Both Home and Limit Switch?
- RobLynch
24 Aug 2015 09:41 #61730
by RobLynch
Both Home and Limit Switch? was created by RobLynch
Hello,
Moving away from Mach3. Did the import routine and it migrated the motor/driver settings into LinuxCnc but not my limit switch configuration.
So my configuration is as follows:
3 Axis Mill.
Limit switches for both -x and + x, -y and +y and +Z. Each are Axis has its own pin value in stepconf.
So my question is: Which limit switch configuration should I use?
The wiki documentation doesn't really give you a definition that I could see that described each of the limit switch options available in stepconfig.
I would like to home the machine like I did with Mach3.
Thank you,
3 Axis Mill.
Thank you,
- Thank you received: 2159
24 Aug 2015 10:31 #61733
Replied by cmorley on topic Both Home and Limit Switch?
so you have two switches combined to one parport input pin and you want to use it for home too?
that's 'both limits + home x'
It seems you only have a +z limit switch and you want to use it for home too?
that's 'maximum limit + home"
Chris M
Chris M
- RobLynch
24 Aug 2015 11:22 #61734
by RobLynch
Replied by RobLynch on topic Both Home and Limit Switch?
Thank you Chris for the quick reply!
I will give that a try.
Time to create page: 0.046 seconds
