Jog when doing tool change
21 May 2010 00:30 #2940 by cwebs
Jog when doing tool change was created by cwebs
I found that I can't jog or reset Z zero during M6 tool change. Is there a way of moving to do this? Is there a gcode edit I can insert at the M6 command? The problem came up when I had to install a longer tool. Carl
21 May 2010 11:24 #2950 by BigJohnT
Replied by BigJohnT on topic Re:Jog when doing tool change
At this time that is not possible. If you don't have presettable tools you should split up the program between tool changes.
21 May 2010 11:33 #2951 by cwebs
Replied by cwebs on topic Re:Jog when doing tool change
Thanks for the answer. That is just what I had to do. The problem was after engraving with a .062 mill I had to put in a drill witch is much longer.
11 Nov 2013 14:25 #40726 by bottleworks
Replied by bottleworks on topic Jog when doing tool change
So fast forward a few years.... Has anything changed with this? (If not), Any plans to implement this? Thanks
11 Nov 2013 19:02 #40734 by newbynobi
Replied by newbynobi on topic Jog when doing tool change
Take a look here, nothing is imposible:
Extending linuxcnc
