a4988 requirements
- garbageman
02 Jul 2015 08:21 #60325
by garbageman
a4988 requirements was created by garbageman
Hi I'm looking to find out how to run polulu a4988 stepper drivers with linux cnc, what other circuits and stuff I might need, if I can just hook it strait up to the parallel port and if so how and all that good stuff.
Cheers Ryan
Cheers Ryan
The following user(s) said Thank You: cncbasher
- cncbasher
- Thank you received: 288
02 Jul 2015 16:38 #60332
by cncbasher
Replied by cncbasher on topic a4988 requirements
a4988 , are straight forward , using step , direction and enable , follow any standard design for example reprap , and connect using a breakout board
to the parraell port , or follow the designs of the beaglebone black and the Machinekit project ,
- Thank you received: 4967
02 Jul 2015 20:08 #60340
You probably can wire directly to the parport. There is some risk of wiring errors damaging the parallel port, which is why a breakout board is normally suggested, but directly to the parport (configured to sink current) works too.
Replied by andypugh on topic a4988 requirements
Time to create page: 0.057 seconds
