Need help with error message
- jrbankston1
04 Jul 2015 19:33 #60405
by jrbankston1
Need help with error message was created by jrbankston1
My machine worked fine yesterday but today I cannot load axis. I get the attached error message. I have tried several times and even tried rebooting the computer with the same results. Can anyone help me with this problem.
- ArcEye
- Thank you received: 758
04 Jul 2015 22:43 #60407
by ArcEye
Replied by ArcEye on topic Need help with error message
Nothing attached.
Rename it with a .txt extension and it will work
- jrbankston1
04 Jul 2015 23:11 #60408
by jrbankston1
Replied by jrbankston1 on topic Need help with error message
Lets try again.
- jrbankston1
04 Jul 2015 23:14 - 05 Jul 2015 02:01 #60409
by jrbankston1
Could not get it to attach, but this might work.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/julian/linuxcnc/configs/CNC-router'
Machine configuration file is 'CNC-router.ini'
INIFILE=/home/julian/linuxcnc/configs/CNC-router/CNC-router.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
INFO CLASSICLADDER- No ladder GUI requested-Realtime runs till HAL closes.
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=2439
Killing task milltask, PID=2491
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
custom_postgui.hal:5: Warning: File contains DOS-style line endings.
custom_postgui.hal:28: Pin 'halui.mdi-command-03' does not exist
2439
PID TTY STAT TIME COMMAND
2491
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 100.843261] I-pipe: Domain RTAI registered.
[ 100.843270] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 100.843272] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 100.843277] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 100.843279] PIPELINE layers:
[ 100.843282] dac1ce20 9ac15d93 RTAI 200
[ 100.843285] c085cb20 0 Linux 100
[ 100.864878] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 100.865050] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 100.865055] RTAI[sched]: hard timer type/freq = APIC/12462890(Hz); default timing: periodic; linear timed lists.
[ 100.865058] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2194095000 hz.
[ 100.865060] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 100.865178] RTAI[usi]: enabled.
[ 100.938591] RTAI[math]: loaded.
[ 101.023347] config string '0x378 out '
[ 101.032524] creating ladder-state
[ 105.179981] RTAI[math]: unloaded.
[ 105.232249] SCHED releases registered named ALIEN RTGLBH
[ 105.248819] RTAI[malloc]: unloaded.
[ 105.348012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 105.351504] I-pipe: Domain RTAI unregistered.
[ 105.351514] RTAI[hal]: unmounted.
Last edit: 05 Jul 2015 02:01 by BigJohnT. Reason: add code tags
- BigJohnT
- Thank you received: 1176
05 Jul 2015 02:05 - 05 Jul 2015 02:06 #60413
by BigJohnT
Replied by BigJohnT on topic Need help with error message
There are limitations for file size (not an issue here) and extensions.
linuxcnc.org/index.php/english/forum/36-...-this-before-posting
Looks like your trying to load classicladder without a file maybe.
JT
JT
Last edit: 05 Jul 2015 02:06 by BigJohnT.
- jrbankston1
05 Jul 2015 04:02 #60421
by jrbankston1
Thanks BigJohn
Yesterday I installed a touch plate following instructions in "For Science" and it worked well except the Z axis would not retract after touching the plate. I tried it several times with different plate heights and each time it worked fine. When I tried to start up LinuxCNC this morning I got the error message that I posted. I cant understand why it worked yesterday but not today. Any suggestions? Maybe I should start over and load it again.
- BigJohnT
05 Jul 2015 04:47 #60423
by BigJohnT
Oh I found it!
You have edited your custom_postgui.hal file with something other than a plain text editor. I always use Gedit in Linux and Notepad++ in Windoze. Open your file up in Gedit and Save As with Line Ending: Unix/Linux.
JT
JT
- ArcEye
05 Jul 2015 23:19 #60441
by ArcEye
Linuxcnc halted because of the error on line 28
Either this was caused by unknown symbols in the file because of windoze line endings, or you simply do not have
the mdi-command-03 defined in your ini file
Clean up the file as JT suggests and you should soon find out
Time to create page: 0.064 seconds
