why mpg hookup uses "a second parallel port"
17 Aug 2015 08:56 #61476 by southbayguy
Hi -
The description of how to hook up an MPG3 handheld pendant using a C22 interface card, both from CNC4PC, says:
"This example uses a MPG3 pendant and a C22 pendant interface card from [CNC4PC] and a second parallel port plugged into the PCI slot"
Is there some reason it has to be a second parallel port? I have an unused parallel port ... as far as I know it's the first parallel port. Can I use it?
... sorry about this ... it might be a dumb question.
-southbayguy
17 Aug 2015 10:11 #61479 by cmorley
Replied by cmorley on topic why mpg hookup uses "a second parallel port"
Yes you can use any parallel port that is available.
Just need to change the address in the loadrt line for the parports.
Chris M
Time to create page: 0.050 seconds
