464
22 Jun 2015 21:35 #60060
Replied by Todd Zuercher on topic Spindle digitial out + Modbus control?
I would think that using the outputs on the drive would be preferable, since there you would be seeing the true state of the drive. But you can connect multiple pins to the same signal in hal.
- alan_3301
- Thank you received: 33
23 Jun 2015 05:48 #60072
by alan_3301
Replied by alan_3301 on topic Spindle digitial out + Modbus control?
In my testing on the huanyang, when using rs485 for on/off control, the multi input terminals no longer work.
I was trying to hook the drive up to the e-stop, but it didn't monitor the IO anymore.
You should be able to connect the hal pin for your lamp output to motion.spindle-on
Time to create page: 0.046 seconds
